Sd90 mini servo not working
This is my first arduino UNO, it came in the ultimate starter kit. The servo also came with it for use with the project book. The servo moves 0 - 180 degrees and the motor simply does not move again. The servo is humming, but no movement. I played with the code, took the servo apart. Nothing. Would this be a bad servo? Or am I doing something wrong?
You will need to show us the code and the wiring circuit you are using.
...R
I assume you are using a servo library and example. You realise you can't just use 5V, or even pwm to drive a servo.
The gears in the small servos tend to strip easily. Below is some servo test code you can use to test the movement of your servo.
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7, 500, 2500);  //the pin for the servo control, and range if desired
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
