sda and slc ic2 on esp12
I’m sure this has been asked before, but I couldn’t find it on searches.
I am doing an oled1306 on esp-12 from geekcreit. I am running the scanner (which works for me on other occasions.
1306
scl → d4 (gpi02)
sda → d5 (gpio14)
nothing shows for scanner.
I have modified Wire.begin(4,5) and flipped it to (5,4)
Scanner isn’t picking anything up.
What I m missing?
CircuitMagic.com
#include <SPI.h>
#include <Wire.h>
  Wire.begin(4,5);
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknow error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000); // wait 5 seconds for next scan
fixed. d2 (gpio14) doesn't mean 2 is the pin. 14 is the correct pin to code for.
I also have a few ESP8266 + OLED projects here.
Ray
