sdcard load pictures with effective way
i could to upload a picture stored in sdcard using zoomkat codes like this
if(readString.indexOf("image") >=0) {
client.println("Content-Type: image/jpeg");
client.println(); }
//select file to send to browser
if(readString.indexOf("image") >= 0) {
File myFile = SD.open("image.jpg");
if (myFile) {
while (myFile.available()) {
client.write(myFile.read());
myFile.close();
my problem now is i have many pictures on the sd card and need to upload all of them if i repeat the code i will waste a lot of memory so
my question is can i do a for loop to identify and upload many pictures ??? i tried but not working any suggestion will be appreciated
the picture i want to upload has this name (IMAGE00 -> IMAGE09)
Please post the code you tried even if it didn't work.
It sounds to me as though you need a function to read a file and for the name of the file to be passed to the function as a parameter. That way the file reading code only has to be be written and maintained in the function, not multiple times.
this is all of my code for one picture only
//zoomkat 1/26/13
//SD server slider test code
//open serial monitor to see what the arduino receives
//address will look like http://192.168.1.102:84/servosld.htm when submited
//for use with W5100 based ethernet shields
//put the servosld.htm, slider.js, bluev_sl.gif,
//and bluev_bg.gif on the SD card
//files at http://web.comporium.net/~shb/servoslider.htm page
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
String readString ;
byte mac[] = {0x90, 0xA2, 0xDA, 0x80, 0x0A, 0xC6 }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
void setup(){
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
Serial.print("Starting SD..");
if(!SD.begin(4)) Serial.println("failed");
else Serial.println("ok");
Ethernet.begin(mac, ip, gateway, gateway, subnet);
//delay(2000);
server.begin();
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
//select proper header for file to be sent to browser
client.println("HTTP/1.1 200 ok"); //send new page
if(readString.indexOf("bk") >=0) {
client.println(); }
if(readString.indexOf("bk") >= 0) {
File myFile = SD.open("bk.jpg");
if (myFile) {
myFile.close();
delay(1);
//stopping client
client.stop();
readString="";
Maybe make the image name a variable, and add a counter so that it increases it every time it loops to upload an image?
The question is this File myFile = SD.open("bk.jpg"); accept variable name ???
try
File myFile = SD.open(variable);
PREDICTION : Your next question will be "how do I create a series of filenames and put them into a variable to use with the function"
its true :roll_eyes: my skills in coding is very poor so its a problem to me
Start by explicitly setting a variable to a filename in the program then using the variable with SD.open()
If it works then you are moving in the right direction. You could then consider setting the variable explicitly to the next filename and calling the function and so on, but maybe you can do better ....
Will the filenames always be the same, will there always be the same number of them, is there a pattern to the filenames ?
yes all the pictures has the name (IMAGE00 -> IMAGE09) 10 pictures with these names
In which case you can use something like this to create the filenames
char fileName[] = {"IMAGE0 "};
  for (byte fileNumber = 0; fileNumber < 10; fileNumber++)
    fileName[6] = (char)fileNumber + 48;
    Serial.println(fileName);
Instead of printing the filename you would, of course, pass it to your function that loads the file from the SD card.
NOTE - this will only work for filenames from 00 to 09
thanx a lot for your effort and reply i try your code and passing a variable name to
File myFile = SD.open(fileName.jpg);
but this error face me "request for member 'jpg in 'fileName' which is of non-class type char[8]"
You can't just stick an extension (or anything else) on the end of a variable and expect it to work, hence the error.
The code was meant to give you an idea of what you could do, not a complete solution.
Changechar fileName[] = {"IMAGE0 "};tochar fileName[] = {"IMAGE0 .jpg"};in my code and run it to make sure that you get the results that you expect before trying it in your code.
I've tried to figure out a single function to support uploading several files from the SD card for the below code. So far I haven't figured out how to set the file name to a variable that is acceptable to the SD file open actions.
//zoomkat 1/26/13
#include <SD.h>
#include <SPI.h>
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
Servo myservoe, myservof, myservog;
String readString, pos;
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
void setup(){
  // disable w5100 while setting up SD
  pinMode(10,OUTPUT);
  //delay(2000);
  server.begin();
  Serial.println("Ready");
  myservoa.attach(2);  //the pin for the servoa control
  myservob.attach(3);  //the pin for the servob control
  myservoc.attach(5);  //the pin for the servoc control
  myservod.attach(6);  //the pin for the servod control
  myservoe.attach(7);  //the pin for the servoa control
  myservof.attach(8);  //the pin for the servob control
  myservog.attach(9);  //the pin for the servoc control
  //myservoh.attach(10);  //the pin for the servod control
void loop(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
           if(readString.indexOf("Submit") >=0) { //don't send new page
           client.println("HTTP/1.1 204 Zoomkat");
           client.println();
           client.println(); }
          //client.println("HTTP/1.1 200 OK"); //send new page
          if(readString.indexOf("servosld") >=0) {
          client.println("Content-Type: text/html");
          client.println(); }
          if(readString.indexOf("slider") >=0) {
          client.println("Content-Type: application/x-javascript");
          client.println(); }
          if(readString.indexOf("bluev") >=0) {
          client.println("Content-Type: image/gif");
          client.println(); }
            File myFile = SD.open("SERVOSLD.HTM");
            if (myFile) {
              myFile.close();
            File myFile = SD.open("slider.js");
            if (myFile) {
              myFile.close();
          if(readString.indexOf("bluev_sl") >=0) {
            File myFile = SD.open("bluev_sl.gif");
            if (myFile) {
              myFile.close();
          if(readString.indexOf("bluev_bg") >=0) {
            File myFile = SD.open("bluev_bg.gif");
            if (myFile) {
              myFile.close();
          delay(1);
          //stopping client
          client.stop();
          //process GET string request from client and and position servo
          pos = readString.substring(8, 12); //get the first four characters
          //Serial.println(pos);
          int n = pos.toInt();  //convert readString into a number
          Serial.println(n);
          if(readString.indexOf("?0") >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf("?1") >0) myservob.writeMicroseconds(n);
          if(readString.indexOf("?2") >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf("?3") >0) myservod.writeMicroseconds(n);
          if(readString.indexOf("?4") >0) myservoe.writeMicroseconds(n);
          if(readString.indexOf("?5") >0) myservof.writeMicroseconds(n);
          if(readString.indexOf("?6") >0) myservog.writeMicroseconds(n);
          //only seven servo pins, so back to myservoa for testing
          if(readString.indexOf("?7") >0) myservoa.writeMicroseconds(n);
          //clearing string for next read
          readString="";
          pos="";
That's because you think that the only character-handling tool on the Arduino is the String class. There are also strings - NULL terminated arrays of chars. sprintf() would let you construct a name based on a variable:
int servoNum = 12;
char buff[16];
sprintf(buff, "Servo%d.dat", servoNum);
file servoData = SD.open(buff);
And that ethernet transfer code is slow. Read this and the posts that follow in this thread.
http://forum.arduino.cc/index.php?topic=134868.msg1123725#msg1123725
SurferTim:
Why's SD -> Ethernet Card -> Webbrowser so slow? - #5 by SurferTim - Home Automation - Arduino Forum
I intentionally left out the buffering to keep things simple and just focus on the SD function. Ideally the buffering would occur in the function and all file uploads would be processed via the function.
