Hello there
I've a problem with my Ethernet SD server
The server is working very well and I can access my index.htm page
The index page contains a button that action is only to go to another page when it clicked
But when I click it doesn't acsses the second page
I thought that could be a HTML code error
But trying the same pages over PC without arduino they are working
What would be the problem ?
Perhaps is you showed the sketch someone would have a chance of locating your problem.
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(169, 254, 214, 254); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile;
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while (webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
what about ROOT SD command
Your Arduino web server only ever serves one page. It ignores the contents of the request and always returns the contents of index.htm. To access a different page you will have to look at the HTTP request to see what page is being requested. Try displaying the lines of the request to see what the browser is requesting.
