sdfat - fgets
Hello there :slight_smile: ,
Looking at the sample for sdfat fgets, is there a way of altering it (with a button attached to pin 8 when it goes high, pressed) to show the next line, as the example loads all the lines in 1 go.
// Demo of fgets function to read lines from a file.
#include <SPI.h>
#include <SdFat.h>
// SD chip select pin
const uint8_t chipSelect = SS;
SdFat sd;
// print stream
ArduinoOutStream cout(Serial);
// store error strings in flash memory
#define error(s) sd.errorHalt(F(s))
void demoFgets() {
  char line[25];
  int n;
  // open test file
  SdFile rdfile("fgets.txt", O_READ);
  // check for open error
  if (!rdfile.isOpen()) {
    error("demoFgets");
  cout << endl << F(
         "Lines with '>' end with a '\\n' character\n"
         "Lines with '#' do not end with a '\\n' character\n"
         "\n");
  // read lines from the file
  while ((n = rdfile.fgets(line, sizeof(line))) > 0) {
    if (line[n - 1] == '\n') {
      cout << '>' << line;
      cout << '#' << line << endl;
void makeTestFile() {
  // create or open test file
  SdFile wrfile("fgets.txt", O_WRITE | O_CREAT | O_TRUNC);
  if (!wrfile.isOpen()) {
    error("MakeTestFile");
  // write test file
  wrfile.print(F(
                 "Line with CRLF\r\n"
                 "Line with only LF\n"
                 "Long line that will require an extra read\n"
                 "\n"  // empty line
                 "Line at EOF without NL"
  wrfile.close();
void setup(void) {
  while (!Serial) {}  // Wait for Leonardo
  cout << F("Type any character to start\n");
  while (Serial.read() <= 0) {}
  delay(400);  // catch Due reset problem
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  if (!sd.begin(chipSelect, SPI_HALF_SPEED)) {
    sd.initErrorHalt();
  makeTestFile();
  demoFgets();
  cout << F("\nDone\n");
void loop(void) {}
Many Thanks,
Pete
Will offer a bit of $ via PayPal if anyone can help?
Here is a version of the fgets example that waits for pin 8 to go high and then low after each line. It has a debounce that can be adjusted by the value of DEBOUNCE_COUNT.
Hope you are capable of modifying the example for your needs.
#include <SPI.h>
#include <SdFat.h>
SdFat sd;
// print stream
// wait for switch to be pushed and released.
void waitSwitch() {
  const uint8_t SWITCH_PIN = 8;
  const uint8_t DEBOUNCE_COUNT = 10;
  uint8_t count = DEBOUNCE_COUNT;
  // Wait for pin to go high.
  while (!digitalRead(SWITCH_PIN)) {}
  // Wait for pin to go low with debounce.
  while (count) {
    delay(10);
    if (digitalRead(SWITCH_PIN)) {
      count--;
void demoFgets() {
  char line[25];
  int n;
  // open test file
    error("demoFgets");
  cout << endl << F(
         "\n");
    waitSwitch();
  // write test file
  wrfile.print(F(
                 "\n"  // empty line
  wrfile.close();
void setup(void) {
    sd.initErrorHalt();
  makeTestFile();
  demoFgets();
void loop(void) {}
