im getting the error:
GpsDataLoggerInstructable_pde.ino: In function 'void setup()':
GpsDataLoggerInstructable_pde:56: error: no matching function for call to 'SdVolume::init(Sd2Card&)'
C:\Program Files (x86)\Arduino\libraries\SdFat/SdVolume.h:81: note: candidates are: bool SdVolume::init(Sd2Card*)
C:\Program Files (x86)\Arduino\libraries\SdFat/SdVolume.h:82: note: bool SdVolume::init(Sd2Card*, uint8_t)
and then if i try its' suggustions it says that the following line needs to follow an initialiser
the two lines are:
volume.init(card); //Initialize a volume on the SD card.
root.openRoot(volume); //Open the root directory in the volume.
i need some help with converting to the updated version of SdFat.h
what should i replace these two lines with?
