SDFAT library- converting from SD
Moving from SD to SdFat lib, I am trying to run the example program “Backwards Compatibility”.
With #define USE_SD_H 0 (using SdFat) I’m getting this error - BackwardCompatibility:24: error: ‘File’ does not name a type
File myFile;
and
BackwardCompatibility:48: error: ‘myFile’ was not declared in this scope
myFile = SD.open(“test.txt”, FILE_WRITE);
I’m not quite sure why? Sd lib is working fine. File is not a type with SdFat? What needs to be done to fix this?
// A simple read/write example for SD.h.
// Mostly from the SD.h ReadWrite example.
// Your SD must be formatted FAT16/FAT32.
// Set USE_SD_H nonzero to use SD.h.
// Set USE_SD_H zero to use SdFat.h.
#define USE_SD_H 0
#if USE_SD_H
#include <SD.h>
#else  // USE_SD_H
#include "SdFat.h"
SdFat SD;
#endif  // USE_SD_H
// Modify SD_CS_PIN for your board.
// For Teensy 3.6 and SdFat.h use BUILTIN_SDCARD.
#define SD_CS_PIN 10
File myFile;
  while (!Serial) {}
#if USE_SD_H
  Serial.println(F("Using SD.h. Set USE_SD_H zero to use SdFat.h."));
#else  // USE_SD_H
  Serial.println(F("Using SdFat.h. Set USE_SD_H nonzero to use SD.h."));
#endif  // USE_SD_H
  Serial.println(F("\nType any character to begin."));
  while (!Serial.available()) {
    yield();
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS_PIN)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    // close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
    // close the file:
    myFile.close();
  // nothing happens after setup
Please follow the advice on posting a programming question given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
OK thanks I have read the posting info and see the error in my post. Sorry can some help or will i need to repost?
Thanks for adding the code tags. It really does make it easier to examine the code
