sdFat put filename to var
hi,
i try to put a filename to a variable. I use the sdFat library. later i want to compear the first two chars of the name with a integer. But my biggest problem is get the filename. This is what i tried:
#include <SPI.h>
#include "SdFat.h"
#include <SdFatutil.h>
// SD default chip select pin.
const uint8_t chipSelect = 4;
// file system object
SdFat sd;
SdFile file;
byte currentDir=9;
byte track=3;
  if (!sd.begin(chipSelect, SPI_HALF_SPEED)) {
    sd.initErrorHalt();
  char dirName[4]="";                     //----
  sprintf(dirName,"%02i",currentDir);     //  |
  strcat(dirName,"/");                    //  V
  sd.chdir(dirName);                      //go to current directory
  getFileName();                          //read name of the file
void getFileName(){
    char* fBuffer;
    while (file.openNext(sd.vwd(), O_READ)) {
      file.getName(fBuffer,13);
      file.printName(&Serial);
      file.close();
the help of the sdFat
bool FatFile::getName 	( 	char *  	name,
		size_t  	size
Get a file's name followed by a zero byte.
Parameters
    [out]	name	An array of characters for the file's name.
    [in]	size	The size of the array in bytes. The array must be at least 13 bytes long. The file's name will be truncated if the file's name is too long.
Returns
    The value true, is returned for success and the value false, is returned for failure.
but i don't understand how to use this.
can anyone pleas help me?
Put the name of the file in the 13 bytes that the pointer points to. Where, exactly, does that pointer point?
Nowhere that you have any control over.
Use an array, NOT a pointer!
