The function LS didn't work for me so i try to build a recursive file list function by myself.
But it works not so fine.
It prints the first files, then prints the files from the first Directory but then Ends and i don't know why.
#include <SdFat.h>
const uint8_t chipSelect = 4;
SdFat sd;
SdFile file;
void pf(char *dir) {
uint32_t pos = 0;
Serial.print("*****");
Serial.println(dir);
sd.chdir(dir);
char name[13];
while (1) {
sd.vwd()->seekSet(pos);
if (!file.openNext(sd.vwd(), O_READ)) break;
pos = sd.vwd()->curPosition();
bool z = file.isDir();
file.getFilename(name);
Serial.println(name);
file.close();
if (z) pf(name);
Serial.println("-ende-");
if (!sd.begin(chipSelect, SPI_HALF_SPEED)) sd.initErrorHalt();
pf("\\");
void loop() {}
Here is the problem.
sd.chdir(dir);
This changes sd.vwd() to a different directory so the recursion will not work. Your in the wrong directory when the recursive call returns.
You need to keep the state of the directory at every level.
That's why ls() does the recursion like this with an additional file, s.
SdBaseFile s;
if (s.open(this, index, O_READ)) s.ls(pr, flags, indent + 2);
I wrote ls() quickly a long time ago and should revisit ls(). I may do that soon since I am writing a new generic FAT filesystem that is not SD or Arduino dependent.
Hm, ok. I thought with:
s.vwd()->seekSet(pos);
i go back to the old list pos.
I look if i can build it with your tip.
Thanks.
This changes the file that sd.vwd() point to.
sd.chdir(dir);
Restoring the position has no meaning since sd.vwd() now is a handle for "dir", not the file that you referenced with this.
You can not modify a global variable in a recursive function and have recursion work correctly.
What feature do you need in ls()?
Here is an ls() function like your pf(). It recursively list files in a subdir.
#include <SdFat.h>
const uint8_t SD_CHIP_SELECT = 10;
SdFat sd;
void ls(char *path) {
SdBaseFile dir;
if (!dir.open(path, O_READ) || !dir.isDir()) {
Serial.println("bad dir");
return;
dir.ls(&Serial, LS_R);
if (!sd.begin(SD_CHIP_SELECT)) sd.errorHalt();
sd.ls(&Serial, LS_R);
Serial.println("Done with root");
ls("DIR0");
Serial.println("Done with DIR0");
void loop() {}
Here is output
A0.TXT
B0.TXT
DIR0/
A1.TXT
B1.TXT
DIR1/
A2.TXT
B2.TXT
Done with root
A1.TXT
B1.TXT
DIR1/
A2.TXT
B2.TXT
Done with DIR0
It's just the beginning. Later i need an other format to communicate with a desktop Tool. At the moment i use the std SD Lib but i miss some functions like trunc and rename. So i try to change to the SdFat cause this has all the needed funcs. (whole project: http://www.rocktagon.de/forum/viewtopic.php?f=24&t=83 (german)).
At the moment i figure out this:
#include <SdFat.h>
SdFat sd;
byte pf(SdBaseFile s) {
SdFile file;
char name[13];
while (1) {
if (!file.openNext(&s, O_READ)) break;
file.close();
if (z) Serial.print('\\');
if (z) {
SdBaseFile n;
uint16_t index = s.curPosition() / 32 - 1;
n.open(&s, index, O_READ);
pf(n);
SdBaseFile s;
s.openRoot(sd.vol());
pf(s);
void loop() {}
Works fine (thanks for your tip) but i searching a way to print the filenames with the wohle Directory path (output like: "\dir\dir\filename").
At last i need this output to a web client: "\dir\dir....\filename "#10#13
Hope your path will not be too deep if you have an Uno. You are using a lot of memory on the stack for each level of recursion.
You will need to maintain the path in a global variable as part of the recursion or maintain a list of pointers to each directory file in a global array.
My final solution (mybe not the best but it works):
#include <SdFat.h>
SdFat sd;
void pf(SdBaseFile s, char subdirs[][13], ArduinoOutStream outp, char dirnr = -1) {
SdFile file;
char name[13]; // 8.3 format
while (1) {
if (!file.openNext(&s, O_READ)) break; // no file - end
file.getFilename(name); // File/directory name
uint32_t fsize = file.fileSize(); // filesize
file.close(); // closing bevore open the next one
if (z) { // add subdir and run new list
memcpy(subdirs[dirnr + 1], name, strlen(name) + 1);
SdBaseFile n; // new basefile for next directory
uint16_t index = s.curPosition() / 32 - 1; //index of current directory
n.open(&s, index, O_READ); // open the directory
pf(n, subdirs, outp, dirnr + 1); // list files/directorys in this dir
else { // print filename
for (byte i = 0; i <= dirnr; i++) // print all subdirectorys
outp << (subdirs[i]) << '\\';
outp << name << ' ' << fsize << "\n";
void printSDroot(ArduinoOutStream cout) {
SdBaseFile s;
char dircount[5][13]; // max 5 subdirs
s.openRoot(sd.vol()); // open root dir
pf(s, dircount, cout);
printSDroot(ArduinoOutStream (Serial)); //Serial,Serial1,Serial2,client .... all who knows print
void loop() {}
p.s.: using 2560 and Due
