I’m new to this so please excuse me if the question was been asked before or is ignorant. I cannot get the correct time with the following
LiquidCrystal lcd(4, 5, 6, 7, 8, 9);
int LDR = 0; //analog pin to which LDR is connected, here we set it to 0 so it means A0
int LDRValue = 0; //that’s a variable to store LDR values
int light_sensitivity = 600; //This is the approx value of light surrounding your LDR
#include <SdFat.h>
#include <SdFatUtil.h> // define FreeRam()
#define SD_CHIP_SELECT SS // SD chip select pin
#define USE_DS1307 1 // set nonzero to use DS1307 RTC
#define LOG_INTERVAL 1000 // mills between entries
#define SENSOR_COUNT 1 // number of analog pins to log
#define ECHO_TO_SERIAL 1 // echo data to serial port if nonzero
#define WAIT_TO_START 0 // Wait for serial input in setup()
#define ADC_DELAY 10 // ADC delay for high impedence sensors
// file system object
SdFat sd;
// text file for logging
ofstream logfile;
// Serial print stream
ArduinoOutStream cout(Serial);
// buffer to format data - makes it eaiser to echo to Serial
char buf[80];
#if SENSOR_COUNT > 6
#error SENSOR_COUNT too large
#endif // SENSOR_COUNT
// store error strings in flash to save RAM
#define error(s) sd.errorHalt_P(PSTR(s))
#if USE_DS1307
// use RTClib from Adafruit
// https://github.com/adafruit/RTClib
// The Arduino IDE has a bug that causes Wire and RTClib to be loaded even
// if USE_DS1307 is false.
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 RTC; // define the Real Time Clock object
// call back for file timestamps
void dateTime(uint16_t* date, uint16_t* time) {
DateTime now = RTC.now();
// return date using FAT_DATE macro to format fields
*date = FAT_DATE(now.year(), now.month(), now.day());
// return time using FAT_TIME macro to format fields
*time = FAT_TIME(now.hour(), now.minute(), now.second());
// format date/time
ostream& operator << (ostream& os, DateTime& dt) {
os << dt.year() << '/' << int(dt.month()) << '/' << int(dt.day()) << ',';
os << int(dt.hour()) << ':' << setfill('0') << setw(2) << int(dt.minute());
os << ':' << setw(2) << int(dt.second()) << setfill(' ');
return os;
#endif // USE_DS1307
{lcd.begin(16,2);
lcd.clear();
lcd.print("LDR");}
pinMode(3, OUTPUT);
while (!Serial){} // wait for Leonardo
// pstr stores strings in flash to save RAM
cout << endl << pstr("FreeRam: ") << FreeRam() << endl;
#if WAIT_TO_START
cout << pstr("Type any character to start\n");
while (Serial.read() <= 0) {}
delay(400); // catch Due reset problem
#endif // WAIT_TO_START
#if USE_DS1307
// connect to RTC
Wire.begin();
if (!RTC.begin()) error("RTC failed");
// set date time callback function
SdFile::dateTimeCallback(dateTime);
cout << now << endl;
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
if (!sd.begin(SD_CHIP_SELECT, SPI_HALF_SPEED)) sd.initErrorHalt();
// create a new file in root, the current working directory
char name[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
name[6] = i/10 + '0';
name[7] = i%10 + '0';
if (sd.exists(name)) continue;
logfile.open(name);
if (!logfile.is_open()) error("file.open");
cout << pstr("Logging to: ") << name << endl;
cout << pstr("Type any character to stop\n\n");
// format header in buffer
obufstream bout(buf, sizeof(buf));
bout << pstr("millis");
#if USE_DS1307
bout << pstr(",date,time");
for (uint8_t i = 0; i < SENSOR_COUNT; i++) {
bout << pstr(",sens") << int(i);
logfile << buf << endl;
#if ECHO_TO_SERIAL
cout << buf << endl;
#endif // ECHO_TO_SERIAL
lcd.clear();
lcd.setCursor(0,0);
lcd.print(analogRead (A0));
LDRValue = analogRead(LDR); //reads the ldr’s value through LDR which we have set to Analog input 0 “A0?
Serial.println(LDRValue); //prints the LDR values to serial monitor
if (LDRValue > light_sensitivity)
digitalWrite(3, HIGH);
delay(180000);
digitalWrite(3, LOW);
delay(1620000);
if (LDRValue < light_sensitivity)
delay(900000);
uint32_t m;
// wait for time to be a multiple of interval
do {
m = millis();
} while (m % LOG_INTERVAL);
// use buffer stream to format line
// start with time in millis
bout << m;
#if USE_DS1307
bout << ',' << now;
// read analog pins and format data
for (uint8_t ia = 0; ia < SENSOR_COUNT; ia++) {
#if ADC_DELAY
analogRead(ia);
delay(ADC_DELAY);
#endif // ADC_DELAY
bout << ',' << analogRead(ia);
bout << endl;
// log data and flush to SD
logfile << buf << flush;
// check for error
if (!logfile) error("write data failed");
#if ECHO_TO_SERIAL
cout << buf;
// don't log two points in the same millis
if (m == millis()) delay(1);
if (!Serial.available()) return;
logfile.close();
cout << pstr("Done!");
while (1);
