Here is the code
//* NESCAT by Nathalis *
//* prototype version: 0.5 (c)2020 *
//* Enhanced version Nintendo Emulator for ESP32 *
//* Requirements: ESP32 WEMOS D1 MINI, SD7789 LCD, MICROSD CARD slot, *
//* PCM5102 I2S AUDIO MODULE, OTHER PARTS... *
//* Only for personal & educational use! *
//* (GPL-3.0 License) *
//* features: *
//* - MicroSD card support *
//* - 240*240 1.3" LCD SD7789 display *
//* - Composite TV OUT Video PAL *
//* - I2S AUDIO support PCM5102 module *
//* - PS2 (USB) KEYBOARD support (wireless not work) *
//* - huge NES ROMs up to 512kB (read from FLASH) *
//* - PS4 DualShock BlueTooth Gamepad (experimental) *
//* to do: *
//* - ESP32-WROVER PSRAM module support *
//* - battery install *
//* - ESP32 MP3-Player support *
#define NES_FOLDER ("/NES/")
#define BLUETOOTH_ENABLED
#define KEYBOARD_ENABLED
#define LCD_ENABLED true
#define SOUND_ENABLED true
#define COMPOSITE_VIDEO_ENABLED
#define DEBUG true //Serial debugging enable.
#define DEBUGEXTRA false //Extra Serial debugging enable.
///!!! do not forget 1KOHM resistors
#define KEYBOARD_DATA 4 /// ---[ 1K ]--- // -D
#define KEYBOARD_CLK 0 /// ---[ 1K ]--- // +D
//COMPOSITE_VIDEO: - //DAC_GPIO25_CHANNEL or DAC_GPIO26_CHANNEL
#define VIDEO_OUT (DAC_GPIO26_CHANNEL)
//micro_SD_Card:
#define SOFTSD_MOSI_PIN 12
#define SOFTSD_MISO_PIN 13
#define SOFTSD_SCK_PIN 14
#define SD_CS_PIN 22
#define PIN_UP 2 //IO2
#define PIN_DOWN 15 //IO2
#define PIN_LEFT 39 //VN
#define PIN_RIGHT 34 //IO34
#define PIN_A 21 //IO21
#define PIN_B 26 //IO26
#define PIN_START 35 //IO36
#define PIN_SELECT 36 //VN
//LCD_ST7789:
#define TFT_CS -1 // define chip select pin
#define TFT_DC 5 // define data/command pin
#define TFT_RST 19
#define TFT_MOSI 23 // Data out (SDA) //better not change
#define TFT_SCLK 18 // Clock out (SCL) //better not change
//AUDIO_i2S:
#define I2S_BCK_IO 27 //BCK
#define I2S_WS_IO 32 //LCK
#define I2S_DO_IO 25 //DIN
#define I2S_DI_IO -1
//MAIN LIBRARIES:
#include <esp_task_wdt.h>
#include "esp_types.h"
#include "esp_heap_caps.h"
#include "esp_attr.h"
#include "esp_intr_alloc.h"
#include "esp_err.h"
#include "soc/gpio_reg.h"
#include "soc/rtc.h"
#include "soc/soc.h"
#include "soc/i2s_struct.h"
#include "soc/i2s_reg.h"
#include "soc/ledc_struct.h"
#include "soc/rtc_io_reg.h"
#include "soc/io_mux_reg.h"
#include "rom/gpio.h"
#include "rom/lldesc.h"
#include "driver/periph_ctrl.h"
#include "driver/dac.h"
#include "driver/gpio.h"
//SPI FLASH MEMORY ACCESS:
#include "esp_spi_flash.h"
#define SPI_FLASH_ADDRESS 0x00300000 //0x00300000 working (empty flash area)
#define SPI_FLASH_SECTOR_SIZE 0x1000 //4kB = better not change
uint32_t FILE_ROM_SIZE = 0;
uint32_t FLASH_ROM_SIZE = 0;
//constant data pointer for direct access
const void *ROM;
spi_flash_mmap_handle_t handle1;
uint8_t flashdata[4096] = {0}; //4kB buffer
//DRAM MEMORY ACCESS:
char* ROMFILENAME; //NES load File name
unsigned char *rom = 0; //Actual ROM pointer
//Allocated MEMORY variables:
uint8_t* SCREENMEMORY[256]; //256*256 bytes
uint16_t SCREENBUFFER[256]; //512 bytes
//PALETTES:
const uint32_t nes_32bit[64] = { //4colors Green-Yellow-Red-Blue
0x2D253469, 0x000000D9, 0x000000A1, 0x0F111CA1, 0x001F3F70, 0x0024491C, 0x06264900, 0x061F3B00,
0x12162300, 0x2D0B0000, 0x27090000, 0x21080000, 0x1806004D, 0x14141414, 0x14141414, 0x14141414,
0x453950A1, 0x2D0B00D9, 0x210800D9, 0x181C2DD9, 0x002F5EAF, 0x0031624D, 0x153B6C00, 0x2139620E,
0x2D304900, 0x45110000, 0x3F0F0000, 0x3F0F0038, 0x330C0077, 0x14141414, 0x14141414, 0x14141414,
0x5D4D6CD9, 0x451D18D9, 0x33232DD9, 0x2D2C42D9, 0x2D416CD9, 0x213E6C85, 0x2D416C4D, 0x3C456C38,
0x45476C00, 0x5D3F5015, 0x51272646, 0x5D2A2685, 0x571500BD, 0x2D253469, 0x14141414, 0x14141414,
0x5D4D6CD9, 0x543846D9, 0x453950D9, 0x45405ED9, 0x45476CD9, 0x3C456CA8, 0x4E48699A, 0x544B6C93,
0x514A6C69, 0x5D465E69, 0x5D3F50A1, 0x5D3F50BD, 0x5D1700D9, 0x514A6CD9, 0x14141414, 0x14141414,
const uint16_t nes_16bit[64] = {
0x7BEF, 0x001F, 0x0017, 0x4157, 0x9010, 0xA804, 0xA880, 0x88A0,
0x5180, 0x03C0, 0x0340, 0x02C0, 0x020B, 0x0000, 0x0000, 0x0000,
0xBDF7, 0x03DF, 0x02DF, 0x6A3F, 0xD819, 0xE00B, 0xF9C0, 0xE2E2,
0xABE0, 0x05C0, 0x0540, 0x0548, 0x0451, 0x0000, 0x0000, 0x0000,
0xFFDF, 0x3DFF, 0x6C5F, 0x9BDF, 0xFBDF, 0xFAD3, 0xFBCB, 0xFD08,
0xFDC0, 0xBFC3, 0x5ECA, 0x5FD3, 0x075B, 0x7BCF, 0x0000, 0x0000,
0xFFFF, 0xA73F, 0xBDDF, 0xDDDF, 0xFDDF, 0xFD38, 0xF696, 0xFF15,
0xFECF, 0xDFCF, 0xBFD7, 0xBFDB, 0x07FF, 0xFEDF, 0x0000, 0x0000,
//#ifdef BLUETOOTH_ENABLED
//Bluetooth_PS4_DualShock_support_for_ESP32:
//#include "P:\1a Youtube videos tercero/ESP32 Nintendo/NesCat-main/src/hid_server/hid_server.h"
//#endif
//COMPOSITE_VIDEO_OUT
#ifdef COMPOSITE_VIDEO_ENABLED
#include "C:\Users\touwh\OneDrive\Documents\Year 3\Projects\NesCat-main\src\compositevideo\video.h"
#endif
//LIBRARIES:
//LCD_ST7789:
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
//micro_SD_Card:
#include <SdFat.h>
//#define ENABLE_SOFTWARE_SPI_CLASS 1 // Must be set in SdFat/SdFatConfig.h !!!
//AUDIO_i2S:
#ifdef SOUND_ENABLED
#include "driver/i2s.h"
#endif
//CONFIGS:
//LCD_ST7789
#define ST7789_DRIVER // Configure all registers
#define TFT_WIDTH 240
#define TFT_HEIGHT 240
#define LOAD_GLCD // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2 // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4 // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
//micro_SD_Card
const uint8_t SOFT_MOSI_PIN = SOFTSD_MOSI_PIN;
const uint8_t SOFT_MISO_PIN = SOFTSD_MISO_PIN;
const uint8_t SOFT_SCK_PIN = SOFTSD_SCK_PIN;
SdFatSoftSpi<SOFT_MISO_PIN, SOFT_MOSI_PIN, SOFT_SCK_PIN> SD;
File fp;
SdFile dirFile; //for root directory file listing
SdFile file;
///TYPEDEFS:
// Define this if running on little-endian (x86) systems
#define HOST_LITTLE_ENDIAN //!!! important for Arduino
#define ZERO_LENGTH 0
// quell stupid compiler warnings
#define UNUSED(x) ((x) = (x))
// 16Bit Color set
#define BLACK 0x0000
#define RED 0xF800
#define GREEN 0x07E0
#define BLUE 0x102E
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
//AUDIO_SETUP
#define DEFAULT_SAMPLERATE 24000
#define DEFAULT_FRAGSIZE 60 //max.256, default 240
//VIDEO_SETUP
// Visible (NTSC) screen height
#ifndef NES_VISIBLE_HEIGHT
#define NES_VISIBLE_HEIGHT 240
#endif // !NES_VISIBLE_HEIGHT
#define NES_SCREEN_WIDTH 256
#define NES_SCREEN_HEIGHT 240
#define PAL
// NTSC = 60Hz, PAL = 50Hz
#ifdef PAL
#define NES_REFRESH_RATE 50
#else
#define NES_REFRESH_RATE 60
#endif
#define MAX_MEM_HANDLERS 32
#define DEFAULT_WIDTH NES_SCREEN_WIDTH
#define DEFAULT_HEIGHT NES_VISIBLE_HEIGHT
#define NES_CLOCK_DIVIDER 12 //default: 12
//#define NES_MASTER_CLOCK 21477272.727272727272
#define NES_MASTER_CLOCK (236250000 / 11)
#define NES_SCANLINE_CYCLES (1364.0 / NES_CLOCK_DIVIDER)
#define NES_FIQ_PERIOD (NES_MASTER_CLOCK / NES_CLOCK_DIVIDER / 60)
#define NES_RAMSIZE 0x800
#define NES6502_NUMBANKS 16
#define NES6502_BANKSHIFT 12
#define NES6502_BANKSIZE (0x10000 / NES6502_NUMBANKS)
#define NES6502_BANKMASK (NES6502_BANKSIZE - 1)
uint8_t NES_POWER = 1;
QueueHandle_t vidQueue;
uint8_t JOY_UP = 0;
uint8_t JOY_DOWN = 0;
uint8_t JOY_LEFT = 0;
uint8_t JOY_RIGHT = 0;
uint8_t JOY_CROSS = 0;
uint8_t JOY_SQUARE = 0;
uint8_t JOY_CIRCLE = 0;
uint8_t JOY_TRIANGLE = 0;
uint8_t JOY_SHARE = 0; //(START)
uint8_t JOY_OPTIONS = 0; //(SELECT)
uint8_t scancode = 0;
boolean keyup = false;
byte keymap[256];
IRAM_ATTR void USB_KEYBOARD() {
#ifdef KEYBOARD_ENABLED
if (keymap[0x75] == 0) {
JOY_UP = 1;
else JOY_UP = 0;
if (keymap[0x72] == 0) {
JOY_DOWN = 1;
else JOY_DOWN = 0;
if (keymap[0x6B] == 0) {
JOY_LEFT = 1;
else JOY_LEFT = 0;
if (keymap[0x74] == 0) {
JOY_RIGHT = 1;
else JOY_RIGHT = 0;
if (keymap[0x11] == 0 || keymap[0x1A] == 0) JOY_CROSS = 1; //ALT or X
else JOY_CROSS = 0;
if (keymap[0x14] == 0 || keymap[0x22] == 0) JOY_SQUARE = 1; //CTRL or Z
else JOY_SQUARE = 0;
if (keymap[0x5A] == 0) JOY_SHARE = 1;
else JOY_SHARE = 0;
if (keymap[0x66] == 0) JOY_OPTIONS = 1;
else JOY_OPTIONS = 0;
if (keymap[0x76] == 0) {
JOY_SHARE = 1;
JOY_OPTIONS = 1;
} else if (JOY_SHARE == 1 && JOY_OPTIONS == 1 ) {
JOY_SHARE = 0;
JOY_OPTIONS = 0;
if (DEBUGEXTRA) {
if (JOY_UP) Serial.print("UP.");
if (JOY_DOWN) Serial.print("DOWN.");
if (JOY_LEFT) Serial.print("LEFT.");
if (JOY_RIGHT) Serial.print("RIGHT.");
if (JOY_SHARE) Serial.print("START.");
if (JOY_OPTIONS) Serial.print("SELECT.");
if (JOY_CROSS) Serial.print("A.");
if (JOY_SQUARE) Serial.print("B.");
#endif
void IRAM_ATTR kb_interruptHandler(void) {
static uint8_t bitcount = 0;
uint8_t val;
int clock = digitalRead(KEYBOARD_CLK);
if (clock == 0) {
return;
val = digitalRead(KEYBOARD_DATA);
if (DEBUGEXTRA) Serial.print(".");
if (DEBUGEXTRA) Serial.print(val);
bitcount++;
if (bitcount > 1 && bitcount < 10) { //8bits
scancode |= ((val & 1) << (bitcount - 2));
if (bitcount > 10) {
if (keyup == true) {
keymap[scancode] = 1;
if (DEBUGEXTRA) {
Serial.print(" {");
Serial.print(scancode, HEX);
Serial.print("} ");
keyup = false;
keymap[scancode] = 0;
if (scancode == 0xF0 ) {
keyup = true;
keyup = false;
if (DEBUGEXTRA) {
Serial.print("[");
Serial.println("]");
USB_KEYBOARD();
bitcount = 0;
scancode = 0;
#endif
void kb_begin() {
pinMode(KEYBOARD_DATA, INPUT_PULLUP);
pinMode(KEYBOARD_CLK, INPUT_PULLUP);
digitalWrite(KEYBOARD_DATA, true);
digitalWrite(KEYBOARD_CLK, true);
attachInterrupt(digitalPinToInterrupt(KEYBOARD_CLK), kb_interruptHandler, RISING);
memset(keymap, 1, sizeof(keymap));
#endif
uint8_t buf[64] = {0}; //JoyRead buffer...
int num_get = 0;
IRAM_ATTR static void PS4_JOY() {
// update the bluetooth edr/hid stack
///hid_update();
//read data from JoyStick
//num_get = hid_get(buf, sizeof(buf) - 1); // called from emulation loop
if ((num_get != -1) && buf[0] == 161) { // If connected then read JoyStick
uint8_t JOYBUTTON = buf[6];
uint8_t JOYBUTTON2 = buf[7];
///Serial.println(JOYBUTTON);
if ( JOYBUTTON % 8 == 0) {
JOY_UP = 1;
else if ( JOYBUTTON % 8 == 1) {
JOY_UP = 1;
JOY_RIGHT = 1;
JOY_DOWN = 0;
JOY_LEFT = 0;
else if ( JOYBUTTON % 8 == 2) {
JOY_RIGHT = 1;
JOY_DOWN = 0;
JOY_LEFT = 0;
JOY_UP = 0;
else if ( JOYBUTTON % 8 == 3) {
JOY_RIGHT = 1;
JOY_DOWN = 1;
JOY_LEFT = 0;
JOY_UP = 0;
else if ( JOYBUTTON % 8 == 4) {
JOY_DOWN = 1;
JOY_LEFT = 0;
JOY_RIGHT = 0;
JOY_UP = 0;
else if ( JOYBUTTON % 8 == 5) {
JOY_DOWN = 1;
JOY_LEFT = 1;
JOY_RIGHT = 0;
JOY_UP = 0;
else if ( JOYBUTTON % 8 == 6) {
JOY_LEFT = 1;
JOY_UP = 0;
JOY_DOWN = 0;
JOY_RIGHT = 0;
else if ( JOYBUTTON % 8 == 7) {
JOY_LEFT = 1;
JOY_UP = 1;
JOY_DOWN = 0;
JOY_RIGHT = 0;
if (((JOYBUTTON >> 3) & 1) != 0) {
JOY_UP = 0;
JOY_DOWN = 0;
JOY_LEFT = 0;
JOY_RIGHT = 0;
if ( JOYBUTTON > 8 && ((JOYBUTTON >> 4) & 1) != 0) {
JOY_SQUARE = 1;
else if (((JOYBUTTON >> 4) & 1) == 0) {
JOY_SQUARE = 0;
if ( JOYBUTTON > 8 && ((JOYBUTTON >> 4) & 2) != 0) {
JOY_CROSS = 1;
else if (((JOYBUTTON >> 4) & 2) == 0) {
JOY_CROSS = 0;
if ( JOYBUTTON > 8 && ((JOYBUTTON >> 4) & 4) != 0) {
JOY_CIRCLE = 1;
else if (((JOYBUTTON >> 4) & 4) == 0) {
JOY_CIRCLE = 0;
if ( JOYBUTTON > 8 && ((JOYBUTTON >> 4) & 8) != 0) {
JOY_TRIANGLE = 1;
else if (((JOYBUTTON >> 8) & 1) == 0) {
JOY_TRIANGLE = 0;
if (JOYBUTTON2 == 0) {
JOY_SHARE = 0;
JOY_OPTIONS = 0;
if ( JOYBUTTON2 > 8 && ((JOYBUTTON2 >> 4) & 1) != 0) {
JOY_SHARE = 1;
if ( JOYBUTTON2 > 8 && ((JOYBUTTON2 >> 4) & 2) != 0) {
JOY_OPTIONS = 1;
if (DEBUGEXTRA) {
#endif
/* read counters */
int pad0_readcount, pad1_readcount, ppad_readcount, ark_readcount;
void input_strobe(void) {
pad0_readcount = 0;
pad1_readcount = 0;
ppad_readcount = 0;
ark_readcount = 0;
uint8_t get_pad0(void) {
uint8_t value;
/// value = (uint8_t) retrieve_type(INP_JOYPAD0);
value = 0;
// 12, 33, 9, 10pin not usable
if (digitalRead(PIN_A) == 1) value |= 1; //A
if (digitalRead(PIN_B) == 1) value |= 2; //B
if (digitalRead(PIN_SELECT) == 1) value |= 4; //SELECT
if (digitalRead(PIN_START) == 1) value |= 8; //START
if (digitalRead(PIN_UP) == 1) value |= 16; //UP
if (digitalRead(PIN_DOWN) == 1) value |= 32; //DOWN
if (digitalRead(PIN_LEFT) == 1) value |= 64; //LEFT
if (digitalRead(PIN_RIGHT) == 1) value |= 128; //RIGHT
if (digitalRead(PIN_SELECT) == 1 && digitalRead(PIN_START) == 1) NES_POWER = 0; //EXIT
//EJECT EMULATOR
if (JOY_SHARE == 1 && JOY_OPTIONS == 1) {
JOY_SHARE = 0;
JOY_OPTIONS = 0;
NES_POWER = 0;
if (JOY_SHARE == 1) value |= 8; //START
if (JOY_OPTIONS == 1) value |= 4; //SELECT
if (JOY_UP == 1) value |= 16; //UP
if (JOY_DOWN == 1) value |= 32; //DOWN
if (JOY_LEFT == 1) value |= 64; //LEFT
if (JOY_RIGHT == 1) value |= 128; //RIGHT
if (JOY_CROSS == 1) value |= 1; //A
if (JOY_SQUARE == 1) value |= 2; //B
/// if (JOY_CIRCLE==1) Serial.println("JOY_CIRCLE");
/// if (JOY_TRIANGLE==1) Serial.println("JOY_TRIANGLE");
// mask out left/right simultaneous keypresses
if ((value & JOY_UP) && (value & JOY_DOWN)) value &= ~(JOY_UP | JOY_DOWN);
if ((value & JOY_LEFT) && (value & JOY_RIGHT)) value &= ~(JOY_LEFT | JOY_RIGHT);
// return (0x40 | value) due to bus conflicts
///return (0x40 | ((value >> pad0_readcount++) & 1));
return (((value >> pad0_readcount++) & 1));
//BUFFER TEXT DRAW FUNCTIONS
#include "C:\Users\touwh\OneDrive\Documents\Year 3\Projects\NesCat-main\Libraries\Fonts\Retro8x16.c" //used font...
void screenmemory_fillscreen(uint8_t COLOR) {
for (uint16_t Ypos = 0; Ypos < DEFAULT_HEIGHT; Ypos++)
for (uint16_t Xpos = 0; Xpos < DEFAULT_WIDTH; Xpos++) {
SCREENMEMORY[Ypos][Xpos] = COLOR;
if (LCD_ENABLED) xQueueSend(vidQueue, &SCREENMEMORY, 0); //refresh LCD
void screenmemory_drawpixel(uint16_t X, uint16_t Y, uint8_t COLOR) {
if (Y < DEFAULT_HEIGHT && X < DEFAULT_WIDTH) SCREENMEMORY[Y][X] = COLOR;
void screenmemory_drawfillrectangle(uint16_t X, uint16_t Y, uint16_t Width, uint16_t Height, uint8_t COLOR) {
for (uint16_t Ypos = Y; Ypos < Y + Height; Ypos++)
for (uint16_t Xpos = X; Xpos < X + Width; Xpos++) {
screenmemory_drawpixel(Xpos, Ypos, COLOR);
uint8_t draw_char_xy(uint16_t Main_x, uint16_t Main_y, char Main_char, const char* font) {
uint8_t XcharSize = font[0]; //x char size
uint8_t YcharSize = font[1]; //y char size
uint8_t CHAROFFSET = font[2]; //char start offset
font[3]; //char count
if (Main_char != '\n' && Main_char != '\r') for (uint16_t Ypos = 0; Ypos < YcharSize; Ypos++)
for (uint16_t Xpos = 0; Xpos < XcharSize; Xpos += 8) {
uint8_t CHARLINE = font[(Main_char - CHAROFFSET) * (YcharSize * (XcharSize / 8)) + (Ypos) * (XcharSize / 8) + Xpos / 8 + 4];
if ((Xpos + 0 < XcharSize) && (CHARLINE & 0b10000000) != 0) screenmemory_drawpixel(Main_x + Xpos + 0, Main_y + Ypos, 48);
else screenmemory_drawpixel(Main_x + Xpos + 0, Main_y + Ypos, 63);
if ((Xpos + 1 < XcharSize) && (CHARLINE & 0b01000000) != 0) screenmemory_drawpixel(Main_x + Xpos + 1, Main_y + Ypos, 48);
else screenmemory_drawpixel(Main_x + Xpos + 1, Main_y + Ypos, 63);
if ((Xpos + 2 < XcharSize) && (CHARLINE & 0b00100000) != 0) screenmemory_drawpixel(Main_x + Xpos + 2, Main_y + Ypos, 48);
else screenmemory_drawpixel(Main_x + Xpos + 2, Main_y + Ypos, 63);
if ((Xpos + 3 < XcharSize) && (CHARLINE & 0b00010000) != 0) screenmemory_drawpixel(Main_x + Xpos + 3, Main_y + Ypos, 48);
else screenmemory_drawpixel(Main_x + Xpos + 3, Main_y + Ypos, 63);
if ((Xpos + 4 < XcharSize) && (CHARLINE & 0b00001000) != 0) screenmemory_drawpixel(Main_x + Xpos + 4, Main_y + Ypos, 48);
else screenmemory_drawpixel(Main_x + Xpos + 4, Main_y + Ypos, 63);
if ((Xpos + 5 < XcharSize) && (CHARLINE & 0b00000100) != 0) screenmemory_drawpixel(Main_x + Xpos + 5, Main_y + Ypos, 48);
else screenmemory_drawpixel(Main_x + Xpos + 5, Main_y + Ypos, 63);
if ((Xpos + 6 < XcharSize) && (CHARLINE & 0b00000010) != 0) screenmemory_drawpixel(Main_x + Xpos + 6, Main_y + Ypos, 48);
else screenmemory_drawpixel(Main_x + Xpos + 6, Main_y + Ypos, 63);
if ((Xpos + 7 < XcharSize) && (CHARLINE & 0b00000001) != 0) screenmemory_drawpixel(Main_x + Xpos + 7, Main_y + Ypos, 48);
else screenmemory_drawpixel(Main_x + Xpos + 7, Main_y + Ypos, 63);
return XcharSize;
uint16_t draw_string_xy(uint16_t x, uint16_t y, char *c, const char* font)
uint8_t width;
uint16_t textwidth = 0;
while (*c) {
width = draw_char_xy(x, y, *c, font);
textwidth += (width);
x += (width);
c++;
return textwidth;
const char* DisplayFontSet = NULL;
uint16_t XPOS_CHAR = 0;
uint16_t YPOS_CHAR = 0;
void set_font(const char* font) {
DisplayFontSet = font;
void set_font_XY(uint16_t x, uint16_t y) {
XPOS_CHAR = x;
YPOS_CHAR = y;
void draw_string(char *c) {
if (c[strlen(c) - 1] == '\n') {
draw_string_xy(XPOS_CHAR, YPOS_CHAR, c, DisplayFontSet);
YPOS_CHAR += (uint8_t)(DisplayFontSet[1]);
XPOS_CHAR = 0;
XPOS_CHAR += draw_string_xy(XPOS_CHAR, YPOS_CHAR, c, DisplayFontSet);
void (*audio_callback)(void *buffer, int length) = NULL;
TimerHandle_t timer_1;
//Seemingly, this will be called only once. Should call func with a freq of frequency,
IRAM_ATTR int osd_installtimer_1(int frequency, void *func, int funcsize, void *counter, int countersize)
if (DEBUG) Serial.print("Timer install, freq=");
if (DEBUG) Serial.println(frequency);
timer_1 = xTimerCreate("nes_hid", configTICK_RATE_HZ / frequency, pdTRUE, NULL, (TimerCallbackFunction_t)func);
xTimerStart(timer_1, 0);
return 0;
// HID timer ISR
volatile int time_ticks = 0;
IRAM_ATTR static void timer_isr(void)
/*#ifdef BLUETOOTH_ENABLED
/// hid_update();
///PS4_JOY();
#endif*/ //this causes crashing
if (audio_callback && NES_POWER == 1) do_audio_frame();
time_ticks++;
IRAM_ATTR static void timer_isr_end(void) {}
IRAM_ATTR int install_timer(int hertz) {
return osd_installtimer_1(hertz, (void *) timer_isr, (int) timer_isr_end - (int) timer_isr, (void *) &time_ticks, sizeof(time_ticks));
IRAM_ATTR void MEMORY_STATUS() {
if (DEBUG) {
Serial.println("--------------------------------");
Serial.print("TOTAL HEAP: ");
Serial.println(ESP.getHeapSize());
Serial.print("FREE HEAP: ");
Serial.println(ESP.getFreeHeap());
Serial.print("heap_caps_get_free_size: ");
Serial.println(heap_caps_get_free_size(MALLOC_CAP_8BIT));
//AUDIO SETUP
typedef struct sndinfo_s
int sample_rate;
int bps;
} sndinfo_t;
intr_handle_t i2s_interrupt;
i2s_pin_config_t pin_config = {
.bck_io_num = I2S_BCK_IO,
.ws_io_num = I2S_WS_IO,
.data_out_num = I2S_DO_IO,
.data_in_num = I2S_DI_IO //Not used
i2s_config_t audio_cfg = {
.mode = static_cast<i2s_mode_t>(I2S_MODE_MASTER | I2S_MODE_TX /*| I2S_MODE_DAC_BUILT_IN*/),
.sample_rate = DEFAULT_SAMPLERATE,
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
///.channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = static_cast<i2s_comm_format_t>(I2S_COMM_FORMAT_PCM | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1 /*| ESP_INTR_FLAG_IRAM /* | ESP_INTR_FLAG_SHARED*/, ///(DO NOT USE: ESP_INTR_FLAG_IRAM = BLUETOOTH PROBLEM)
.dma_buf_count = 6,
// .dma_buf_len = 2 * DEFAULT_FRAGSIZE,
.dma_buf_len = 4 * DEFAULT_FRAGSIZE,
.use_apll = false
#endif
int init_sound(void)
i2s_driver_install(I2S_NUM_1, &audio_cfg, 0, NULL);
i2s_set_pin(I2S_NUM_1, &pin_config);
#endif
audio_callback = NULL;
return 0;
void osd_setsound(void (*playfunc)(void *buffer, int length))
//Indicates we should call playfunc() to get more data.
audio_callback = playfunc;
void osd_stopsound(void)
void osd_getsoundinfo(sndinfo_t *info);
info->sample_rate = DEFAULT_SAMPLERATE;
info->bps = 16;
#if SOUND_ENABLED
QueueHandle_t queue;
// uint16_t audio_frame[DEFAULT_FRAGSIZE];
uint16_t audio_frame[2 * DEFAULT_FRAGSIZE];
#endif
void do_audio_frame()
///printf("do_audio_frame\n");
#if SOUND_ENABLED
int left = DEFAULT_SAMPLERATE / NES_REFRESH_RATE;
while (left)
int n = DEFAULT_FRAGSIZE;
if (n > left)
n = left;
audio_callback(audio_frame, n); //get more data
//16 bit mono -> 32-bit (16 bit r+l)
for (int i = n - 1; i >= 0; i--)
// audio_frame[i] = audio_frame[i] + 0x8000;
/// uint16_t a = (audio_frame[i] >> 3); //VEEERY BAD!
uint16_t a = (audio_frame[i] >> 0);
audio_frame[i * 2 + 1] = 0x8000 + a;
audio_frame[i * 2] = 0x8000 - a;
///Serial.print(audio_frame[i]);
size_t i2s_bytes_write;
// i2s_write(I2S_NUM_0, (const char *)audio_frame, 2 * n, &i2s_bytes_write, portMAX_DELAY);
// left -= i2s_bytes_write / 2;
i2s_write(I2S_NUM_1, (const char *)audio_frame, 4 * n, &i2s_bytes_write, portMAX_DELAY);
left -= i2s_bytes_write / 4;
#endif
static void lcd_write_frame(const uint16_t x, const uint16_t y, const uint16_t width, const uint16_t height)
uint8_t n, l;
uint16_t i, len;
uint16_t w = TFT_WIDTH;
uint16_t h = TFT_HEIGHT;
uint16_t X_ = 0;
for (i = 0; i < height; i++) {
uint16_t horizontal_offset = 8;
for (X_ = 0; X_ < 256; X_++) {
SCREENBUFFER[X_] = nes_16bit[(0x3F & ((uint8_t *)SCREENMEMORY[i])[X_])];
///PAL optimalisation in this case:
tft.drawRGBBitmap(0, i, (uint16_t *)(SCREENBUFFER), 48, 1);
tft.drawRGBBitmap(48, i, (uint16_t *)(SCREENBUFFER + 48), 48, 1);
tft.drawRGBBitmap(96, i, (uint16_t *)(SCREENBUFFER + 96), 48, 1);
tft.drawRGBBitmap(144, i, (uint16_t *)(SCREENBUFFER + 144), 48, 1);
tft.drawRGBBitmap(192, i, (uint16_t *)(SCREENBUFFER + 192), 48, 1);
///QueueHandle_t vidQueue;
static void videoTask(void *arg)
int x = (320 - DEFAULT_WIDTH) / 2;
int y = ((240 - DEFAULT_HEIGHT) / 2);
while (1)
xQueueReceive(vidQueue, &SCREENMEMORY, portMAX_DELAY);
lcd_write_frame(x, y, DEFAULT_WIDTH, DEFAULT_HEIGHT);
///delay(1); //1ms (prevent crash???)
int audiovideo_init() ///osd_init()
// disable Core 0 WDT
TaskHandle_t idle_0 = xTaskGetIdleTaskHandleForCPU(0);
esp_task_wdt_delete(idle_0);
init_sound(); //START AUDIO
vidQueue = xQueueCreate( 1, sizeof( unsigned int* ));
///lcd_write_frame(0, 0, 320, 240);
xTaskCreatePinnedToCore(&videoTask, "videoTask", 3072, NULL, 0, NULL, 0);
if (DEBUG) Serial.println("videoTask Pinned To Core 0...");
return 0;
#define MAXFILES 256
#define MAXFILENAME_LENGTH 255
void sortStrings(char arr[][MAXFILENAME_LENGTH], int n)
char temp[MAXFILENAME_LENGTH];
// Sorting strings using bubble sort
for (int j = 0; j < n - 1; j++)
for (int i = j + 1; i < n; i++)
if (strcmp(arr[j], arr[i]) > 0)
strcpy(temp, arr[j]);
strcpy(arr[j], arr[i]);
strcpy(arr[i], temp);
// Max of ten files since files are selected with a single digit.
const uint16_t nMaxfiles = MAXFILES; //max. 256 NES roms
char filename[nMaxfiles][MAXFILENAME_LENGTH] = {0};
char fileext[nMaxfiles][4] = {0};
char* NESMENU() {
uint8_t num = 0;
uint8_t loadedFileNames = 0;
screenmemory_fillscreen(63); //black color
set_font_XY(0, 10);
//LOAD FILENAMES INTO MEMORY...
num = 0;
//Load List files in root directory.
///if (!dirFile.open("/", O_READ)) {
if (!dirFile.open(NES_FOLDER, O_READ)) {
SD.errorHalt("open root failed");
while (1) {};
while (num < nMaxfiles && file.openNext(&dirFile, O_READ)) {
// Skip directories and hidden files.
if (!file.isSubDir() && !file.isHidden()) {
for (uint8_t i = sizeof(filename[num]); i > 3; i--) filename[num][i] = 0;
file.getName(filename[num], MAXFILENAME_LENGTH);
for (uint8_t i = sizeof(filename[num]); i > 3; i--) {
if (filename[num][i] != 0) {
fileext[num][3] = '\0';
fileext[num][2] = filename[num][i];
fileext[num][1] = filename[num][i - 1];
fileext[num][0] = filename[num][i - 2];
//check NES File extension, then increase index
if ((fileext[num][0] == 'N' || fileext[num][0] == 'n')
&& (fileext[num][1] == 'E' || fileext[num][1] == 'e')
&& (fileext[num][2] == 'S' || fileext[num][2] == 's')) {
num++;
loadedFileNames = num;
file.close();
if (DEBUG) {
Serial.print("Count of loaded File Names:");
Serial.println(loadedFileNames);
///int n = sizeof(filename)/sizeof(filename[0]);
sortStrings(filename, loadedFileNames);
//DRAW FILENAMES INTO BUFFER
uint8_t CURSOR = 0;
uint8_t PAGE = 0;
#define FILESPERPAGE 8
bool NamesDisplayed = false;
while (1) {
//hid_update();
PS4_JOY();
PAGE = CURSOR / FILESPERPAGE;
if (!NamesDisplayed) {
for (num = PAGE * FILESPERPAGE; num < ((PAGE + 1)*FILESPERPAGE) && num < loadedFileNames; num++) {
set_font_XY(40, 48 + 20 * (num % FILESPERPAGE));
draw_string(filename[num]);
delay(1);
NamesDisplayed = true;
//PROCESS CURSOR SELECTION
if (digitalRead(PIN_A) == 1) {
JOY_CROSS = 1; //A
delay(200);
if (digitalRead(PIN_B) == 1) {
JOY_SQUARE = 1; //B
delay(200);
if (digitalRead(PIN_SELECT) == 1) {
JOY_OPTIONS = 1; //SELECT
delay(200);
if (digitalRead(PIN_START) == 1) {
JOY_SHARE = 1; //START
delay(200);
if (digitalRead(PIN_UP) == 1) {
JOY_UP = 1;
delay(200);
if (digitalRead(PIN_DOWN) == 1) {
JOY_DOWN = 1; //DOWN
delay(200);
if (digitalRead(PIN_LEFT) == 1) {
JOY_LEFT = 1; //LEFT
delay(200);
if (digitalRead(PIN_RIGHT) == 1) {
JOY_RIGHT = 1; //RIGHT
delay(200);
//Empty Cursor
set_font_XY(16, 48 + (20 * (CURSOR % FILESPERPAGE)));
draw_string(" ");
if (JOY_UP == 1 ) {
if (CURSOR % FILESPERPAGE == 0) NamesDisplayed = false; //changed page
if (CURSOR == 0 && loadedFileNames > 0) CURSOR = loadedFileNames - 1;
else if (CURSOR > 0 && loadedFileNames > 0) CURSOR--;
JOY_UP = 0;
if (JOY_DOWN == 1 ) {
if (CURSOR % FILESPERPAGE == FILESPERPAGE - 1 || CURSOR == loadedFileNames - 1) NamesDisplayed = false; //changed page
if (CURSOR == loadedFileNames - 1 && loadedFileNames > 0) CURSOR = 0;
else if (CURSOR < loadedFileNames - 1 && loadedFileNames > 0) CURSOR++;
JOY_DOWN = 0;
if (JOY_LEFT == 1) {
if (CURSOR > FILESPERPAGE - 1) CURSOR -= FILESPERPAGE;
JOY_LEFT = 0;
if (JOY_RIGHT == 1) {
if (CURSOR / FILESPERPAGE < loadedFileNames / FILESPERPAGE) CURSOR += FILESPERPAGE;
if (CURSOR > loadedFileNames - 1) CURSOR = loadedFileNames - 1;
JOY_RIGHT = 0;
if ((JOY_CROSS == 1 || JOY_SHARE == 1) && JOY_OPTIONS == 0) {
dirFile.close();
JOY_CROSS = 0;
JOY_SHARE = 0;
JOY_OPTIONS = 0;
return filename[CURSOR] ; //START //A
//Draw Cursor
draw_string("->");
delay(25);
char loadmessage[64];
unsigned char *getromdata(char* ROMFILENAME_)
char namebuffer[256];
strncpy(namebuffer, NES_FOLDER, sizeof(namebuffer));
strncat(namebuffer, ROMFILENAME_, sizeof(namebuffer));
fp = SD.open(namebuffer);
if (DEBUG) Serial.print("FILE SIZE: ");
if (DEBUG) Serial.println(fp.size());
FILE_ROM_SIZE = fp.size();
uint16_t BLOCKCOUNT = (FILE_ROM_SIZE + SPI_FLASH_SECTOR_SIZE) / SPI_FLASH_SECTOR_SIZE;
uint16_t BLOCKSIZEPX = DEFAULT_WIDTH / BLOCKCOUNT;
Serial.print("BLOCKCOUNT: ");
Serial.print(BLOCKCOUNT);
Serial.print(" BLOCKSIZEPX: ");
Serial.print(BLOCKSIZEPX);
BLOCKSIZEPX++;
// Read NES rom to SPI FLASH!
uint32_t i = 0;
for (i = 0; i < fp.size() + SPI_FLASH_SECTOR_SIZE; i++) {
if (DEBUGEXTRA && i % SPI_FLASH_SECTOR_SIZE == 0) {
Serial.print("ROM loaded 4kB:");
Serial.println(i / 0x1000);
if (i > 0 && i % SPI_FLASH_SECTOR_SIZE == 0) {
///spi_flash_erase_sector(SPI_FLASH_ADDRESS/SPI_FLASH_SECTOR_SIZE + (i/SPI_FLASH_SECTOR_SIZE)-SPI_FLASH_SECTOR_SIZE);
delayMicroseconds(300);
spi_flash_erase_range(SPI_FLASH_ADDRESS + i - SPI_FLASH_SECTOR_SIZE, sizeof(flashdata));
spi_flash_write(SPI_FLASH_ADDRESS + i - SPI_FLASH_SECTOR_SIZE, flashdata, sizeof(flashdata));
sprintf(loadmessage, " %d / %d", i, FILE_ROM_SIZE);
set_font_XY(8, 8);
draw_string("Loaded:");
draw_string(loadmessage);
screenmemory_drawfillrectangle(((i / SPI_FLASH_SECTOR_SIZE) - 1)* BLOCKSIZEPX, 24, BLOCKSIZEPX, 16, 57);
delayMicroseconds(50);
if (fp.available()) flashdata[i % SPI_FLASH_SECTOR_SIZE] = fp.read();
fp.close();
FLASH_ROM_SIZE = i; //Size of File and Offset Align
if (DEBUG) Serial.print("FLASH SIZE: ");
if (DEBUG) Serial.println(FLASH_ROM_SIZE);
ROM = 0;
///if (handle1) spi_flash_munmap(handle1);
printf("Mapping %x (+%x)\n", SPI_FLASH_ADDRESS, FLASH_ROM_SIZE);
ESP_ERROR_CHECK( spi_flash_mmap(SPI_FLASH_ADDRESS, FLASH_ROM_SIZE, SPI_FLASH_MMAP_DATA, &ROM, &handle1) );
printf("mmap_res: handle=%d ptr=%p\n", handle1, ROM);
Serial.println("[NES ROM MAPPED ON FLASH!]");
return (unsigned char *)ROM;
// EMULATOR CORE HEADERS:
//CPU.H:
// Define this to enable decimal mode in ADC / SBC (not needed in NES)
//#define NES6502_DECIMAL
// P (flag) register bitmasks
#define N_FLAG 0x80
#define V_FLAG 0x40
#define R_FLAG 0x20 // Reserved, always 1
#define B_FLAG 0x10
#define D_FLAG 0x08
#define I_FLAG 0x04
#define Z_FLAG 0x02
#define C_FLAG 0x01
// Vector addresses
#define NMI_VECTOR 0xFFFA
#define RESET_VECTOR 0xFFFC
#define IRQ_VECTOR 0xFFFE
// cycle counts for interrupts
#define INT_CYCLES 7
#define RESET_CYCLES 6
#define NMI_MASK 0x01
#define IRQ_MASK 0x02
// Stack is located on 6502 page 1
#define STACK_OFFSET 0x0100
typedef struct {
uint32_t min_range, max_range;
uint8_t (*read_func)(uint32_t address);
} nes6502_memread;
typedef struct {
void (*write_func)(uint32_t address, uint8_t value);
} nes6502_memwrite;
typedef struct {
uint8_t *mem_page[NES6502_NUMBANKS]; // memory page pointers
nes6502_memread *read_handler;
nes6502_memwrite *write_handler;
uint32_t pc_reg;
uint8_t a_reg, p_reg;
uint8_t x_reg, y_reg;
uint8_t s_reg;
uint8_t jammed; // is processor jammed?
uint8_t int_pending, int_latency;
int32_t total_cycles, burn_cycles;
} nes6502_context;
//PPU.H:
// PPU register defines
#define PPU_CTRL0 0x2000
#define PPU_CTRL1 0x2001
#define PPU_STAT 0x2002
#define PPU_OAMADDR 0x2003
#define PPU_OAMDATA 0x2004
#define PPU_SCROLL 0x2005
#define PPU_VADDR 0x2006
#define PPU_VDATA 0x2007
#define PPU_OAMDMA 0x4014
#define PPU_JOY0 0x4016
#define PPU_JOY1 0x4017
// $2000
#define PPU_CTRL0F_NMI 0x80
#define PPU_CTRL0F_OBJ16 0x20
#define PPU_CTRL0F_BGADDR 0x10
#define PPU_CTRL0F_OBJADDR 0x08
#define PPU_CTRL0F_ADDRINC 0x04
#define PPU_CTRL0F_NAMETAB 0x03
// $2001
#define PPU_CTRL1F_OBJON 0x10
#define PPU_CTRL1F_BGON 0x08
#define PPU_CTRL1F_OBJMASK 0x04
#define PPU_CTRL1F_BGMASK 0x02
// $2002
#define PPU_STATF_VBLANK 0x80
#define PPU_STATF_STRIKE 0x40
#define PPU_STATF_MAXSPRITE 0x20
// Sprite attribute byte bitmasks
#define OAMF_VFLIP 0x80
#define OAMF_HFLIP 0x40
#define OAMF_BEHIND 0x20
// Maximum number of sprites per horizontal scanline
#define PPU_MAXSPRITE 8
// some mappers do *dumb* things
typedef void (*ppulatchfunc_t)(uint32_t address, uint8_t value);
typedef void (*ppuvromswitch_t)(uint8_t value);
typedef struct ppu_s {
// big nasty memory chunks
uint8_t nametab[0x1000];
uint8_t oam[256];
uint8_t palette[32];
uint8_t *page[16];
// hardware registers
uint8_t ctrl0, ctrl1, stat, oam_addr;
uint32_t vaddr, vaddr_latch;
int tile_xofs, flipflop;
int vaddr_inc;
uint32_t tile_nametab;
uint8_t obj_height;
uint32_t obj_base, bg_base;
bool bg_on, obj_on;
bool obj_mask, bg_mask;
uint8_t latch, vdata_latch;
uint8_t strobe;
bool strikeflag;
uint32_t strike_cycle;
// callbacks for naughty mappers
ppulatchfunc_t latchfunc;
ppuvromswitch_t vromswitch;
bool vram_accessible;
bool vram_present;
bool drawsprites;
} ppu_t;
//APU.H:
// define this for realtime generated noise
#define REALTIME_NOISE
#define APU_WRA0 0x4000
#define APU_WRA1 0x4001
#define APU_WRA2 0x4002
#define APU_WRA3 0x4003
#define APU_WRB0 0x4004
#define APU_WRB1 0x4005
#define APU_WRB2 0x4006
#define APU_WRB3 0x4007
#define APU_WRC0 0x4008
#define APU_WRC2 0x400A
#define APU_WRC3 0x400B
#define APU_WRD0 0x400C
#define APU_WRD2 0x400E
#define APU_WRD3 0x400F
#define APU_WRE0 0x4010
#define APU_WRE1 0x4011
#define APU_WRE2 0x4012
#define APU_WRE3 0x4013
#define APU_SMASK 0x4015
// length of generated noise
#define APU_NOISE_32K 0x7FFF
#define APU_NOISE_93 93
#define APU_BASEFREQ 1789772.7272727272727272
// channel structures: As much data as possible is precalculated, to keep the sample processing as lean as possible
typedef struct rectangle_s {
uint8_t regs[4];
bool enabled;
float accum;
int32_t freq;
int32_t output_vol;
bool fixed_envelope;
bool holdnote;
uint8_t volume;
int32_t sweep_phase;
int32_t sweep_delay;
bool sweep_on;
uint8_t sweep_shifts;
uint8_t sweep_length;
bool sweep_inc;
// this may not be necessary in the future
int32_t freq_limit;
int32_t env_phase;
int32_t env_delay;
uint8_t env_vol;
int vbl_length;
uint8_t adder;
int duty_flip;
} rectangle_t;
typedef struct triangle_s {
uint8_t regs[3];
bool enabled;
float accum;
int32_t freq;
int32_t output_vol;
uint8_t adder;
bool holdnote;
bool counter_started;
// quasi-hack
int write_latency;
int vbl_length;
int linear_length;
} triangle_t;
typedef struct noise_s {
uint8_t regs[3];
bool enabled;
float accum;
int32_t freq;
int32_t output_vol;
int32_t env_phase;
int32_t env_delay;
uint8_t env_vol;
bool holdnote;
uint8_t volume;
int vbl_length;
#ifdef REALTIME_NOISE
uint8_t xor_tap;
#else
bool short_sample;
int cur_pos;
#endif // REALTIME_NOISE
} noise_t;
typedef struct dmc_s
uint8_t regs[4];
// bodge for timestamp queue
bool enabled;
float accum;
int32_t freq;
int32_t output_vol;
uint32_t address;
uint32_t cached_addr;
int dma_length;
int cached_dmalength;
uint8_t cur_byte;
bool looping;
bool irq_gen;
bool irq_occurred;
} dmc_t;
enum
APU_FILTER_NONE,
APU_FILTER_LOWPASS,
APU_FILTER_WEIGHTED
typedef struct
} apu_memread;
typedef struct
} apu_memwrite;
// external sound chip stuff
typedef struct apuext_s
int (*init)(void);
void (*shutdown)(void);
void (*reset)(void);
int32_t (*process)(void);
apu_memread *mem_read;
apu_memwrite *mem_write;
} apuext_t;
typedef struct apu_s
rectangle_t rectangle[2];
triangle_t triangle;
noise_t noise;
dmc_t dmc;
uint8_t enable_reg;
void *buffer; // pointer to output buffer
int num_samples;
uint8_t mix_enable;
int filter_type;
double base_freq;
float cycle_rate;
int sample_rate;
int sample_bits;
int refresh_rate;
void (*process)(void *buffer, int num_samples);
void (*irq_callback)(void);
uint8_t (*irqclear_callback)(void);
apuext_t *ext;
} apu_t;
//ROM.H:
typedef enum {
MIRROR_HORIZ = 0,
MIRROR_VERT = 1
} mirror_t;
#define ROM_FLAG_BATTERY 0x01
#define ROM_FLAG_TRAINER 0x02
#define ROM_FLAG_FOURSCREEN 0x04
#define ROM_FLAG_VERSUS 0x08
typedef struct rominfo_s
// pointers to ROM and VROM
uint8_t *rom, *vrom;
// pointers to SRAM and VRAM
uint8_t *sram, *vram;
// number of banks
int rom_banks, vrom_banks;
int sram_banks, vram_banks;
int mapper_number;
mirror_t mirror;
uint8_t flags;
} rominfo_t;
typedef struct inesheader_s
uint8_t ines_magic[4];
uint8_t rom_banks;
uint8_t vrom_banks;
uint8_t rom_type;
uint8_t mapper_hinybble;
uint8_t reserved[8];
} inesheader_t;
//LIBSNS.H:
#define TAG_LENGTH 4
struct mapper1Data {
unsigned char registers[4];
unsigned char latch;
unsigned char numberOfBits;
struct mapper4Data {
unsigned char irqCounter;
unsigned char irqLatchCounter;
unsigned char irqCounterEnabled;
unsigned char last8000Write;
struct mapper5Data {
unsigned char dummy; // needed for some compilers; remove if any members are added
struct mapper6Data {
unsigned char last43FEWrite;
unsigned char last4500Write;
struct mapper9Data {
unsigned char latch[2];
unsigned char lastB000Write;
unsigned char lastC000Write;
unsigned char lastD000Write;
unsigned char lastE000Write;
struct mapper10Data {
struct mapper16Data {
unsigned char irqCounterLowByte;
unsigned char irqCounterHighByte;
struct mapper17Data {
struct mapper18Data {
struct mapper19Data {
struct mapper21Data {
struct mapper24Data {
struct mapper40Data {
struct mapper69Data {
struct mapper90Data {
struct mapper224Data {
unsigned char chrRamWriteable;
struct mapper225Data {
unsigned char prgSize;
struct mapper226Data {
struct mapper228Data {
unsigned char prgChipSelected;
struct mapper230Data {
unsigned char numberOfResets;
typedef struct _SnssFileHeader {
char tag[TAG_LENGTH + 1];
unsigned int numberOfBlocks;
} SnssFileHeader;
// this block appears before every block in the SNSS file
typedef struct _SnssBlockHeader {
unsigned int blockVersion;
unsigned int blockLength;
} SnssBlockHeader;
#define MAPPER_BLOCK_LENGTH 0x98
typedef struct _SnssMapperBlock
unsigned short prgPages[4];
unsigned short chrPages[8];
union _extraData
unsigned char mapperData[128];
struct mapper1Data mapper1;
struct mapper4Data mapper4;
struct mapper5Data mapper5;
struct mapper6Data mapper6;
struct mapper9Data mapper9;
struct mapper10Data mapper10;
struct mapper16Data mapper16;
struct mapper17Data mapper17;
struct mapper18Data mapper18;
struct mapper19Data mapper19;
struct mapper21Data mapper21;
struct mapper24Data mapper24;
struct mapper40Data mapper40;
struct mapper69Data mapper69;
struct mapper90Data mapper90;
struct mapper224Data mapper224;
struct mapper225Data mapper225;
struct mapper226Data mapper226;
struct mapper228Data mapper228;
struct mapper230Data mapper230;
} extraData;
} SnssMapperBlock;
//MMC.H:
#define MMC_LASTBANK -1
typedef struct {
} map_memread;
typedef struct {
} map_memwrite;
typedef struct mapintf_s {
int number;
char *name;
void (*init)(void);
void (*vblank)(void);
void (*hblank)(int vblank);
void (*get_state)(SnssMapperBlock *state);
void (*set_state)(SnssMapperBlock *state);
map_memread *mem_read;
map_memwrite *mem_write;
apuext_t *sound_ext;
} mapintf_t;
typedef struct mmc_s {
mapintf_t *intf;
rominfo_t *cart; // link it back to the cart
} mmc_t;
//NES.H
typedef struct nes_s {
// hardware things
nes6502_context *cpu;
nes6502_memread readhandler[MAX_MEM_HANDLERS];
nes6502_memwrite writehandler[MAX_MEM_HANDLERS];
ppu_t *ppu;
apu_t *apu;
mmc_t *mmc;
rominfo_t *rominfo;
bool fiq_occurred;
uint8_t fiq_state;
int fiq_cycles;
int scanline;
// Timing stuff
float scanline_cycles;
} nes_t;
ppu_t ppu;
apu_t apu;
mmc_t mmc;
nes_t nes;
nes_t *NESmachine;
// EMULATOR CORE CODES:
//ROM.C
// Max length for displayed filename
#define ROM_DISP_MAXLEN 20
#define ROM_FOURSCREEN 0x08
#define ROM_TRAINER 0x04
#define ROM_BATTERY 0x02
#define ROM_MIRRORTYPE 0x01
#define ROM_INES_MAGIC "NES\x1A"
#define TRAINER_OFFSET 0x1000
#define TRAINER_LENGTH 0x200
#define VRAM_LENGTH 0x2000
#define ROM_BANK_LENGTH 0x4000
#define VROM_BANK_LENGTH 0x2000
#define SRAM_BANK_LENGTH 0x0400
#define VRAM_BANK_LENGTH 0x2000
// Allocate space for SRAM
int rom_allocsram(rominfo_t *rominfo);
int rom_allocsram(rominfo_t *rominfo) {
// Load up SRAM
if (NULL == rominfo->sram) rominfo->sram = (uint8_t*)malloc(SRAM_BANK_LENGTH * rominfo->sram_banks);
if (NULL == rominfo->sram) {
///gui_sendmsg(GUI_RED, "Could not allocate space for battery RAM");
return -1;
// make damn sure SRAM is clear
memset(rominfo->sram, 0, SRAM_BANK_LENGTH * rominfo->sram_banks);
return 0;
// If there's a trainer, load it in at $7000
void rom_loadtrainer(unsigned char **rom, rominfo_t *rominfo);
void rom_loadtrainer(unsigned char **rom, rominfo_t *rominfo) {
if (rominfo->flags & ROM_FLAG_TRAINER)
// fread(rominfo->sram + TRAINER_OFFSET, TRAINER_LENGTH, 1, fp);
memcpy(rominfo->sram + TRAINER_OFFSET, *rom, TRAINER_LENGTH);
rom += TRAINER_LENGTH;
///nes_log_printf("Read in trainer at $7000\n");
int rom_loadrom(unsigned char **rom, rominfo_t *rominfo);
int rom_loadrom(unsigned char **rom, rominfo_t *rominfo) {
rominfo->rom = *rom;
*rom += ROM_BANK_LENGTH * rominfo->rom_banks;
// If there's VROM, allocate and stuff it in
if (rominfo->vrom_banks)
rominfo->vrom = *rom;
*rom += VROM_BANK_LENGTH * rominfo->vrom_banks;
if (NULL == rominfo->vram) rominfo->vram = (uint8_t*)malloc(VRAM_LENGTH);
///gui_sendmsg(GUI_RED, "Could not allocate space for VRAM");
return -1;
memset(rominfo->vram, 0, VRAM_LENGTH);
return 0;
#define RESERVED_LENGTH 8
int rom_getheader(unsigned char **rom, rominfo_t *rominfo);
int rom_getheader(unsigned char **rom, rominfo_t *rominfo) {
inesheader_t head;
uint8_t reserved[RESERVED_LENGTH];
bool header_dirty;
// Read in the header
if (DEBUG) {
Serial.print("Head: ");
Serial.print((*rom)[0]);
Serial.print(" ");
Serial.print((*rom)[1]);
Serial.print(" ");
Serial.print((*rom)[2]);
Serial.print(" ");
Serial.println((*rom)[3]);
memcpy(&head, *rom, sizeof(head));
*rom += sizeof(head);
if (memcmp(head.ines_magic, ROM_INES_MAGIC, 4)) {
if (DEBUG) Serial.println("ROM is not a valid NES image");
if (DEBUG) tft.println("ROM is not a valid NES image");
return -1;
rominfo->rom_banks = head.rom_banks;
rominfo->vrom_banks = head.vrom_banks;
// iNES assumptions
rominfo->sram_banks = 8; //1kB banks, so 8KB
rominfo->vram_banks = 1; // 8kB banks, so 8KB
rominfo->mirror = (head.rom_type & ROM_MIRRORTYPE) ? MIRROR_VERT : MIRROR_HORIZ;
rominfo->flags = 0;
if (head.rom_type & ROM_BATTERY) rominfo->flags |= ROM_FLAG_BATTERY;
if (head.rom_type & ROM_TRAINER) rominfo->flags |= ROM_FLAG_TRAINER;
if (head.rom_type & ROM_FOURSCREEN) rominfo->flags |= ROM_FLAG_FOURSCREEN;
// TODO: fourscreen a mirroring type?
rominfo->mapper_number = head.rom_type >> 4;
// Do a compare - see if we've got a clean extended header
memset(reserved, 0, RESERVED_LENGTH);
if (0 == memcmp(head.reserved, reserved, RESERVED_LENGTH)) {
// We were clean
header_dirty = false;
rominfo->mapper_number |= (head.mapper_hinybble & 0xF0);
header_dirty = true;
// @!?#@! DiskDude.
if (('D' == head.mapper_hinybble) && (0 == memcmp(head.reserved, "iskDude!", 8))) {
///nes_log_printf("`DiskDude!' found in ROM header, ignoring high mapper nybble\n");
///nes_log_printf("ROM header dirty, possible problem\n");
///rom_adddirty(rominfo->filename);
// Check for VS unisystem mapper
if (99 == rominfo->mapper_number) rominfo->flags |= ROM_FLAG_VERSUS;
return 0;
/* Free a ROM */
void rom_free(rominfo_t **rominfo);
if (NULL == *rominfo)
if (DEBUG) Serial.println("ROM not loaded");
return;
/* if ((*rominfo)->sram)
free((*rominfo)->sram);
Serial.println("sram"); */
/* if ((*rominfo)->rom)
free((*rominfo)->rom);
Serial.println("rom");
if ((*rominfo)->vrom)
free((*rominfo)->vrom);
Serial.println("vrom");
if ((*rominfo)->vram)
free((*rominfo)->vram);
Serial.println("vram"); */
free(*rominfo);
///CPU.C:
// internal CPU context
static nes6502_context cpu;
static int remaining_cycles = 0; // so we can release timeslice
// memory region pointers
static uint8_t *ram = NULL, *stack = NULL;
static uint8_t null_page[NES6502_BANKSIZE];
//#define NES6502_DISASM
//#define NES6502_JUMPTABLE
#define ADD_CYCLES(x) { remaining_cycles -= (x); cpu.total_cycles += (x); }
#define PAGE_CROSS_CHECK(addr, reg) { if ((reg) > (uint8_t) (addr)) ADD_CYCLES(1); }
#define EMPTY_READ(value) // empty
#define IMMEDIATE_BYTE(value) { value = bank_readbyte(PC++); }
#define ABSOLUTE_ADDR(address) { address = bank_readword(PC); PC += 2; }
#define ABSOLUTE(address, value) { ABSOLUTE_ADDR(address); value = mem_readbyte(address); }
#define ABSOLUTE_BYTE(value) { ABSOLUTE(temp, value); }
#define ABS_IND_X_ADDR(address) { ABSOLUTE_ADDR(address); address = (address + X) & 0xFFFF; }
#define ABS_IND_X(address, value) { ABS_IND_X_ADDR(address); value = mem_readbyte(address); }
#define ABS_IND_X_BYTE(value) { ABS_IND_X(temp, value); }
#define ABS_IND_X_BYTE_READ(value) { ABS_IND_X_ADDR(temp); PAGE_CROSS_CHECK(temp, X); value = mem_readbyte(temp); }
#define ABS_IND_Y_ADDR(address) { ABSOLUTE_ADDR(address); address = (address + Y) & 0xFFFF; }
#define ABS_IND_Y(address, value) { ABS_IND_Y_ADDR(address); value = mem_readbyte(address); }
#define ABS_IND_Y_BYTE(value) { ABS_IND_Y(temp, value); }
#define ABS_IND_Y_BYTE_READ(value) { ABS_IND_Y_ADDR(temp); PAGE_CROSS_CHECK(temp, Y); value = mem_readbyte(temp); }
#define ZERO_PAGE_ADDR(address) { IMMEDIATE_BYTE(address); }
#define ZERO_PAGE(address, value) { ZERO_PAGE_ADDR(address); value = ZP_READBYTE(address); }
#define ZERO_PAGE_BYTE(value) { ZERO_PAGE(btemp, value); }
#define ZP_IND_X_ADDR(address) { ZERO_PAGE_ADDR(address); address += X; }
#define ZP_IND_X(address, value) { ZP_IND_X_ADDR(address); value = ZP_READBYTE(address); }
#define ZP_IND_X_BYTE(value) { ZP_IND_X(btemp, value); }
#define ZP_IND_Y_ADDR(address) { ZERO_PAGE_ADDR(address); address += Y; }
#define ZP_IND_Y_BYTE(value) { ZP_IND_Y_ADDR(btemp); value = ZP_READBYTE(btemp); }
#define INDIR_X_ADDR(address) { ZERO_PAGE_ADDR(btemp); btemp += X; address = zp_readword(btemp); }
#define INDIR_X(address, value) { INDIR_X_ADDR(address); value = mem_readbyte(address); }
#define INDIR_X_BYTE(value) { INDIR_X(temp, value); }
#define INDIR_Y_ADDR(address) { ZERO_PAGE_ADDR(btemp); address = (zp_readword(btemp) + Y) & 0xFFFF; }
#define INDIR_Y(address, value) { INDIR_Y_ADDR(address); value = mem_readbyte(address); }
#define INDIR_Y_BYTE(value) { INDIR_Y(temp, value); }
#define INDIR_Y_BYTE_READ(value) { INDIR_Y_ADDR(temp); PAGE_CROSS_CHECK(temp, Y); value = mem_readbyte(temp); }
#define PUSH(value) stack[S--] = (uint8_t) (value)
#define PULL() stack[++S]
#define SCATTER_FLAGS(value) { n_flag = (value) & N_FLAG; v_flag = (value) & V_FLAG; b_flag = (value) & B_FLAG; \
d_flag = (value) & D_FLAG; i_flag = (value) & I_FLAG; z_flag = (0 == ((value) & Z_FLAG)); c_flag = (value) & C_FLAG; }
#define COMBINE_FLAGS() ( (n_flag & N_FLAG) | (v_flag ? V_FLAG : 0) | R_FLAG | (b_flag ? B_FLAG : 0) | (d_flag ? D_FLAG : 0) \
| (i_flag ? I_FLAG : 0) | (z_flag ? 0 : Z_FLAG) | c_flag )
#define SET_NZ_FLAGS(value) n_flag = z_flag = (value);
#define RELATIVE_BRANCH(condition) { if (condition) { IMMEDIATE_BYTE(btemp); if (((int8_t) btemp + (PC & 0x00FF)) & 0x100) \
ADD_CYCLES(1); ADD_CYCLES(3); PC += (int8_t) btemp; } else { PC++; ADD_CYCLES(2); } }
#define JUMP(address) { PC = bank_readword((address)); }
#define NMI_PROC() { PUSH(PC >> 8); PUSH(PC & 0xFF); b_flag = 0; PUSH(COMBINE_FLAGS()); i_flag = 1; JUMP(NMI_VECTOR); }
#define IRQ_PROC() { PUSH(PC >> 8); PUSH(PC & 0xFF); b_flag = 0; PUSH(COMBINE_FLAGS()); i_flag = 1; JUMP(IRQ_VECTOR); }
// Warning! NES CPU has no decimal mode, so by default this does no BCD!
#ifdef NES6502_DECIMAL
#define ADC(cycles, read_func) { read_func(data); if (d_flag) { temp = (A & 0x0F) + (data & 0x0F) + c_flag; if (temp >= 10) \
temp = (temp - 10) | 0x10; temp += (A & 0xF0) + (data & 0xF0); z_flag = (A + data + c_flag) & 0xFF; n_flag = temp; \
v_flag = ((~(A ^ data)) & (A ^ temp) & 0x80); if (temp > 0x90) { temp += 0x60; c_flag = 1; } else { c_flag = 0; } \
A = (uint8_t) temp; } else { temp = A + data + c_flag; c_flag = (temp >> 8) & 1; v_flag = ((~(A ^ data)) & (A ^ temp) & 0x80); \
A = (uint8_t) temp; SET_NZ_FLAGS(A); } ADD_CYCLES(cycles); }
#else // NES6502_DECIMAL
#define ADC(cycles, read_func) { read_func(data); temp = A + data + c_flag; c_flag = (temp >> 8) & 1; \
v_flag = ((~(A ^ data)) & (A ^ temp) & 0x80); A = (uint8_t) temp; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#endif // NES6502_DECIMAL
#define ANC(cycles, read_func) { read_func(data); A &= data; c_flag = (n_flag & N_FLAG) >> 7; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define AND(cycles, read_func) { read_func(data); A &= data; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define ANE(cycles, read_func) { read_func(data); A = (A | 0xEE) & X & data; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define ARR(cycles, read_func) { read_func(data); data &= A; if (d_flag) { temp = (data >> 1) | (c_flag << 7); SET_NZ_FLAGS(temp); \
v_flag = (temp ^ data) & 0x40; if (((data & 0x0F) + (data & 0x01)) > 5) temp = (temp & 0xF0) | ((temp + 0x6) & 0x0F); \
if (((data & 0xF0) + (data & 0x10)) > 0x50) { temp = (temp & 0x0F) | ((temp + 0x60) & 0xF0); c_flag = 1; } else { \
c_flag = 0; } A = (uint8_t) temp; } else { A = (data >> 1) | (c_flag << 7); SET_NZ_FLAGS(A); c_flag = (A & 0x40) >> 6; \
v_flag = ((A >> 6) ^ (A >> 5)) & 1; } ADD_CYCLES(cycles); }
#define ARR(cycles, read_func) { read_func(data); data &= A; A = (data >> 1) | (c_flag << 7); \
SET_NZ_FLAGS(A); c_flag = (A & 0x40) >> 6; v_flag = ((A >> 6) ^ (A >> 5)) & 1; ADD_CYCLES(cycles); }
#define ASL(cycles, read_func, write_func, addr) { read_func(addr, data); c_flag = data >> 7; data <<= 1; write_func(addr, data); \
SET_NZ_FLAGS(data); ADD_CYCLES(cycles); }
#define ASL_A() { c_flag = A >> 7; A <<= 1; SET_NZ_FLAGS(A); ADD_CYCLES(2); }
#define ASR(cycles, read_func) { read_func(data); data &= A; c_flag = data & 1; A = data >> 1; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define BCC() { RELATIVE_BRANCH(0 == c_flag); }
#define BCS() { RELATIVE_BRANCH(0 != c_flag); }
#define BEQ() { RELATIVE_BRANCH(0 == z_flag); }
#define BIT(cycles, read_func) { read_func(data); n_flag = data; v_flag = data & V_FLAG; z_flag = data & A; ADD_CYCLES(cycles); }
#define BMI() { RELATIVE_BRANCH(n_flag & N_FLAG); }
#define BNE() { RELATIVE_BRANCH(0 != z_flag); }
#define BPL() { RELATIVE_BRANCH(0 == (n_flag & N_FLAG)); }
#define BRK() { PC++; PUSH(PC >> 8); PUSH(PC & 0xFF); b_flag = 1; PUSH(COMBINE_FLAGS()); i_flag = 1; JUMP(IRQ_VECTOR); ADD_CYCLES(7); }
#define BVC() { RELATIVE_BRANCH(0 == v_flag); }
#define BVS() { RELATIVE_BRANCH(0 != v_flag); }
#define CLC() { c_flag = 0; ADD_CYCLES(2); }
#define CLD() { d_flag = 0; ADD_CYCLES(2); }
#define CLI() { i_flag = 0; ADD_CYCLES(2); if (cpu.int_pending && remaining_cycles > 0) { cpu.int_pending = 0; \
IRQ_PROC(); ADD_CYCLES(INT_CYCLES); } }
#define CLV() { v_flag = 0; ADD_CYCLES(2); }
#define _COMPARE(reg, value) { temp = (reg) - (value); c_flag = ((temp & 0x100) >> 8) ^ 1; SET_NZ_FLAGS((uint8_t) temp); }
#define CMP(cycles, read_func) { read_func(data); _COMPARE(A, data); ADD_CYCLES(cycles); }
#define CPX(cycles, read_func) { read_func(data); _COMPARE(X, data); ADD_CYCLES(cycles); }
#define CPY(cycles, read_func) { read_func(data); _COMPARE(Y, data); ADD_CYCLES(cycles); }
#define DCP(cycles, read_func, write_func, addr) { read_func(addr, data); data--; write_func(addr, data); CMP(cycles, EMPTY_READ); }
#define _DEC(cycles, read_func, write_func, addr) { read_func(addr, data); data--; write_func(addr, data); SET_NZ_FLAGS(data); \
#define DEX() { X--; SET_NZ_FLAGS(X); ADD_CYCLES(2); }
#define DEY() { Y--; SET_NZ_FLAGS(Y); ADD_CYCLES(2); }
#define DOP(cycles) { PC++; ADD_CYCLES(cycles); }
#define EOR(cycles, read_func) { read_func(data); A ^= data; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define INC(cycles, read_func, write_func, addr) { read_func(addr, data); data++; write_func(addr, data); \
#define INX() { X++; SET_NZ_FLAGS(X); ADD_CYCLES(2); }
#define INY() { Y++; SET_NZ_FLAGS(Y); ADD_CYCLES(2); }
#define ISB(cycles, read_func, write_func, addr) { read_func(addr, data); data++; write_func(addr, data); SBC(cycles, EMPTY_READ); }
#ifdef NES6502_TESTOPS
#define JAM() { cpu_Jam(); }
#else // !NES6502_TESTOPS
#define JAM() { PC--; cpu.jammed = true; cpu.int_pending = 0; ADD_CYCLES(2); }
#endif // !NES6502_TESTOPS
#define JMP_INDIRECT() { temp = bank_readword(PC); if (0xFF == (temp & 0xFF)) \
PC = (bank_readbyte(temp & 0xFF00) << 8) | bank_readbyte(temp); else JUMP(temp); ADD_CYCLES(5); }
#define JMP_ABSOLUTE() { JUMP(PC); ADD_CYCLES(3); }
#define JSR() { PC++; PUSH(PC >> 8); PUSH(PC & 0xFF); JUMP(PC - 1); ADD_CYCLES(6); }
#define LAS(cycles, read_func) { read_func(data); A = X = S = (S & data); SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define LAX(cycles, read_func) { read_func(A); X = A; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define LDA(cycles, read_func) { read_func(A); SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define LDX(cycles, read_func) { read_func(X); SET_NZ_FLAGS(X); ADD_CYCLES(cycles); }
#define LDY(cycles, read_func) { read_func(Y); SET_NZ_FLAGS(Y); ADD_CYCLES(cycles); }
#define LSR(cycles, read_func, write_func, addr) { read_func(addr, data); c_flag = data & 1; data >>= 1; \
write_func(addr, data); SET_NZ_FLAGS(data); ADD_CYCLES(cycles); }
#define LSR_A() { c_flag = A & 1; A >>= 1; SET_NZ_FLAGS(A); ADD_CYCLES(2); }
#define LXA(cycles, read_func) { read_func(data); A = X = ((A | 0xEE) & data); SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define NOP() { ADD_CYCLES(2); }
#define ORA(cycles, read_func) { read_func(data); A |= data; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define PHA() { PUSH(A); ADD_CYCLES(3); }
#define PHP() { PUSH(COMBINE_FLAGS() | B_FLAG); ADD_CYCLES(3); }
#define PLA() { A = PULL(); SET_NZ_FLAGS(A); ADD_CYCLES(4); }
#define PLP() { btemp = PULL(); SCATTER_FLAGS(btemp); ADD_CYCLES(4); }
#define RLA(cycles, read_func, write_func, addr) { read_func(addr, data); btemp = c_flag; c_flag = data >> 7; \
data = (data << 1) | btemp; write_func(addr, data); A &= data; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define ROL(cycles, read_func, write_func, addr) { read_func(addr, data); btemp = c_flag; c_flag = data >> 7; \
data = (data << 1) | btemp; write_func(addr, data); SET_NZ_FLAGS(data); ADD_CYCLES(cycles); }
#define ROL_A() { btemp = c_flag; c_flag = A >> 7; A = (A << 1) | btemp; SET_NZ_FLAGS(A); ADD_CYCLES(2); }
#define ROR(cycles, read_func, write_func, addr) { read_func(addr, data); btemp = c_flag << 7; c_flag = data & 1; \
data = (data >> 1) | btemp; write_func(addr, data); SET_NZ_FLAGS(data); ADD_CYCLES(cycles); }
#define ROR_A() { btemp = c_flag << 7; c_flag = A & 1; A = (A >> 1) | btemp; SET_NZ_FLAGS(A); ADD_CYCLES(2); }
#define RRA(cycles, read_func, write_func, addr) { read_func(addr, data); btemp = c_flag << 7; c_flag = data & 1; \
data = (data >> 1) | btemp; write_func(addr, data); ADC(cycles, EMPTY_READ); }
#define RTI() { btemp = PULL(); SCATTER_FLAGS(btemp); PC = PULL(); PC |= PULL() << 8; ADD_CYCLES(6); \
if (0 == i_flag && cpu.int_pending && remaining_cycles > 0) { cpu.int_pending = 0; IRQ_PROC(); ADD_CYCLES(INT_CYCLES); } }
#define RTS() { PC = PULL(); PC = (PC | (PULL() << 8)) + 1; ADD_CYCLES(6); }
#define SAX(cycles, read_func, write_func, addr) { read_func(addr); data = A & X; write_func(addr, data); ADD_CYCLES(cycles); }
#define SBC(cycles, read_func) { read_func(data); temp = A - data - (c_flag ^ 1); if (d_flag) { uint8_t al, ah; \
al = (A & 0x0F) - (data & 0x0F) - (c_flag ^ 1); ah = (A >> 4) - (data >> 4); if (al & 0x10) { al -= 6; ah--; \
} if (ah & 0x10) { ah -= 6; c_flag = 0; } else { c_flag = 1; } v_flag = (A ^ temp) & (A ^ data) & 0x80; \
SET_NZ_FLAGS(temp & 0xFF); A = (ah << 4) | (al & 0x0F); } else { v_flag = (A ^ temp) & (A ^ data) & 0x80; \
c_flag = ((temp & 0x100) >> 8) ^ 1; A = (uint8_t) temp; SET_NZ_FLAGS(A & 0xFF); } ADD_CYCLES(cycles); }
#else
#define SBC(cycles, read_func) { read_func(data); temp = A - data - (c_flag ^ 1); v_flag = (A ^ data) & (A ^ temp) & 0x80; \
c_flag = ((temp >> 8) & 1) ^ 1; A = (uint8_t) temp; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define SBX(cycles, read_func) { read_func(data); temp = (A & X) - data; c_flag = ((temp >> 8) & 1) ^ 1; X = temp & 0xFF; \
#define SEC() { c_flag = 1; ADD_CYCLES(2); }
#define SED() { d_flag = 1; ADD_CYCLES(2); }
#define SEI() { i_flag = 1; ADD_CYCLES(2); }
#define SHA(cycles, read_func, write_func, addr) { read_func(addr); data = A & X & ((uint8_t) ((addr >> 8) + 1)); \
#define SHS(cycles, read_func, write_func, addr) { read_func(addr); S = A & X; data = S & ((uint8_t) ((addr >> 8) + 1)); \
#define SHX(cycles, read_func, write_func, addr) { read_func(addr); data = X & ((uint8_t) ((addr >> 8) + 1)); \
#define SHY(cycles, read_func, write_func, addr) { read_func(addr); data = Y & ((uint8_t) ((addr >> 8 ) + 1)); \
#define SLO(cycles, read_func, write_func, addr) { read_func(addr, data); c_flag = data >> 7; data <<= 1; \
write_func(addr, data); A |= data; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define SRE(cycles, read_func, write_func, addr) { read_func(addr, data); c_flag = data & 1; data >>= 1; \
write_func(addr, data); A ^= data; SET_NZ_FLAGS(A); ADD_CYCLES(cycles); }
#define STA(cycles, read_func, write_func, addr) { read_func(addr); write_func(addr, A); ADD_CYCLES(cycles); }
#define STX(cycles, read_func, write_func, addr) { read_func(addr); write_func(addr, X); ADD_CYCLES(cycles); }
#define STY(cycles, read_func, write_func, addr) { read_func(addr); write_func(addr, Y); ADD_CYCLES(cycles); }
#define TAX() { X = A; SET_NZ_FLAGS(X); ADD_CYCLES(2); }
#define TAY() { Y = A; SET_NZ_FLAGS(Y); ADD_CYCLES(2); }
#define TOP() { PC += 2; ADD_CYCLES(4); }
#define TSX() { X = S; SET_NZ_FLAGS(X); ADD_CYCLES(2); }
#define TXA() { A = X; SET_NZ_FLAGS(A); ADD_CYCLES(2); }
#define TXS() { S = X; ADD_CYCLES(2); }
#define TYA() { A = Y; SET_NZ_FLAGS(A); ADD_CYCLES(2); }
#define ZP_READBYTE(addr) ram[(addr)]
#define ZP_WRITEBYTE(addr, value) ram[(addr)] = (uint8_t) (value)
#ifdef HOST_LITTLE_ENDIAN
static inline uint32_t zp_readword(register uint8_t address) {
return (uint32_t) (*(uint16_t *)(ram + address));
static inline uint32_t bank_readword(register uint32_t address) {
return (uint32_t) (*(uint16_t *)(cpu.mem_page[address >> NES6502_BANKSHIFT] + (address & NES6502_BANKMASK)));
#else // !HOST_LITTLE_ENDIAN
uint32_t x = (uint32_t) * (uint16_t *)(ram + address);
return (x << 8) | (x >> 8);
uint32_t x = (uint32_t) * (uint16_t *)(cpu.mem_page[address >> NES6502_BANKSHIFT] + (address & NES6502_BANKMASK));
#endif // !HOST_LITTLE_ENDIAN
static inline uint8_t bank_readbyte(register uint32_t address) {
return cpu.mem_page[address >> NES6502_BANKSHIFT][address & NES6502_BANKMASK];
static inline void bank_writebyte(register uint32_t address, register uint8_t value) {
cpu.mem_page[address >> NES6502_BANKSHIFT][address & NES6502_BANKMASK] = value;
static uint8_t mem_readbyte(uint32_t address) {
nes6502_memread *mr;
if (address < 0x800) { // RAM
return ram[address];
} else if (address >= 0x8000) {
return bank_readbyte(address);
for (mr = cpu.read_handler; mr->min_range != 0xFFFFFFFF; mr++) {
if (address >= mr->min_range && address <= mr->max_range)
return mr->read_func(address);
static void mem_writebyte(uint32_t address, uint8_t value) {
nes6502_memwrite *mw;
ram[address] = value;
return;
for (mw = cpu.write_handler; mw->min_range != 0xFFFFFFFF; mw++) {
if (address >= mw->min_range && address <= mw->max_range) {
mw->write_func(address, value);
return;
bank_writebyte(address, value);
void nes6502_setcontext(nes6502_context *context);
void nes6502_setcontext(nes6502_context *context) {
int loop;
cpu = *context;
for (loop = 0; loop < NES6502_NUMBANKS; loop++) {
if (NULL == cpu.mem_page[loop]) cpu.mem_page[loop] = null_page;
ram = cpu.mem_page[0]; // quick zero-page/RAM references
stack = ram + STACK_OFFSET;
void nes6502_getcontext(nes6502_context *context);
void nes6502_getcontext(nes6502_context *context) {
int loop;
*context = cpu;
if (null_page == context->mem_page[loop]) context->mem_page[loop] = NULL;
uint8_t nes6502_getbyte(uint32_t address) {
uint32_t nes6502_getcycles(bool reset_flag) {
uint32_t cycles = cpu.total_cycles;
if (reset_flag) cpu.total_cycles = 0;
return cycles;
#define GET_GLOBAL_REGS() { PC = cpu.pc_reg; A = cpu.a_reg; X = cpu.x_reg; Y = cpu.y_reg; SCATTER_FLAGS(cpu.p_reg); S = cpu.s_reg; }
#define STORE_LOCAL_REGS() { cpu.pc_reg = PC; cpu.a_reg = A; cpu.x_reg = X; cpu.y_reg = Y; cpu.p_reg = COMBINE_FLAGS(); cpu.s_reg = S; }
#define MIN(a,b) (((a) < (b)) ? (a) : (b))
#ifdef NES6502_JUMPTABLE
#define OPCODE_BEGIN(xx) op##xx:
#define OPCODE_END if (remaining_cycles <= 0) goto end_execute; goto *opcode_table[bank_readbyte(PC++)];
#else // !NES6502_JUMPTABLE
#define OPCODE_BEGIN(xx) case 0x##xx:
#define OPCODE_END break;
#endif // !NES6502_JUMPTABLE
int nes6502_execute(int timeslice_cycles) {
int old_cycles = cpu.total_cycles;
uint32_t temp, addr; // for macros
uint8_t btemp, baddr; // for macros
uint8_t data;
uint8_t n_flag, v_flag, b_flag;
uint8_t d_flag, i_flag, z_flag, c_flag;
uint32_t PC;
uint8_t A, X, Y, S;
static const void *opcode_table[256] =
&&op00, &&op01, &&op02, &&op03, &&op04, &&op05, &&op06, &&op07,
&&op08, &&op09, &&op0A, &&op0B, &&op0C, &&op0D, &&op0E, &&op0F,
&&op10, &&op11, &&op12, &&op13, &&op14, &&op15, &&op16, &&op17,
&&op18, &&op19, &&op1A, &&op1B, &&op1C, &&op1D, &&op1E, &&op1F,
&&op20, &&op21, &&op22, &&op23, &&op24, &&op25, &&op26, &&op27,
&&op28, &&op29, &&op2A, &&op2B, &&op2C, &&op2D, &&op2E, &&op2F,
&&op30, &&op31, &&op32, &&op33, &&op34, &&op35, &&op36, &&op37,
&&op38, &&op39, &&op3A, &&op3B, &&op3C, &&op3D, &&op3E, &&op3F,
&&op40, &&op41, &&op42, &&op43, &&op44, &&op45, &&op46, &&op47,
&&op48, &&op49, &&op4A, &&op4B, &&op4C, &&op4D, &&op4E, &&op4F,
&&op50, &&op51, &&op52, &&op53, &&op54, &&op55, &&op56, &&op57,
&&op58, &&op59, &&op5A, &&op5B, &&op5C, &&op5D, &&op5E, &&op5F,
&&op60, &&op61, &&op62, &&op63, &&op64, &&op65, &&op66, &&op67,
&&op68, &&op69, &&op6A, &&op6B, &&op6C, &&op6D, &&op6E, &&op6F,
&&op70, &&op71, &&op72, &&op73, &&op74, &&op75, &&op76, &&op77,
&&op78, &&op79, &&op7A, &&op7B, &&op7C, &&op7D, &&op7E, &&op7F,
&&op80, &&op81, &&op82, &&op83, &&op84, &&op85, &&op86, &&op87,
&&op88, &&op89, &&op8A, &&op8B, &&op8C, &&op8D, &&op8E, &&op8F,
&&op90, &&op91, &&op92, &&op93, &&op94, &&op95, &&op96, &&op97,
&&op98, &&op99, &&op9A, &&op9B, &&op9C, &&op9D, &&op9E, &&op9F,
&&opA0, &&opA1, &&opA2, &&opA3, &&opA4, &&opA5, &&opA6, &&opA7,
&&opA8, &&opA9, &&opAA, &&opAB, &&opAC, &&opAD, &&opAE, &&opAF,
&&opB0, &&opB1, &&opB2, &&opB3, &&opB4, &&opB5, &&opB6, &&opB7,
&&opB8, &&opB9, &&opBA, &&opBB, &&opBC, &&opBD, &&opBE, &&opBF,
&&opC0, &&opC1, &&opC2, &&opC3, &&opC4, &&opC5, &&opC6, &&opC7,
&&opC8, &&opC9, &&opCA, &&opCB, &&opCC, &&opCD, &&opCE, &&opCF,
&&opD0, &&opD1, &&opD2, &&opD3, &&opD4, &&opD5, &&opD6, &&opD7,
&&opD8, &&opD9, &&opDA, &&opDB, &&opDC, &&opDD, &&opDE, &&opDF,
&&opE0, &&opE1, &&opE2, &&opE3, &&opE4, &&opE5, &&opE6, &&opE7,
&&opE8, &&opE9, &&opEA, &&opEB, &&opEC, &&opED, &&opEE, &&opEF,
&&opF0, &&opF1, &&opF2, &&opF3, &&opF4, &&opF5, &&opF6, &&opF7,
&&opF8, &&opF9, &&opFA, &&opFB, &&opFC, &&opFD, &&opFE, &&opFF
#endif // NES6502_JUMPTABLE
remaining_cycles = timeslice_cycles;
GET_GLOBAL_REGS();
// check for DMA cycle burning
if (cpu.burn_cycles && remaining_cycles > 0) {
int burn_for;
burn_for = MIN(remaining_cycles, cpu.burn_cycles);
ADD_CYCLES(burn_for);
cpu.burn_cycles -= burn_for;
IRQ_PROC();
OPCODE_END
// Continue until we run out of cycles
while (remaining_cycles > 0) {
switch (bank_readbyte(PC++)) {
OPCODE_BEGIN(00) // BRK
BRK();
OPCODE_END
OPCODE_BEGIN(01) // ORA ($nn,X)
ORA(6, INDIR_X_BYTE);
OPCODE_END
OPCODE_BEGIN(02) // JAM
OPCODE_BEGIN(12) // JAM
OPCODE_BEGIN(22) // JAM
OPCODE_BEGIN(32) // JAM
OPCODE_BEGIN(42) // JAM
OPCODE_BEGIN(52) // JAM
OPCODE_BEGIN(62) // JAM
OPCODE_BEGIN(72) // JAM
OPCODE_BEGIN(92) // JAM
OPCODE_BEGIN(B2) // JAM
OPCODE_BEGIN(D2) // JAM
OPCODE_BEGIN(F2) // JAM
JAM();
// kill the CPU
OPCODE_END
OPCODE_BEGIN(03)
SLO(8, INDIR_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(04) // NOP $nn
OPCODE_BEGIN(44) // NOP $nn
OPCODE_BEGIN(64) // NOP $nn
DOP(3);
OPCODE_END
OPCODE_BEGIN(05) // ORA $nn
ORA(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(06) // ASL $nn
ASL(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(07) // SLO $nn
SLO(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(08) // PHP
PHP();
OPCODE_END
OPCODE_BEGIN(09) // ORA #$nn
ORA(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(0A) // ASL A
ASL_A();
OPCODE_END
OPCODE_BEGIN(0B) // ANC #$nn
ANC(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(0C) // NOP $nnnn
TOP();
OPCODE_END
OPCODE_BEGIN(0D) // ORA $nnnn
ORA(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(0E) // ASL $nnnn
ASL(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(0F) // SLO $nnnn
SLO(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(10) // BPL $nnnn
BPL();
OPCODE_END
OPCODE_BEGIN(11) // ORA ($nn),Y
ORA(5, INDIR_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(13) // SLO ($nn),Y
SLO(8, INDIR_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(14) // NOP $nn,X
OPCODE_BEGIN(34) // NOP
OPCODE_BEGIN(54) // NOP $nn,X
OPCODE_BEGIN(74) // NOP $nn,X
OPCODE_BEGIN(D4) // NOP $nn,X
OPCODE_BEGIN(F4) // NOP ($nn,X)
DOP(4);
OPCODE_END
OPCODE_BEGIN(15) // ORA $nn,X
ORA(4, ZP_IND_X_BYTE);
OPCODE_END
OPCODE_BEGIN(16) // ASL $nn,X
ASL(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(17) // SLO $nn,X
SLO(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(18) // CLC
CLC();
OPCODE_END
OPCODE_BEGIN(19) // ORA $nnnn,Y
ORA(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(1A) // NOP
OPCODE_BEGIN(3A) // NOP
OPCODE_BEGIN(5A) // NOP
OPCODE_BEGIN(7A) // NOP
OPCODE_BEGIN(DA) // NOP
OPCODE_BEGIN(FA) // NOP
NOP();
OPCODE_END
OPCODE_BEGIN(1B) // SLO $nnnn,Y
SLO(7, ABS_IND_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(1C) // NOP $nnnn,X
OPCODE_BEGIN(3C) // NOP $nnnn,X
OPCODE_BEGIN(5C) // NOP $nnnn,X
OPCODE_BEGIN(7C) // NOP $nnnn,X
OPCODE_BEGIN(DC) // NOP $nnnn,X
OPCODE_BEGIN(FC) // NOP $nnnn,X
TOP();
OPCODE_END
OPCODE_BEGIN(1D) // ORA $nnnn,X
ORA(4, ABS_IND_X_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(1E) // ASL $nnnn,X
ASL(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(1F) // SLO $nnnn,X
SLO(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(20) // JSR $nnnn
JSR();
OPCODE_END
OPCODE_BEGIN(21) // AND ($nn,X)
AND(6, INDIR_X_BYTE);
OPCODE_END
OPCODE_BEGIN(23) // RLA ($nn,X)
RLA(8, INDIR_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(24) // BIT $nn
BIT(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(25) // AND $nn
AND(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(26) // ROL $nn
ROL(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(27) // RLA $nn
RLA(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(28) // PLP
PLP();
OPCODE_END
OPCODE_BEGIN(29) // AND #$nn
AND(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(2A) // ROL A
ROL_A();
OPCODE_END
OPCODE_BEGIN(2B) // ANC #$nn
OPCODE_END
OPCODE_BEGIN(2C) // BIT $nnnn
BIT(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(2D) // AND $nnnn
AND(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(2E) // ROL $nnnn
ROL(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(2F) // RLA $nnnn
RLA(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(30) // BMI $nnnn
BMI();
OPCODE_END
OPCODE_BEGIN(31) // AND ($nn),Y
AND(5, INDIR_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(33) // RLA ($nn),Y
RLA(8, INDIR_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(35) // AND $nn,X
AND(4, ZP_IND_X_BYTE);
OPCODE_END
OPCODE_BEGIN(36) // ROL $nn,X
ROL(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(37) // RLA $nn,X
RLA(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(38) // SEC
SEC();
OPCODE_END
OPCODE_BEGIN(39) // AND $nnnn,Y
AND(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(3B) // RLA $nnnn,Y
RLA(7, ABS_IND_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(3D) // AND $nnnn,X
AND(4, ABS_IND_X_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(3E) // ROL $nnnn,X
ROL(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(3F) // RLA $nnnn,X
RLA(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(40) // RTI
RTI();
OPCODE_END
OPCODE_BEGIN(41) // EOR ($nn,X)
EOR(6, INDIR_X_BYTE);
OPCODE_END
OPCODE_BEGIN(43) // SRE ($nn,X)
SRE(8, INDIR_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(45) // EOR $nn
EOR(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(46) // LSR $nn
LSR(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(47) // SRE $nn
SRE(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(48) // PHA
PHA();
OPCODE_END
OPCODE_BEGIN(49) // EOR #$nn
EOR(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(4A) // LSR A
LSR_A();
OPCODE_END
OPCODE_BEGIN(4B) // ASR #$nn
ASR(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(4C) // JMP $nnnn
JMP_ABSOLUTE();
OPCODE_END
OPCODE_BEGIN(4D) // EOR $nnnn
EOR(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(4E) // LSR $nnnn
LSR(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(4F) // SRE $nnnn
SRE(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(50) // BVC $nnnn
BVC();
OPCODE_END
OPCODE_BEGIN(51) // EOR ($nn),Y
EOR(5, INDIR_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(53) // SRE ($nn),Y
SRE(8, INDIR_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(55) // EOR $nn,X
EOR(4, ZP_IND_X_BYTE);
OPCODE_END
OPCODE_BEGIN(56) // LSR $nn,X
LSR(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(57) // SRE $nn,X
SRE(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(58) // CLI
CLI();
OPCODE_END
OPCODE_BEGIN(59) // EOR $nnnn,Y
EOR(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(5B) // SRE $nnnn,Y
SRE(7, ABS_IND_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(5D) // EOR $nnnn,X
EOR(4, ABS_IND_X_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(5E) // LSR $nnnn,X
LSR(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(5F) // SRE $nnnn,X
SRE(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(60) // RTS
RTS();
OPCODE_END
OPCODE_BEGIN(61) // ADC ($nn,X)
ADC(6, INDIR_X_BYTE);
OPCODE_END
OPCODE_BEGIN(63) // RRA ($nn,X)
RRA(8, INDIR_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(65) // ADC $nn
ADC(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(66) // ROR $nn
ROR(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(67) // RRA $nn
RRA(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(68) // PLA
PLA();
OPCODE_END
OPCODE_BEGIN(69) // ADC #$nn
ADC(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(6A) // ROR A
ROR_A();
OPCODE_END
OPCODE_BEGIN(6B) // ARR #$nn
ARR(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(6C) // JMP ($nnnn)
JMP_INDIRECT();
OPCODE_END
OPCODE_BEGIN(6D) // ADC $nnnn
ADC(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(6E) // ROR $nnnn
ROR(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(6F) // RRA $nnnn
RRA(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(70) // BVS $nnnn
BVS();
OPCODE_END
OPCODE_BEGIN(71) // ADC ($nn),Y
ADC(5, INDIR_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(73) // RRA ($nn),Y
RRA(8, INDIR_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(75) // ADC $nn,X
ADC(4, ZP_IND_X_BYTE);
OPCODE_END
OPCODE_BEGIN(76) // ROR $nn,X
ROR(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(77) // RRA $nn,X
RRA(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(78) // SEI
SEI();
OPCODE_END
OPCODE_BEGIN(79) // ADC $nnnn,Y
ADC(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(7B) // RRA $nnnn,Y
RRA(7, ABS_IND_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(7D) // ADC $nnnn,X
ADC(4, ABS_IND_X_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(7E) // ROR $nnnn,X
ROR(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(7F) // RRA $nnnn,X
RRA(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(80) // NOP #$nn
OPCODE_BEGIN(82) // NOP #$nn
OPCODE_BEGIN(89) // NOP #$nn
OPCODE_BEGIN(C2) // NOP #$nn
OPCODE_BEGIN(E2) // NOP #$nn
DOP(2);
OPCODE_END
OPCODE_BEGIN(81) // STA ($nn,X)
STA(6, INDIR_X_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(83) // SAX ($nn,X)
SAX(6, INDIR_X_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(84) // STY $nn
STY(3, ZERO_PAGE_ADDR, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(85) // STA $nn
STA(3, ZERO_PAGE_ADDR, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(86) // STX $nn
STX(3, ZERO_PAGE_ADDR, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(87) // SAX $nn
SAX(3, ZERO_PAGE_ADDR, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(88) // DEY
DEY();
OPCODE_END
OPCODE_BEGIN(8A) // TXA
TXA();
OPCODE_END
OPCODE_BEGIN(8B) // ANE #$nn
ANE(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(8C) // STY $nnnn
STY(4, ABSOLUTE_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(8D) // STA $nnnn
STA(4, ABSOLUTE_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(8E) // STX $nnnn
STX(4, ABSOLUTE_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(8F) // SAX $nnnn
SAX(4, ABSOLUTE_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(90) // BCC $nnnn
BCC();
OPCODE_END
OPCODE_BEGIN(91) // STA ($nn),Y
STA(6, INDIR_Y_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(93) // SHA ($nn),Y
SHA(6, INDIR_Y_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(94) // STY $nn,X
STY(4, ZP_IND_X_ADDR, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(95) // STA $nn,X
STA(4, ZP_IND_X_ADDR, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(96) // STX $nn,Y
STX(4, ZP_IND_Y_ADDR, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(97) // SAX $nn,Y
SAX(4, ZP_IND_Y_ADDR, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(98) // TYA
TYA();
OPCODE_END
OPCODE_BEGIN(99) // STA $nnnn,Y
STA(5, ABS_IND_Y_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(9A) // TXS
TXS();
OPCODE_END
OPCODE_BEGIN(9B) // SHS $nnnn,Y
SHS(5, ABS_IND_Y_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(9C) // SHY $nnnn,X
SHY(5, ABS_IND_X_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(9D) // STA $nnnn,X
STA(5, ABS_IND_X_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(9E) // SHX $nnnn,Y
SHX(5, ABS_IND_Y_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(9F) // SHA $nnnn,Y
SHA(5, ABS_IND_Y_ADDR, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(A0) // LDY #$nn
LDY(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(A1) // LDA ($nn,X)
LDA(6, INDIR_X_BYTE);
OPCODE_END
OPCODE_BEGIN(A2) // LDX #$nn
LDX(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(A3) // LAX ($nn,X)
LAX(6, INDIR_X_BYTE);
OPCODE_END
OPCODE_BEGIN(A4) // LDY $nn
LDY(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(A5) // LDA $nn
LDA(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(A6) // LDX $nn
LDX(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(A7) // LAX $nn
LAX(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(A8) // TAY
TAY();
OPCODE_END
OPCODE_BEGIN(A9) // LDA #$nn
LDA(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(AA) // TAX
TAX();
OPCODE_END
OPCODE_BEGIN(AB) // LXA #$nn
LXA(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(AC) // LDY $nnnn
LDY(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(AD) // LDA $nnnn
LDA(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(AE) // LDX $nnnn
LDX(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(AF) // LAX $nnnn
LAX(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(B0) // BCS $nnnn
BCS();
OPCODE_END
OPCODE_BEGIN(B1) // LDA ($nn),Y
LDA(5, INDIR_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(B3) // LAX ($nn),Y
LAX(5, INDIR_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(B4) // LDY $nn,X
LDY(4, ZP_IND_X_BYTE);
OPCODE_END
OPCODE_BEGIN(B5) // LDA $nn,X
LDA(4, ZP_IND_X_BYTE);
OPCODE_END
OPCODE_BEGIN(B6) // LDX $nn,Y
LDX(4, ZP_IND_Y_BYTE);
OPCODE_END
OPCODE_BEGIN(B7) // LAX $nn,Y
LAX(4, ZP_IND_Y_BYTE);
OPCODE_END
OPCODE_BEGIN(B8) // CLV
CLV();
OPCODE_END
OPCODE_BEGIN(B9) // LDA $nnnn,Y
LDA(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(BA) // TSX
TSX();
OPCODE_END
OPCODE_BEGIN(BB) // LAS $nnnn,Y
LAS(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(BC) // LDY $nnnn,X
LDY(4, ABS_IND_X_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(BD) // LDA $nnnn,X
LDA(4, ABS_IND_X_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(BE) // LDX $nnnn,Y
LDX(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(BF) // LAX $nnnn,Y
LAX(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(C0) // CPY #$nn
CPY(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(C1) // CMP ($nn,X)
CMP(6, INDIR_X_BYTE);
OPCODE_END
OPCODE_BEGIN(C3) // DCP ($nn,X)
DCP(8, INDIR_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(C4) // CPY $nn
CPY(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(C5) // CMP $nn
CMP(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(C6) // DEC $nn
_DEC(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(C7) // DCP $nn
DCP(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(C8) // INY
INY();
OPCODE_END
OPCODE_BEGIN(C9) // CMP #$nn
CMP(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(CA) // DEX
DEX();
OPCODE_END
OPCODE_BEGIN(CB) // SBX #$nn
SBX(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(CC) // CPY $nnnn
CPY(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(CD) // CMP $nnnn
CMP(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(CE) // DEC $nnnn
_DEC(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(CF) // DCP $nnnn
DCP(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(D0) // BNE $nnnn
BNE();
OPCODE_END
OPCODE_BEGIN(D1) // CMP ($nn),Y
CMP(5, INDIR_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(D3) // DCP ($nn),Y
DCP(8, INDIR_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(D5) // CMP $nn,X
CMP(4, ZP_IND_X_BYTE);
OPCODE_END
OPCODE_BEGIN(D6) // DEC $nn,X
_DEC(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(D7) // DCP $nn,X
DCP(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(D8) // CLD
CLD();
OPCODE_END
OPCODE_BEGIN(D9) // CMP $nnnn,Y
CMP(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(DB) // DCP $nnnn,Y
DCP(7, ABS_IND_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(DD) // CMP $nnnn,X
CMP(4, ABS_IND_X_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(DE) // DEC $nnnn,X
_DEC(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(DF) // DCP $nnnn,X
DCP(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(E0) // CPX #$nn
CPX(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(E1) // SBC ($nn,X)
SBC(6, INDIR_X_BYTE);
OPCODE_END
OPCODE_BEGIN(E3) // ISB ($nn,X)
ISB(8, INDIR_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(E4) // CPX $nn
CPX(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(E5) // SBC $nn
SBC(3, ZERO_PAGE_BYTE);
OPCODE_END
OPCODE_BEGIN(E6) // INC $nn
INC(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(E7) // ISB $nn
ISB(5, ZERO_PAGE, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(E8) // INX
INX();
OPCODE_END
OPCODE_BEGIN(E9) // SBC #$nn
OPCODE_BEGIN(EB) // USBC #$nn
SBC(2, IMMEDIATE_BYTE);
OPCODE_END
OPCODE_BEGIN(EA) // NOP
NOP();
OPCODE_END
OPCODE_BEGIN(EC) // CPX $nnnn
CPX(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(ED) // SBC $nnnn
SBC(4, ABSOLUTE_BYTE);
OPCODE_END
OPCODE_BEGIN(EE) // INC $nnnn
INC(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(EF) // ISB $nnnn
ISB(6, ABSOLUTE, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(F0) // BEQ $nnnn
BEQ();
OPCODE_END
OPCODE_BEGIN(F1) // SBC ($nn),Y
SBC(5, INDIR_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(F3) // ISB ($nn),Y
ISB(8, INDIR_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(F5) // SBC $nn,X
SBC(4, ZP_IND_X_BYTE);
OPCODE_END
OPCODE_BEGIN(F6) // INC $nn,X
INC(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(F7) // ISB $nn,X
ISB(6, ZP_IND_X, ZP_WRITEBYTE, baddr);
OPCODE_END
OPCODE_BEGIN(F8) // SED
SED();
OPCODE_END
OPCODE_BEGIN(F9) // SBC $nnnn,Y
SBC(4, ABS_IND_Y_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(FB) // ISB $nnnn,Y
ISB(7, ABS_IND_Y, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(FD) // SBC $nnnn,X
SBC(4, ABS_IND_X_BYTE_READ);
OPCODE_END
OPCODE_BEGIN(FE) // INC $nnnn,X
INC(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
OPCODE_BEGIN(FF) // ISB $nnnn,X
ISB(7, ABS_IND_X, mem_writebyte, addr);
OPCODE_END
end_execute:
STORE_LOCAL_REGS();
return (cpu.total_cycles - old_cycles);
void nes6502_reset(void) // Issue a CPU Reset
cpu.p_reg = Z_FLAG | R_FLAG | I_FLAG; // Reserved bit always 1
cpu.int_pending = 0; // No pending interrupts
cpu.int_latency = 0; // No latent interrupts
cpu.pc_reg = bank_readword(RESET_VECTOR); // Fetch reset vector
cpu.burn_cycles = RESET_CYCLES;
cpu.jammed = false;
#define DECLARE_LOCAL_REGS uint32_t PC; uint8_t A, X, Y, S; uint8_t n_flag, v_flag, b_flag; uint8_t d_flag, i_flag, z_flag, c_flag;
void nes6502_nmi(void) { // Non-maskable interrupt
DECLARE_LOCAL_REGS
if (false == cpu.jammed)
GET_GLOBAL_REGS();
NMI_PROC();
cpu.burn_cycles += INT_CYCLES;
STORE_LOCAL_REGS();
void nes6502_irq(void) { // Interrupt request
DECLARE_LOCAL_REGS
if (false == cpu.jammed) {
GET_GLOBAL_REGS();
if (0 == i_flag) {
IRQ_PROC();
cpu.int_pending = 1;
STORE_LOCAL_REGS();
void nes6502_burn(int cycles) { // Set dead cycle period
cpu.burn_cycles += cycles;
void nes6502_release(void) { // Release our timeslice
//NES.C part
void nes_setfiq(uint8_t value) {
nes.fiq_state = value;
nes.fiq_cycles = (int) NES_FIQ_PERIOD;
void nes_nmi(void) {
nes6502_nmi();
//PPU.C:
// PPU access
#define PPU_MEM(x) ppu.page[(x) >> 10][(x)]
// Background (color 0) and solid sprite pixel flags
#define BG_TRANS 0x80
#define SP_PIXEL 0x40
#define BG_CLEAR(V) ((V) & BG_TRANS)
#define BG_SOLID(V) (0 == BG_CLEAR(V))
#define SP_CLEAR(V) (0 == ((V) & SP_PIXEL))
// Full BG color
#define FULLBG (ppu.palette[0] | BG_TRANS)
void ppu_displaysprites(bool display) {
ppu.drawsprites = display;
void ppu_getcontext(ppu_t *dest_ppu);
void ppu_getcontext(ppu_t *dest_ppu) {
int nametab[4];
*dest_ppu = ppu;
// we can't just copy contexts here, because more than likely,
// the top 8 pages of the ppu are pointing to internal PPU memory,
// which means we need to recalculate the page pointers.
// TODO: we can either get rid of the page pointing in the code,
// or add more robust checks to make sure that pages 8-15 are
// definitely pointing to internal PPU RAM, not just something
// that some crazy mapper paged in.
nametab[0] = (ppu.page[8] - ppu.nametab + 0x2000) >> 10;
nametab[1] = (ppu.page[9] - ppu.nametab + 0x2400) >> 10;
nametab[2] = (ppu.page[10] - ppu.nametab + 0x2800) >> 10;
nametab[3] = (ppu.page[11] - ppu.nametab + 0x2C00) >> 10;
dest_ppu->page[8] = dest_ppu->nametab + (nametab[0] << 10) - 0x2000;
dest_ppu->page[9] = dest_ppu->nametab + (nametab[1] << 10) - 0x2400;
dest_ppu->page[10] = dest_ppu->nametab + (nametab[2] << 10) - 0x2800;
dest_ppu->page[11] = dest_ppu->nametab + (nametab[3] << 10) - 0x2C00;
dest_ppu->page[12] = dest_ppu->page[8] - 0x1000;
dest_ppu->page[13] = dest_ppu->page[9] - 0x1000;
dest_ppu->page[14] = dest_ppu->page[10] - 0x1000;
dest_ppu->page[15] = dest_ppu->page[11] - 0x1000;
void ppu_setcontext(ppu_t *src_ppu);
void ppu_setcontext(ppu_t *src_ppu) {
int nametab[4];
ppu = *src_ppu;
nametab[0] = (src_ppu->page[8] - src_ppu->nametab + 0x2000) >> 10;
nametab[1] = (src_ppu->page[9] - src_ppu->nametab + 0x2400) >> 10;
nametab[2] = (src_ppu->page[10] - src_ppu->nametab + 0x2800) >> 10;
nametab[3] = (src_ppu->page[11] - src_ppu->nametab + 0x2C00) >> 10;
ppu.page[8] = ppu.nametab + (nametab[0] << 10) - 0x2000;
ppu.page[9] = ppu.nametab + (nametab[1] << 10) - 0x2400;
ppu.page[10] = ppu.nametab + (nametab[2] << 10) - 0x2800;
ppu.page[11] = ppu.nametab + (nametab[3] << 10) - 0x2C00;
ppu.page[12] = ppu.page[8] - 0x1000;
ppu.page[13] = ppu.page[9] - 0x1000;
ppu.page[14] = ppu.page[10] - 0x1000;
ppu.page[15] = ppu.page[11] - 0x1000;
ppu_t *ppu_create(void);
ppu_t *ppu_create(void) {
static bool pal_generated = false;
ppu_t *temp;
if (NULL == temp) temp = (ppu_t*) malloc(sizeof(ppu_t));
if (NULL == temp)
return NULL;
memset(temp, 0, sizeof(ppu_t));
temp->latchfunc = NULL;
temp->vromswitch = NULL;
temp->vram_present = false;
temp->drawsprites = true;
// TODO: probably a better way to do this...
if (false == pal_generated)
///pal_generate();
pal_generated = true;
///ppu_setdefaultpal(temp);
return temp;
void ppu_setpage(int size, int page_num, uint8_t *location)
// deliberately fall through
switch (size)
case 8:
ppu.page[page_num++] = location;
case 4:
case 2:
case 1:
// make sure $3000-$3F00 mirrors $2000-$2F00
void ppu_mirrorhipages(void)
void ppu_mirror(int nt1, int nt2, int nt3, int nt4)
ppu.page[8] = ppu.nametab + (nt1 << 10) - 0x2000;
ppu.page[9] = ppu.nametab + (nt2 << 10) - 0x2400;
ppu.page[10] = ppu.nametab + (nt3 << 10) - 0x2800;
ppu.page[11] = ppu.nametab + (nt4 << 10) - 0x2C00;
// bleh, for snss
uint8_t *ppu_getpage(int page)
return ppu.page[page];
void mem_trash(uint8_t *buffer, int length)
int i;
for (i = 0; i < length; i++)
buffer[i] = (uint8_t) rand();
// reset state of ppu
void ppu_reset()
///if (HARD_RESET == reset_type)
mem_trash(ppu.oam, 256);
///memset(ppu.oam, 0, 256);
ppu.ctrl0 = 0;
ppu.ctrl1 = PPU_CTRL1F_OBJON | PPU_CTRL1F_BGON;
ppu.stat = 0;
ppu.flipflop = 0;
ppu.vaddr_latch = 0x2000;
ppu.vaddr = ppu.vaddr_latch = 0x2000;
ppu.oam_addr = 0;
ppu.tile_xofs = 0;
ppu.latch = 0;
ppu.vram_accessible = true;
// we render a scanline of graphics first so we know exactly
// where the sprite 0 strike is going to occur (in terms of
// cpu cycles), using the relation that 3 pixels == 1 cpu cycle
void ppu_setstrike(int x_loc)
if (false == ppu.strikeflag)
ppu.strikeflag = true;
// 3 pixels per cpu cycle
ppu.strike_cycle = nes6502_getcycles(false) + (x_loc / 3);
void ppu_oamdma(uint8_t value)
uint32_t cpu_address;
uint8_t oam_loc;
cpu_address = (uint32_t) (value << 8);
// Sprite DMA starts at the current SPRRAM address
oam_loc = ppu.oam_addr;
do
ppu.oam[oam_loc++] = nes6502_getbyte(cpu_address++);
while (oam_loc != ppu.oam_addr);
// TODO: enough with houdini
cpu_address -= 256;
// Odd address in $2003
if ((ppu.oam_addr >> 2) & 1) {
for (oam_loc = 4; oam_loc < 8; oam_loc++) ppu.oam[oam_loc] = nes6502_getbyte(cpu_address++);
cpu_address += 248;
for (oam_loc = 0; oam_loc < 4; oam_loc++) ppu.oam[oam_loc] = nes6502_getbyte(cpu_address++);
} else { // Even address in $2003
for (oam_loc = 0; oam_loc < 8; oam_loc++)
// make the CPU spin for DMA cycles
nes6502_burn(513);
nes6502_release();
void ppu_writehigh(uint32_t address, uint8_t value)
switch (address)
case PPU_OAMDMA:
ppu_oamdma(value);
case PPU_JOY0:
// VS system VROM switching - bleh!
if (ppu.vromswitch) ppu.vromswitch(value);
// see if we need to strobe them joypads
value &= 1;
if (0 == value && ppu.strobe) input_strobe();
ppu.strobe = value;
//NES Controller strobe
/// digitalWrite(NESCTRL_Latch, HIGH);
/// digitalWrite(NESCTRL_Latch, LOW);
case PPU_JOY1: // frame IRQ control
nes_setfiq(value);
default:
uint8_t ppu_readhigh(uint32_t address) {
uint8_t value;
switch (address)
case PPU_JOY0:
value = get_pad0();
/// if (digitalRead(NESCTRL_Data) == LOW) value=255;
/// digitalWrite(NESCTRL_Clock, HIGH);
/// digitalWrite(NESCTRL_Clock, LOW);
///pad0_readcount++;
case PPU_JOY1:
value = 0;
default:
value = 0xFF;
return value;
// Read from $2000-$2007
uint8_t ppu_read(uint32_t address) {
uint8_t value;
// handle mirrored reads up to $3FFF
switch (address & 0x2007)
case PPU_STAT:
value = (ppu.stat & 0xE0) | (ppu.latch & 0x1F);
if (ppu.strikeflag) {
if (nes6502_getcycles(false) >= ppu.strike_cycle)
value |= PPU_STATF_STRIKE;
// clear both vblank flag and vram address flipflop
ppu.stat &= ~PPU_STATF_VBLANK;
ppu.flipflop = 0;
case PPU_VDATA:
// buffered VRAM reads
value = ppu.latch = ppu.vdata_latch;
// VRAM only accessible during VBL
if ((ppu.bg_on || ppu.obj_on) && !ppu.vram_accessible) {
ppu.vdata_latch = 0xFF;
///nes_log_printf("VRAM read at $%04X, scanline %d\n", ppu.vaddr, nes_getcontextptr()->scanline);
uint32_t addr = ppu.vaddr;
if (addr >= 0x3000) addr -= 0x1000;
ppu.vdata_latch = PPU_MEM(addr);
ppu.vaddr += ppu.vaddr_inc;
ppu.vaddr &= 0x3FFF;
case PPU_OAMDATA:
case PPU_CTRL0:
case PPU_CTRL1:
case PPU_OAMADDR:
case PPU_SCROLL:
case PPU_VADDR:
default:
value = ppu.latch;
return value;
// Write to $2000-$2007
void ppu_write(uint32_t address, uint8_t value) {
// write goes into ppu latch...
ppu.latch = value;
case PPU_CTRL0:
ppu.ctrl0 = value;
ppu.obj_height = (value & PPU_CTRL0F_OBJ16) ? 16 : 8;
ppu.bg_base = (value & PPU_CTRL0F_BGADDR) ? 0x1000 : 0;
ppu.obj_base = (value & PPU_CTRL0F_OBJADDR) ? 0x1000 : 0;
ppu.vaddr_inc = (value & PPU_CTRL0F_ADDRINC) ? 32 : 1;
ppu.tile_nametab = value & PPU_CTRL0F_NAMETAB;
// Mask out bits 10 & 11 in the ppu latch
ppu.vaddr_latch &= ~0x0C00;
ppu.vaddr_latch |= ((value & 3) << 10);
case PPU_CTRL1:
ppu.ctrl1 = value;
ppu.obj_on = (value & PPU_CTRL1F_OBJON) ? true : false;
ppu.bg_on = (value & PPU_CTRL1F_BGON) ? true : false;
ppu.obj_mask = (value & PPU_CTRL1F_OBJMASK) ? false : true;
ppu.bg_mask = (value & PPU_CTRL1F_BGMASK) ? false : true;
case PPU_OAMADDR:
ppu.oam_addr = value;
case PPU_OAMDATA:
ppu.oam[ppu.oam_addr++] = value;
case PPU_SCROLL:
if (0 == ppu.flipflop) {
// Mask out bits 4 - 0 in the ppu latch
ppu.vaddr_latch &= ~0x001F;
ppu.vaddr_latch |= (value >> 3); // Tile number
ppu.tile_xofs = (value & 7); // Tile offset (0-7 pix)
// Mask out bits 14-12 and 9-5 in the ppu latch
ppu.vaddr_latch &= ~0x73E0;
ppu.vaddr_latch |= ((value & 0xF8) << 2); // Tile number
ppu.vaddr_latch |= ((value & 7) << 12); // Tile offset (0-7 pix)
ppu.flipflop ^= 1;
case PPU_VADDR:
// Mask out bits 15-8 in ppu latch
ppu.vaddr_latch &= ~0xFF00;
ppu.vaddr_latch |= ((value & 0x3F) << 8);
// Mask out bits 7-0 in ppu latch
ppu.vaddr_latch &= ~0x00FF;
ppu.vaddr_latch |= value;
ppu.vaddr = ppu.vaddr_latch;
ppu.flipflop ^= 1;
case PPU_VDATA:
if (ppu.vaddr < 0x3F00) {
// VRAM only accessible during scanlines 241-260
///nes_log_printf("VRAM write to $%04X, scanline %d\n", ppu.vaddr, nes_getcontextptr()->scanline);
PPU_MEM(ppu.vaddr) = 0xFF; // corrupt
if (false == ppu.vram_present && addr >= 0x3000) ppu.vaddr -= 0x1000;
PPU_MEM(addr) = value;
if (0 == (ppu.vaddr & 0x0F)) {
int i;
for (i = 0; i < 8; i ++) ppu.palette[i << 2] = (value & 0x3F) | BG_TRANS;
} else if (ppu.vaddr & 3) {
ppu.palette[ppu.vaddr & 0x1F] = value & 0x3F;
default:
