Hello,
I'm doing a project that uses sound outputs. I found a library in the internet (GitHub - TMRh20/TMRpcm: Arduino library for asynchronous playback of PCM/WAV files direct from SD card. Arduino Uno,Nano,Mega etc supported) and used the available code, which is:
#include <SD.h> // need to include the SD library
//#define SD_ChipSelectPin 53 //example uses hardware SS pin 53 on Mega2560
#define SD_ChipSelectPin 10 //using digital pin 4 on arduino nano 328
#include <TMRpcm.h> // also need to include this library...
TMRpcm tmrpcm; // create an object for use in this sketch
char mychar;
void setup(){
tmrpcm.speakerPin = 9; //11 on Mega, 9 on Uno, Nano, etc
if (!SD.begin(SD_ChipSelectPin)) { // see if the card is present and can be initialized:
Serial.println("SD fail");
return; // don't do anything more if not
tmrpcm.play("beware.wav"); //the sound file "music" will play each time the arduino powers up, or is reset
void loop(){
if(Serial.available()){
mychar = Serial.read();
if(mychar == 'o'){ //send the letter p over the serial monitor to start playback
tmrpcm.play("helpyou.wav");
} else if(mychar == 'r'){ //send the letter p over the serial monitor to start playback
tmrpcm.play("chortle.wav");
} else if(mychar == 'q'){ //send the letter p over the serial monitor to start playback
} else if(mychar == 'p'){
else if(mychar == 'w'){ //send the letter p over the serial monitor to start playback
tmrpcm.play("impresiv.wav");
else if(mychar == 't'){ //send the letter p over the serial monitor to start playback
tmrpcm.play("seekyoda.wav");
else if(mychar == 'y'){ //send the letter p over the serial monitor to start playback
tmrpcm.play("sensefear.wav");
else if(mychar == 'u'){ //send the letter p over the serial monitor to start playback
tmrpcm.play("strongami.wav");
else if(mychar == 'i'){ //send the letter p over the serial monitor to start playback
tmrpcm.play("whyhere.wav");
Basically, it receives an input from the keyboard and plays an audio file stored in microSD attached to the Arduino Board through a shield.
I installed the library and it went OK. However, when I try to compile it, it tells me that a fatal error occurred and that SdFile.h is missing, even though it's not!
Did anybody have this error already?
I'm using Arduino Uno.
Thank you.
