Attempting to code an LED animation that looks like a comet running down the length of the led strip of 422 leds. The beginning and the end of the strip are budded against each other, and ive been trying different approaches to get the effect to immediately start once the end is hit to avoid any visual breaks. Right now i have the code running an extra 40 pixels to entirely hide the animation once it hits the end or else the pixel will remain on. The entire effect is 40 pixels in length ie it has to run those extra pixels to create a turned off strip.
Im trying to avoid a for loop in a for loop to draw the 40 pixel effect, so ive setting the color of each pixel and then show it. The problem is when the counter hits zero, its telling negative number of pixels location (ie number -40 pixel location) a color value when instead it should be telling pixel (422-40 = 382 pixel) that command. Any help would be appreciated, thanks.
#define PIN 11
#define NUM_LEDS 422
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_WRGB + NEO_KHZ800);
int OFFSET;
strip.begin();
strip.show(); // Initialize all piiels to 'off'
for (int i = 0; i < NUM_LEDS + 40; i++) {
strip.setPixelColor(i, strip.Color(255, 255, 0, 255));
OFFSET = 1;
strip.setPixelColor(i - OFFSET, strip.Color(243, 243, 0, 243));
OFFSET = 2;
strip.setPixelColor(i - OFFSET, strip.Color(236, 236, 0, 236));
OFFSET = 3;
strip.setPixelColor(i - OFFSET, strip.Color(230, 230, 0, 230));
OFFSET = 4;
strip.setPixelColor(i - OFFSET, strip.Color(224, 224, 0, 224));
OFFSET = 5;
strip.setPixelColor(i - OFFSET, strip.Color(218, 218, 0, 218));
OFFSET = 6;
strip.setPixelColor(i - OFFSET, strip.Color(212, 212, 0, 212));
OFFSET = 7;
strip.setPixelColor(i - OFFSET, strip.Color(205, 205, 0, 205));
OFFSET = 8;
strip.setPixelColor(i - OFFSET, strip.Color(199, 199, 0, 199));
OFFSET = 9;
strip.setPixelColor(i - OFFSET, strip.Color(193, 193, 0, 193));
OFFSET = 10;
strip.setPixelColor(i - OFFSET, strip.Color(187, 187, 0, 187));
OFFSET = 11;
strip.setPixelColor(i - OFFSET, strip.Color(181, 181, 0, 181));
OFFSET = 12;
strip.setPixelColor(i - OFFSET, strip.Color(174, 174, 0, 174));
OFFSET = 13;
strip.setPixelColor(i - OFFSET, strip.Color(168, 168, 0, 168));
OFFSET = 14;
strip.setPixelColor(i - OFFSET, strip.Color(162, 162, 0, 162));
OFFSET = 15;
strip.setPixelColor(i - OFFSET, strip.Color(156, 156, 0, 156));
OFFSET = 16;
strip.setPixelColor(i - OFFSET, strip.Color(150, 150, 0, 150));
OFFSET = 17;
strip.setPixelColor(i - OFFSET, strip.Color(143, 143, 0, 143));
OFFSET = 18;
strip.setPixelColor(i - OFFSET, strip.Color(137, 137, 0, 137));
OFFSET = 19;
strip.setPixelColor(i - OFFSET, strip.Color(131, 131, 0, 131));
OFFSET = 20;
strip.setPixelColor(i - OFFSET, strip.Color(125, 125, 0, 125));
OFFSET = 21;
strip.setPixelColor(i - OFFSET, strip.Color(119, 119, 0, 119));
OFFSET = 22;
strip.setPixelColor(i - OFFSET, strip.Color(112, 112, 0, 112));
OFFSET = 23;
strip.setPixelColor(i - OFFSET, strip.Color(106, 106, 0, 106));
OFFSET = 24;
strip.setPixelColor(i - OFFSET, strip.Color(100, 100, 0, 100));
OFFSET = 25;
strip.setPixelColor(i - OFFSET, strip.Color(90, 90, 0, 90));
OFFSET = 26;
strip.setPixelColor(i - OFFSET, strip.Color(70, 70, 0, 70));
OFFSET = 27;
strip.setPixelColor(i - OFFSET, strip.Color(55, 55, 0, 55));
OFFSET = 28;
strip.setPixelColor(i - OFFSET, strip.Color(43, 43, 0, 43));
OFFSET = 29;
strip.setPixelColor(i - OFFSET, strip.Color(34, 34, 0, 34));
OFFSET = 30;
strip.setPixelColor(i - OFFSET, strip.Color(28, 28, 0, 28));
OFFSET = 31;
strip.setPixelColor(i - OFFSET, strip.Color(22, 22, 0, 22));
OFFSET = 32;
strip.setPixelColor(i - OFFSET, strip.Color(18, 18, 0, 18));
OFFSET = 33;
strip.setPixelColor(i - OFFSET, strip.Color(15, 15, 0, 15));
OFFSET = 34;
strip.setPixelColor(i - OFFSET, strip.Color(12, 12, 0, 12));
OFFSET = 35;
strip.setPixelColor(i - OFFSET, strip.Color(10, 10, 0, 10));
OFFSET = 36;
strip.setPixelColor(i - OFFSET, strip.Color(8, 8, 0, 8));
OFFSET = 37;
strip.setPixelColor(i - OFFSET, strip.Color(7, 7, 0, 7));
OFFSET = 38;
strip.setPixelColor(i - OFFSET, strip.Color(6, 6, 0, 6));
OFFSET = 39;
strip.setPixelColor(i - OFFSET, strip.Color(5, 5, 0, 5));
OFFSET = 40;
strip.setPixelColor(i - OFFSET, strip.Color(0, 0, 0, 0));
strip.show();
