Search for precise tutorial/help
Hi
I saw that I loose much memory with text strings
However the interface i build is identical on serial and on ethernet. I there a known technique/trick to do some kind of port redirection (apart using common pointers for the text)?
Another idea would be to renounce to ethernet in favor of a zigbee conexion but I was unable to find example of an arduino inserted in a zigbee environment and then managing it through a tuya gateway. Did you saw any ?
bgrigoriu:
O lot of reprogramming is needed ( low level int routines and ADC during interrupts, along with port manipulation is used).
Nothing faintly like that. You can think of the Mega as simply a Uno with 8x the memory. It also has three extra serial ports, which may be of value.
Nick_Pyner:
Nothing faintly like that. You can think of the Mega as a Uno with 8x the memory. It also has three extra serial ports, which may be of value.
OK ,
I will buy one . I saw it's less than 7 euros. I will parse the datasheet and see if it fits. The size of the Pro mega fits wit the project. Thanks a lot !
bgrigoriu:
Hi
my TelnetStream library, but it uses telnet client not a web browser
Juraj:
Thanks !
I will try.
I already have now more possible directions to look at than actual time.
This can be fun.
