Search function on lcd
Hi All,
How to search array values using search function on LCD shield(for example if i pressed number 2 the
stt & prices 2nd values to be displayed like Masal 70 and if i press number 16,it should display the value).Any one tried this type of function.Help please.
String Array Values
char Stt [100]={"Rice","Oil","Masal","HCare","HairC","Baby","Pickle","Oral Care","Dry Fruits","Noodles"};
int prices[] = {0, 52, 70, 15, 62, 75, 175, 58, 44, 17, 30};
Regards
JR
There are probably hundreds of ways to write this, but I'm assuming the function needs to return the two values to you. So I'd probably do something like:
  char buffer[10];
  int val, price, ret;
  if (Serial.available() > 0) {
    val = Serial.read() - '0';
    ret = FindItemData(val, buffer, &price);
    if (ret) {
      Serial.print(buffer);
      Serial.print("   ");
      Serial.println(price);
int FindItemData(int whichOne, char *item, int *price)
   static char *Stt[100]={"Rice","Oil","Masal","HCare","HairC","Baby","Pickle","Oral Care","Dry Fruits","Noodles"};
   static int prices[100] = {0, 52, 70, 15, 62, 75, 175, 58, 44, 17, 30};
   int flag = 0;
   if (whichOne < (sizeof(Stt) / sizeof(Stt[0]))) {
     strcpy(item, Stt[whichOne]);
     *price = prices[whichOne];
     flag = 1;
     *item = NULL;
     *price = -1;
     flag = 0;
   return flag;
Hi econjack,
First of all thanks for your code it's showing perfectly from 0 to 9,and if i type 10 it showing 1 and 0 values.Kindly suggest and how to implement this for LCD.
Output from serial
Rice 0
Oil 52
Masal 70
HCare 15
HairC 62
Baby 75
Pickle 175
Oral Care 58
Dry Fruits, 44
Noodles 17
Oil 52
Rice 0
Thanks & Regards
JR
Any please give me some suggestion.
Regards
JR
Hi econjack,
Output from serial
Rice 0
Oil 52
Masal 70
HCare 15
HairC 62
Baby 75
Pickle 175
Oral Care 58
Dry Fruits, 44
Noodles 17
Oil 52
Rice 0
Thanks & Regards
JR
My original code was only mean to be used for a single digit index:
If you want val to work with values greater than 9, you need to change the way the Serial input is handled and the search function:
  char buffer[10];
  int index, val, price, ret;
    index = Serial.readBytesUntil('\n', buffer, 9);  // Look for newline or max of 9 chars
    buffer[index] = '\0';                            // It's now a string
    val = atoi(buffer);                              // Now it's an int
    if (ret) {
      Serial.print("   ");
  static char *Stt[100] = {"Rice", "Oil", "Masal", "HCare", "HairC", "Baby", "Pickle", "Oral Care", "Dry Fruits", "Noodles"};
  int flag = 0;
  for (int i = 0; i < (sizeof(Stt) / sizeof(Stt[0])); i++) {
    if (prices[i] == whichOne) {
        strcpy(item, Stt[i]);
        *price = prices[i];
        flag = 1;
  return flag;
Hello econjack,
Thank you.But no output is displaying on serial.
Regards
JR
Hi econjack,
Sorry for sending you a private message for this programming question.
Regards
JR
Hello econjack,
I have mixed your old code in this.now it is showing perfectly.The changes i made in that code is copied below.Thanks for your kind help.
Regards
JR
  char buffer[10];
    if (ret) {
      Serial.print("   ");
  static char *Stt[100] = {"Rice", "Oil", "Masal", "HCare", "HairC", "Baby", "Pickle", "Oral Care", "Dry Fruits", "Noodles","Health","Fitness","Medi","Test"};
  static int prices[100] = {0, 52, 70, 15, 62, 75, 175, 58, 44, 17, 30,25,35,40};
  int flag = 0;
     flag = 1;
     *item = NULL;
     *price = -1;
     flag = 0;
  return flag;
The code I posted in #5 worked perfectly.
yes indeed.
Hi econjack,
How to change from serial to lcd using keypad.I tried several options nothing worked.Please give some suggestion.
  char buffer[10];
    if (ret) {
      Serial.print("   ");
Hi All,
How to change from serial to LCD using keypad.I tried several options nothing worked.Please give some suggestion.Below is the code
  char buffer[10];
  if (ret) {
      Serial.print("   ");
Is this code one of the options? Why show this one and not the others?
Can you write a test sketch that verifies that the keypad is connected?
Below is the complete code.The problem is it is working on serial,but implementing on lcd it only fetching 1st value only not going further.
Regards
JR
#include <LiquidCrystal.h>
#include "Keypad.h"
#include "Wire.h" // for I2C LCD
// Initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// keypad type definition
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char customKey;
int total = 0;
char keys[ROWS][COLS] =
{ {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {2, 3, 11, 12}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A2, A3, A4, A5}; // connect to the column pinouts of the keypad
int count = 0;
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  //Set the characters and column numbers.
  //lcd.init();
  lcd.begin(16, 2);
  // set up the switch pin as an input
  lcd.clear();
   //customKey = myKeypad.getKey();
   char key = keypad.getKey();
   switch(customKey)
     case 'C':
   guru();
  if (key != NO_KEY)
    lcd.print(key);
    count++;
         if (count == 17)
      lcd.clear();
      count = 0;
  static char *Stt[100] = {"Rice", "Oil", "Masal", "HCare", "HairC", "Baby", "Pickle", "Oral Care", "Dry Fruits", "Noodles", "Midha"};
  static int prices[100] = {0, 52, 70, 15, 62, 75, 175, 58, 44, 17, 30, 35};
  int flag = 0;
    flag = 1;
    *item = NULL;
    *price = -1;
    flag = 0;
  return flag;
void guru()
  char buffer[10];
  if (count>key) {
   // digitalRead;
    //count++;
       //index = Serial.readBytesUntil('\n', buffer, 9);  // Look for newline or max of 9 chars
    if (ret) {
      Serial.print("   ");
      delay(200);
      //lcd.clear();
Please some one give me a idea.
Regards
JR
Hi MorganS,
Any solutions or suggestions?.
Regards
JR
seejr:
Regards
JR
Don't cross post! Threads merged.
seejr:
Hi MorganS,
Regards
JR
Don't bump your thread after two minutes!
It works on serial, but not on LCD, eh? Very strange. Let me look into that for a couple of years.
Sorry for that.
Regards
JR
