search text in HTTP Response
Hi there! I am using Ethernet Arduino and I am trying to get some number values of a webpage HTTP Response. The only thing that I get from the response is "Temp1=25" So I have an inData char array which contains this text. I need to find a way to search for the text "Temp1=" and if there is in the inData array, then to point me the pointer value of "T".
I am trying pch = strstr (inData,"Temp1="); with no luck
Whe I check if pch is 0 or not I see that its value is not zero. But I dont know how to find out the value number. When I print pch to serial I get nothing.
pch will be the index to the test string if pch is not NULL. In your case
if(pch != NULL) Serial.println(&inData[pch]);
SurferTim: pch will be the index to the test string if pch is not NULL. In your case
Invalid types char[250] [char*] for array subscript
My HTTP Response will eventually more than 1 temps, and all I need to do, is to search a word in a char array and find out the pointer value of “T” if I am searching for “Temp”
My code: (keep in mind its has some testing variables that are not in use and that it uses a 7 segment too)
#include <SPI.h>
#include <Ethernet.h>
#include <SoftwareSerial.h>
// These are the Arduino pins required to create a software seiral
//  instance. We'll actually only use the TX pin.
const int softwareTx = 8;
const int softwareRx = 7;
SoftwareSerial s7s(softwareRx, softwareTx);
unsigned int counter = 0;  // This variable will count up to 65k
char tempString[10];  // Will be used with sprintf to create strings
char * pch;
// this must be unique
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// change to your network settings
IPAddress ip(192,168,10,194);
IPAddress gateway(192, 168, 10, 150);
IPAddress subnet(255, 255, 255, 0);
// change to your server
IPAddress server(134,124,157,124); // match-me.gr physical server
//Change to your domain name for virtual servers
char serverName[] = "www.mysite.gr";
// If no domain name, use the ip address above
// char serverName[] = "74.125.227.16";
// change to your server's port
int serverPort = 80;
EthernetClient client;
int totalCount = 0;
char pageAdd[64];
char *smsAT;
char inData[250]; // Allocate some space for the string
char inChar; // Where to store the character read
int index = 0; // Index into array; where to store the character
// set this to the number of milliseconds delay
// this is 30 seconds
#define delayMillis 3000
unsigned long thisMillis = 0;
unsigned long lastMillis = 0;
  // Must begin s7s software serial at the correct baud rate.
  //  The default of the s7s is 9600.
  s7s.begin(9600);
  // Clear the display, and then turn on all segments and decimals
  clearDisplay();  // Clears display, resets cursor
  s7s.print("HI  ");  // Displays -HI- on all digits
  s7s.print(" 200");
  setDecimals(0b111111);  // Turn on all decimals, colon, apos
  // Flash brightness values at the beginning
  setBrightness(0);  // Lowest brightness
  setBrightness(127);  // Medium brightness
  setBrightness(255);  // High brightness
  // Clear the display before jumping into loop
  clearDisplay();
  // disable SD SPI
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  // Start ethernet
  Serial.println(F("Starting ethernet..."));
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  // If using dhcp, comment out the line above
  // and uncomment the next 2 lines
  // if(!Ethernet.begin(mac)) Serial.println(F("failed"));
  // else Serial.println(F("ok"));
  digitalWrite(10,HIGH);
  Serial.println(Ethernet.localIP());
  delay(2000);
  Serial.println(F("Ready"));
  thisMillis = millis();
  if(thisMillis - lastMillis > delayMillis)
    lastMillis = thisMillis;
    // Modify next line to load different page
    // or pass values to server
    sprintf(pageAdd,"/temps.php",totalCount);
    // sprintf(pageAdd,"/arduino.php?test=%u",totalCount);
    if(!getPage(server,serverPort,pageAdd)) Serial.print(F("Fail "));
    else Serial.print(F("Pass "));
    totalCount++;
    Serial.println(totalCount,DEC);
byte getPage(IPAddress ipBuf,int thisPort, char *page)
  char inChar;
  char outBuf[128];
  Serial.print(F("connecting..."));
  if(client.connect(ipBuf,thisPort))
    Serial.println(F("connected"));
    sprintf(outBuf,"GET %s HTTP/1.1",page);
    client.println(outBuf);
    sprintf(outBuf,"Host: %s",serverName);
    client.println(F("Connection: close\r\n"));
    return 0;
  // connectLoop controls the hardware fail timeout
  int connectLoop = 0;
  while(client.connected())
    while(client.available())
      inChar = client.read();
      Serial.write(inChar);
      inData[index] = inChar; // Store it
      index++; // Increment where to write nex*-t
      // set connectLoop to zero if a packet arrives
      inData[index] = '\0'; // Null terminate the string
      smsAT=strstr (inData,"plain");
      connectLoop = 0;
    connectLoop++;
    // if more than 10000 milliseconds since the last packet
    if(connectLoop > 10000)
      // then close the connection from this end.
      Serial.println(F("Timeout"));
      client.stop();
    // this is a delay for the connectLoop timing
    delay(1);
  Serial.println(F("disconnecting."));
  // close client end
  Serial.print("smsAT: ");
  Serial.println(smsAT);
  char Temp1[6];
  strncpy(Temp1,&inData[195],5);
  Serial.print("Temp1: ");
  Serial.println(Temp1);
  client.stop();
  int digits = atoi (Temp1);
   Serial.print("digits: ");
  Serial.println(digits);
//  ********* PROBLEM HERE!!!!!
Serial.println(pch);
   // Magical sprintf creates a string for us to send to the s7s.
  //  The %4d option creates a 4-digit integer.
  sprintf(tempString, "%4d", digits);
  // This will output the tempString to the S7S
  s7s.print(tempString);
  setDecimals(0b00010000);  // Sets digit 3 decimal on
  counter++;  // Increment the counter
  delay(100);  // This will make the display update at 10Hz.
  memset(inData, 0, sizeof(inData));
  memset(Temp1, 0, sizeof(Temp1));
 inChar=0;
index=0;
  smsAT=0;
  return 1;
// Functions NaThAN
// Send the clear display command (0x76)
//  This will clear the display and reset the cursor
void clearDisplay()
  s7s.write(0x76);  // Clear display command
// Set the displays brightness. Should receive byte with the value
//  to set the brightness to
//  dimmest------------->brightest
//     0--------127--------255
void setBrightness(byte value)
  s7s.write(0x7A);  // Set brightness command byte
  s7s.write(value);  // brightness data byte
// Turn on any, none, or all of the decimals.
//  The six lowest bits in the decimals parameter sets a decimal
//  (or colon, or apostrophe) on or off. A 1 indicates on, 0 off.
//  [MSB] (X)(X)(Apos)(Colon)(Digit 4)(Digit 3)(Digit2)(Digit1)
void setDecimals(byte decimals)
  s7s.write(0x77);
  s7s.write(decimals);
Look at
pch = strstr (inData,“Temp1=”);
All I need to do is to find out the pointer value that directs to the number just after “=”. Please help me on how to find out the pointer value.
My bad. pch is a pointer, not an index. This should print the string starting at the 6th character after the 'T' in "Temp1="
if(pch != NULL) Serial.println(pch+6);
Thanks!!
