What does "non working" mean? Does it not compile? Does the upload fail? Or does it not behave as expected.
You will have to provide details like code (and libraries used if any) and wiring diagram for anybody to be able to assist (I might not be the one that can assist)
I've moved your topic to a more suitable location on the forum.
Hi sterretjeThe the library examplesof library TMC2209 , also TMCStepper were compiling (only some of them) but that doesn't moves my motor.
I used library TMC2209 , also TMCStepper library examples. But one of them are able to move motor.
Motor is ok as i tried that with A4988 driver. Drivers also i bought new to get confirmation of defectiveness in driver board. Connections are properly done too according to me. Microcontroller is also file , as it driven motor with A4988.
What is possible reason..... Did any example of TMC2209 , also TMCStepper library worked for anyone....Can anyone tell me???
Lets start with how you have the 2209 connected to the ESP32.
Can you also post some images of your project?
So we can see your component layout.
Hi TomGeorgeJackson
I will start with Code --- Here it is not compiling , but in one of post in IDE forum, someone claimed it is working. I installed libraries FastAccelSteeper + TMCStepper . Still not able to compile
#include "FastAccelStepper.h"
#include <TMCStepper.h>
#define STEP_PIN 2
#define DIR_PIN 15
#define RXD2 16
#define TXD2 17
#define SHAFT true
#define SERIAL_PORT_2 Serial2 // TMC2208/TMC2224 HardwareSerial port - pins 16 & 17
#define DRIVER_ADDRESS_1 0b00 // TMC2209 Driver address according to MS1 and MS2
#define R_SENSE 0.11f // E_SENSE for current calc, SilentStepStick series use 0.11
FastAccelStepperEngine engine = FastAccelStepperEngine();
FastAccelStepper *stepper = NULL;
TMC2209Stepper driver(&SERIAL_PORT_2, R_SENSE, DRIVER_ADDRESS_1); // Create TMC driver
int current = 1500;
int stall = 10;
int accel = 8000;
int max_speed = 19000;
int tcools = (3089838.00 * pow(float(max_speed), -1.00161534)) * 1.5; //*64 after max speed
int motor_microsteps = 16;
int motor_steps_per_rev = 200;
pinMode(DIR_PIN, OUTPUT);
pinMode(STEP_PIN, OUTPUT);
// INTITIALIZE SERIAL0 ITERFACE
Serial.println(F("---------------------------------------------------"));
Serial.println(F("UART0 serial output interface intitialized @ 115200"));
// INITIALIZE SERIAL2 UART FOR TMC2209
SERIAL_PORT_2.begin(115200); // INITIALIZE UART TMC2209, SERIAL_8N1, 16, 17
Serial.println(F("UART2 interface for TMC2209 intitialized @ 115200"));
//TMCSTEPPER SETTINGS
driver.begin();
driver.pdn_disable(true); // Use PDN/UART pin for communication
driver.toff(5); // [1..15] enable driver in software
driver.blank_time(24); // [16, 24, 36, 54]
driver.I_scale_analog(false); // Use internal voltage reference
driver.rms_current(current); // motor RMS current (mA) "rms_current will by default set ihold to 50% of irun but you can set your own ratio with additional second argument; rms_current(1000, 0.3)."
driver.mstep_reg_select(true);
read_ms();
driver.microsteps(motor_microsteps); //note that MicroPlyer will interpolate to 256
read_ms();
driver.TCOOLTHRS(tcools);
driver.seimin(1); // minimum current for smart current control 0: 1/2 of IRUN 1: 1/4 of IRUN
driver.semin(0);
driver.iholddelay(3); // 0 - 15 smooth current drop
driver.shaft(SHAFT);
driver.intpol(true); // interpolate to 256 microsteps
driver.SGTHRS(stall);
driver.pwm_autoscale(true); // Needed for stealthChop
driver.en_spreadCycle(false); // false = StealthChop / true = SpreadCycle, Spreadcycle can have higher RPM but is louder
driver.internal_Rsense(false);
driver.TPWMTHRS(0);
engine.init();
stepper = engine.stepperConnectToPin(STEP_PIN);
stepper->setDirectionPin(DIR_PIN);
stepper->setAutoEnable(true);
stepper->setSpeedInHz(max_speed);
stepper->setAcceleration(accel);
void read_ms() {
uint16_t msread = driver.microsteps();
Serial.print("Microsteps: ");
Serial.println(msread);
driver.microsteps(16);
read_ms();
driver.VACTUAL(19000); //SET SPEED OF MOTOR
delay(3000); // MOTOR MOVES 2 SEC THEN STOPS
driver.VACTUAL(0); //STOP MOTOR BY SETTING SPEED TO 0
driver.microsteps(0);
read_ms();
driver.VACTUAL(-19000); //SET SPEED OF MOTOR
Understood. But i would be loosing more time if i argue .
Here i come for solutions and that is what matters for me which is still pending. Posts with Thousands of views are already there to drive TMC2209 with a motor, but no one has proper solution inside...
I would be be thankful for people who would help
Like I said I do not have time to play games. You have been asked many times for information which you have failed to supply. Without the needed information how can you expect an accurate and working answer. Good Luck!
Have you got gnd of ESP32 connected to gnd of 2209?
The ESP is a 3.3V device. So Vio of TMC2209 must be 3.3V, not 5V. Standard schematics are useless. As @TomGeorge already pointed out, helpers need an exact schematic of your project to help.
I am backing out, the OP does not want to solve the problem. It would be relative simple to solve if we had the information asked for but the OP is an expert and is apparently testing us as th OP knows better what we need then we do.
I already attached it in thread previously. No Issues. A code i found which works for me
It rotates accelerates clockwise anticlockwise with good speed for 5 seconds when i ground GPIO21/22 , and deaccelerates to after that for 2 seconds. But i don't know how to use UART feature of TMZ2209 for current adjustment....?This is only help i need from anyone here...
My code is attached below..... Please ignore previous non working codes. I request to focus this one since i think i am near to solution...
// Stepper driver pin definitions
#define PIN_STEP_ENABLE 14
#define PIN_STEP1_DIRECTION 13
#define PIN_STEP1_STEP 12
#define SERIAL_PORT Serial2 // TMC2209 uses a hardware serial port
#define DRIVER_ADDRESS 0b00 // TMC2209 Driver address
// Button pin definitions
#define PIN_BUTTON_1 21
#define PIN_BUTTON_2 22
#define R_SENSE 0.11f // Match to your driver's Rsense value
TMC2209Stepper driver(&SERIAL_PORT, R_SENSE, DRIVER_ADDRESS);
// Stepper driver variables
int targetSpeed = 0;
int currentSpeed = 0;
int stepIncrement = 50;
int maxSpeed = 8000; // Adjust max speed if needed
int minSpeed = -8000; // Adjust min speed if needed
int slowSpeed = 500; // Slow speed for initial 3 seconds
int acceleration = 400;
int deceleration = 10; // Slower deceleration for smooth transition
int currentPosition = 0; // Declare currentPosition globally
SERIAL_PORT.begin(115200);
driver.begin();
driver.toff(4); // Enable driver
driver.rms_current(300); // Set driver current
driver.microsteps(16); // Enable microstepping
driver.en_spreadCycle(false); // Enable StealthChop
// Set both buttons as INPUT_PULLUP so we can detect when they are pressed
pinMode(PIN_BUTTON_1, INPUT_PULLUP);
pinMode(PIN_BUTTON_2, INPUT_PULLUP);
// Configure stepper driver pins as OUTPUTs
pinMode(PIN_STEP1_DIRECTION, OUTPUT);
pinMode(PIN_STEP1_STEP, OUTPUT);
pinMode(PIN_STEP_ENABLE, OUTPUT);
// ENABLE pin has to be pulled LOW for TMC2209 used in this example to enable the driver
digitalWrite(PIN_STEP_ENABLE, LOW);
static bool slowStart = true;
static unsigned long slowStartTime = 0;
static bool transitioningToSlow = false;
static bool slowingDown = false;
if (digitalRead(PIN_BUTTON_1) == LOW || digitalRead(PIN_BUTTON_2) == LOW) {
if (slowStart) {
slowStartTime = millis();
slowStart = false;
if (millis() - slowStartTime < 5000) {
// Run at normal speed for 5 seconds
if (digitalRead(PIN_BUTTON_1) == LOW) {
targetSpeed = maxSpeed;
} else if (digitalRead(PIN_BUTTON_2) == LOW) {
targetSpeed = minSpeed;
} else if (millis() - slowStartTime < 8000) {
// Smooth transition to slow speed
if (!transitioningToSlow) {
transitioningToSlow = true;
slowingDown = true;
if (slowingDown) {
if (currentSpeed > slowSpeed || currentSpeed < -slowSpeed) {
targetSpeed = (currentSpeed > 0) ? currentSpeed - deceleration : currentSpeed + deceleration;
targetSpeed = (targetSpeed > 0) ? slowSpeed : -slowSpeed;
// Reset slow start mechanism after 8 seconds
slowStart = true;
targetSpeed = 0;
slowStart = true;
// Smooth acceleration/deceleration
if (currentSpeed < targetSpeed) {
currentSpeed = min(currentSpeed + acceleration, targetSpeed);
} else if (currentSpeed > targetSpeed) {
currentSpeed = max(currentSpeed - acceleration, targetSpeed);
static unsigned long nextChange = 0;
static uint8_t currentState = LOW;
if (currentSpeed == 0) {
currentState = LOW;
digitalWrite(PIN_STEP1_STEP, LOW);
if (micros() > nextChange) {
if (currentState == LOW) {
currentState = HIGH;
nextChange = micros() + 20; // Short delay for high stepping rate
if (currentSpeed > 0) {
currentPosition++;
} else if (currentSpeed < 0) {
currentPosition--;
currentState = LOW;
nextChange = micros() + (1000000 / abs(currentSpeed)) - 20;
digitalWrite(PIN_STEP1_DIRECTION, LOW);
digitalWrite(PIN_STEP1_DIRECTION, HIGH);
digitalWrite(PIN_STEP1_STEP, currentState);
Hi Tom , i used exact same circuit as i posted above. Right now my hardware works as motor moving with minimal noise. But in code, i need anyone help to resolve.....
driver.begin();
if (slowStart) {
slowStart = false;
slowingDown = true;
if (slowingDown) {
slowStart = true;
targetSpeed = 0;
slowStart = true;
currentState = LOW;
currentPosition++;
currentPosition--;
currentState = LOW;
On my code , i am struggling so much to achieve this logic. Can anyone help me for that, i tried so hard, but luck no luck worked, that would be my perfect solution if it works...
**Button 1 GPIO 21(PIN_BUTTON_1):
When grounded (LOW), the motor should move anticlockwise at a slow speed for the first 3 seconds.
After 3 seconds, the motor should continue moving anticlockwise at a faster speed for an 5 seconds.
Button 2 GPIO22(PIN_BUTTON_2):
When grounded (LOW), the motor should move clockwise at a fast speed for the first 5 seconds.
After 5 seconds, the motor should continue moving clockwise at a slow speed for an 3 seconds.** If i try changing something, things doesn't work as expected. Please help
