searching for arduino coder/freelancer for helping me with some code i can pay
i have parts like ultrasonic sensor and servo and inductive sensor i want to work together in different ways if inductive detect something give value 1 if not 0 if 1 rotate servo right 90 degrees reset pos. if 0 check ultrasonic for value that is 1 or 0 if 1 rotate left 90. and reset pos.if 0 in ultrasonic sensor do nothing i want code to do this and if u want to help me this please reply we can agree on amount later
inductive sensor :CHPSS570 Lj12A3-4-Z/Bx Inductive Proximity Sensor Detection Switch Npn Dc6-36V 4mm Normally Open Proximity Switch
servo: SG90 Tower Pro Micro Servo Motor for ARDUINO RC Bot Control :Torque: 1.8 kgcm
i also need to make a proper circuit help me with that i have 4 *1k resistor
So, where on the planet are you located?
-jim lee
OK, a good starting point is to link to your part's online datasheets, or attach the PDF files in the thread...
Perhaps a sketch (drawing) of what your mechanical layout is going to be - so we can visualise it.
As a mechanical project - you need to consider range of motion, power supplies etc (and chopping off fingers etc)
Your goal sounds easy enough for an experienced developer - if you want to keep going by yourself -
contribute more info, or drop a hint on the budget, timeline etc, and maybe we can PM you to get involved.
