Hi!
I'm looking for someone that has experience and knowledge in building and developing Arduino projects. I will of course pay for the work. I have been in contact with PLC-engineers, and they recommended me to try the Arduino-field, because PLC is very expensive and probably far too advanced for this type of project. (?)
This is the case:
I have bought an old pastry-cream machine/ice-cream machine (Carpigiani) that is controlled electromechanical. My wish is to make this machine more advanced by controlling it with an Arduino, so i can make my own programs and adjustments. I need help with what parts to choose and programming. I think I'll manage the wiring.
The machine (from 1983) is originally controlled by an electromechanical timer and four bi-metallic thermostats:
- One for pasteurization
- A safety thermostat (up to 120 Celcius)
- A cooling/refrigeration thermostat
- A conservation thermostat
(- there is also a thermostat (?) for the defroster (?) for the refrigeration compressor
The heating, cooling, and fast/slow stirring/agitation is controlled by contactors (four of them).
Every contactor handles a high current of 230 Volts 3 Phases, the other electronics are 230 Volts 1 Phase.
My question is then: will it be possible to have a Arduino-board with a relay-board to control the contactors? The Arduino must also have a temperature sensor, preferably a thermocouple-board (?), and a screen/display for showing information and choosing programs/values. Maybe a touchscreen or a LCD with a keypad. It would also be nice to have it controlled by PID, rather than on/off thermostat.
The settings must be something like:
- Heating with timer control (how long to keep at set temperature)
- Cooling (how long to keep at set temperature)
- Fast or slow agitation, pulsing agitation, alternately mixing.
I will attach a link for the schematics for the machine. I also have the manual for how the new machines are build, that are controlled digital.
Link to shared folder OneDrive:
If you are interested in this project, please contact me. I live in Norway.
Here are some links for inspiration (similar machines):
Thanks in advance!
Simen Nilsen
Norway
