Hi, I have been trying to make the following code work I don't know why it isn't working. The code must return the name mentioned in the if statements or return caught while printing the rows. It isn't returning any error. Basically the if statements aren't executing. Please help!
#include <string.h>
#include <CSV_Parser.h>
char * dbc = "Name;Message;Multiplexing/Group;Startbit;Length [Bit];Byte Order;Value Type;Initial Value;Factor;Offset;Minimum;Maximum;Unit;Value Table;Comment;Message ID;GenSigInactiveValue;GenSigSendType;GenSigStartValue\n"
"BMS_AncVolt_V;BMS_PackInfo3;-;16;16;Intel;Unsigned;0;0.1;0;0;1000;V;-;Fuel Cell Voltage - measured by HVM;0x71D;0;Cyclic;0\n"
"BMS_BalancingStatus_enum;BMS_Status2;-;12;4;Intel;Unsigned;0;1;0;0;15;enum;VtSig_BMS_BalancingStatus_enum;Balancing state;0x291;0;Cyclic;0\n"
"BMS_Cell_ChrgCycles_num;BMS_PackInfo5;-;0;16;Intel;Unsigned;0;0.1;0;0;6553.4;num;-;-;0x71F;0;Cyclic;0\n"
"BMS_Cell_TempAvg_degC;BMS_CellTemperatureInfo;-;48;8;Intel;Signed;0;1;0;-128;127;degC;-;Average cell temperature;0x717;0;Cyclic;0\n"
"BMS_Cell_TempMax_CmuId_num;BMS_CellTemperatureInfo;-;32;8;Intel;Unsigned;0;1;0;0;255;num;-;CMU ID of cell with highest temperature;0x717;0;Cyclic;0\n"
"BMS_Cell_TempMax_degC;BMS_CellTemperatureInfo;-;24;8;Intel;Signed;0;1;0;-128;127;degC;-;Maximum cell temperature;0x717;0;Cyclic;0\n"
"BMS_Cell_TempMax_Id_num;BMS_CellTemperatureInfo;-;40;8;Intel;Unsigned;0;1;0;0;255;num;-;Cell number of cell with highest temperature.;0x717;0;Cyclic;0\n"
"BMS_Cell_TempMin_CmuId_num;BMS_CellTemperatureInfo;-;8;8;Intel;Unsigned;0;1;0;0;255;num;-;CMU ID of cell with lowest temperature;0x717;0;Cyclic;0\n"
"BMS_Cell_TempMin_degC;BMS_CellTemperatureInfo;-;0;8;Intel;Signed;0;1;0;-128;127;degC;-;Minimum cell temperature;0x717;0;Cyclic;0\n"
"BMS_Cell_TempMin_Id_num;BMS_CellTemperatureInfo;-;16;8;Intel;Unsigned;0;1;0;0;255;num;-;Cell number of cell with lowest temperature;0x717;0;Cyclic;0\n"
"BMS_Cell_VoltDelta_V;BMS_PackInfo1;-;0;16;Intel;Unsigned;0;0.0001;0;0;6.5535;V;-;Cell voltage difference between minimum and maximum cell voltage;0x71B;0;Cyclic;0\n"
"BMS_Cell_VoltMax_CmuId_num;BMS_CellVoltageInfo;-;48;8;Intel;Unsigned;0;1;0;0;255;num;-;CMU ID of cell with maximum voltage;0x713;0;Cyclic;0\n"
"BMS_Cell_VoltMax_Id_num;BMS_CellVoltageInfo;-;56;8;Intel;Unsigned;0;1;0;0;255;num;-;Cell number of cell with maximum voltage;0x713;0;Cyclic;0\n"
"BMS_Cell_VoltMax_V;BMS_CellVoltageInfo;-;32;16;Intel;Unsigned;0;0.0001;0;0;6.5535;V;-;Maximum cell voltage;0x713;0;Cyclic;0\n"
"BMS_Cell_VoltMin_CmuId_num;BMS_CellVoltageInfo;-;16;8;Intel;Unsigned;0;1;0;0;255;num;-;CMU ID of cell with minimum voltage;0x713;0;Cyclic;0\n"
"BMS_Cell_VoltMin_Id_num;BMS_CellVoltageInfo;-;24;8;Intel;Unsigned;0;1;0;0;255;num;-;Cell number of cell with lowest voltage;0x713;0;Cyclic;0\n"
"BMS_Cell_VoltMin_V;BMS_CellVoltageInfo;-;0;16;Intel;Unsigned;0;0.0001;0;0;6.5535;V;-;Minimum cell voltage;0x713;0;Cyclic;0\n"
"BMS_Chrg_CapacityRemain_Ah;BMS_Status2;-;32;8;Intel;Unsigned;0;0.2;0;0;51;-;-;Battery Pack Charge Capacity Remaining in Ah;0x291;0;Cyclic;0\n"
"BMS_Chrg_TmRemain_min;BMS_PackInfo5;-;16;16;Intel;Unsigned;0;1;0;0;65534;minutes;-;-;0x71F;0;Cyclic;0\n"
"BMS_ChrgComplete_bool;BMS_Status2;-;7;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS charge complete flag. 0 = Not complete, 1 = Complete.;0x291;0;Cyclic;0\n"
"BMS_ChrgCurLim30s_A;BMS_Limits2;-;16;16;Intel;Unsigned;0;0.1;0;0;6553.5;A;-;Charge Current Limit for 30 second events / continuous;0x296;0;Cyclic;0\n"
"BMS_ChrgCurrLim30s_enum;BMS_FltInfo_Derate1;-;48;16;Intel;Unsigned;0;1;0;0;65535;enum;VtSig_BMS_ChrgCurrLim30s_enum;Charge Current Limit Enumeration for 30 second events / continuous;0x73F;0;Cyclic;0\n"
"BMS_ChrgCurrReq_A;BMS_Limits1;-;32;16;Intel;Unsigned;0;0.1;0;0;6553.5;A;-;Current request for charging in Amps;0x295;0;Cyclic;0\n"
"BMS_ChrgModeReqFb_bool;BMS_Status1;-;6;1;Intel;Unsigned;0;1;0;0;1;bool;-;Charge mode request acknowledgement feedback (0 = charge mode not requested feedback, 1 = charge mode requested feedback);0x290;0;Cyclic;0\n"
"BMS_ChrgPwrLim10s_enum;BMS_FltInfo_Derate1;-;16;16;Intel;Unsigned;0;1;0;0;65535;enum;VtSig_BMS_ChrgPwrLim10s_enum;Regen Current Limit Enumeration for 10 second events / instantaneous;0x73F;0;Cyclic;0\n"
"BMS_ChrgPwrLim10s_W;BMS_Limits1;-;16;16;Intel;Unsigned;0;20;0;0;1310700;W;-;Regen Current Limit for 10 second events / instantaneous;0x295;0;Cyclic;0\n"
"BMS_ChrgVolt_V;BMS_PackInfo3;-;32;16;Intel;Unsigned;0;0.1;0;0;1000;V;-;Anc Voltage - measured by HVM;0x71D;0;Cyclic;0\n"
"BMS_ChrgVoltMax_V;BMS_Limits1;-;48;16;Intel;Unsigned;0;0.1;0;0;6553.5;V;-;Maximum charging voltage of pack;0x295;0;Cyclic;0\n"
"BMS_CMU1_temp1;BMS_CMU_Temp1;BMS_CMU_counter = 0x0;8;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU1_temp2;BMS_CMU_Temp1;BMS_CMU_counter = 0x0;16;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU1_temp3;BMS_CMU_Temp1;BMS_CMU_counter = 0x0;24;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU1_temp4;BMS_CMU_Temp1;BMS_CMU_counter = 0x0;32;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU1_temp5;BMS_CMU_Temp1;BMS_CMU_counter = 0x0;40;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU1_temp6;BMS_CMU_Temp1;BMS_CMU_counter = 0x0;48;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU1_voltage1;BMS_CMU_Voltages1;BMS_CMU_counter = 0x0;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage10;BMS_CMU_Voltages1;BMS_CMU_counter = 0x2;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage11;BMS_CMU_Voltages1;BMS_CMU_counter = 0x2;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage12;BMS_CMU_Voltages1;BMS_CMU_counter = 0x2;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage13;BMS_CMU_Voltages1;BMS_CMU_counter = 0x3;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage14;BMS_CMU_Voltages1;BMS_CMU_counter = 0x3;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage2;BMS_CMU_Voltages1;BMS_CMU_counter = 0x0;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage3;BMS_CMU_Voltages1;BMS_CMU_counter = 0x0;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage4;BMS_CMU_Voltages1;BMS_CMU_counter = 0x0;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage5;BMS_CMU_Voltages1;BMS_CMU_counter = 0x1;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage6;BMS_CMU_Voltages1;BMS_CMU_counter = 0x1;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage7;BMS_CMU_Voltages1;BMS_CMU_counter = 0x1;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage8;BMS_CMU_Voltages1;BMS_CMU_counter = 0x1;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU1_voltage9;BMS_CMU_Voltages1;BMS_CMU_counter = 0x2;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_temp1;BMS_CMU_Temp1;BMS_CMU_counter = 0x0;56;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU2_temp2;BMS_CMU_Temp1;BMS_CMU_counter = 0x1;8;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU2_temp3;BMS_CMU_Temp1;BMS_CMU_counter = 0x1;16;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU2_temp4;BMS_CMU_Temp1;BMS_CMU_counter = 0x1;24;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU2_temp5;BMS_CMU_Temp1;BMS_CMU_counter = 0x1;32;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU2_temp6;BMS_CMU_Temp1;BMS_CMU_counter = 0x1;40;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU2_voltage1;BMS_CMU_Voltages1;BMS_CMU_counter = 0x3;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage10;BMS_CMU_Voltages1;BMS_CMU_counter = 0x5;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage11;BMS_CMU_Voltages1;BMS_CMU_counter = 0x6;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage12;BMS_CMU_Voltages1;BMS_CMU_counter = 0x6;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage13;BMS_CMU_Voltages1;BMS_CMU_counter = 0x6;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage14;BMS_CMU_Voltages1;BMS_CMU_counter = 0x6;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage2;BMS_CMU_Voltages1;BMS_CMU_counter = 0x3;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage3;BMS_CMU_Voltages1;BMS_CMU_counter = 0x4;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage4;BMS_CMU_Voltages1;BMS_CMU_counter = 0x4;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage5;BMS_CMU_Voltages1;BMS_CMU_counter = 0x4;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage6;BMS_CMU_Voltages1;BMS_CMU_counter = 0x4;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage7;BMS_CMU_Voltages1;BMS_CMU_counter = 0x5;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage8;BMS_CMU_Voltages1;BMS_CMU_counter = 0x5;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU2_voltage9;BMS_CMU_Voltages1;BMS_CMU_counter = 0x5;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_temp1;BMS_CMU_Temp1;BMS_CMU_counter = 0x1;48;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU3_temp2;BMS_CMU_Temp1;BMS_CMU_counter = 0x1;56;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU3_temp3;BMS_CMU_Temp1;BMS_CMU_counter = 0x2;8;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU3_temp4;BMS_CMU_Temp1;BMS_CMU_counter = 0x2;16;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU3_temp5;BMS_CMU_Temp1;BMS_CMU_counter = 0x2;24;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU3_temp6;BMS_CMU_Temp1;BMS_CMU_counter = 0x2;32;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU3_voltage1;BMS_CMU_Voltages1;BMS_CMU_counter = 0x7;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage10;BMS_CMU_Voltages1;BMS_CMU_counter = 0x9;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage11;BMS_CMU_Voltages1;BMS_CMU_counter = 0x9;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage12;BMS_CMU_Voltages1;BMS_CMU_counter = 0x9;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage13;BMS_CMU_Voltages2;BMS_CMU_counter = 0x0;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU3_voltage14;BMS_CMU_Voltages2;BMS_CMU_counter = 0x0;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU3_voltage2;BMS_CMU_Voltages1;BMS_CMU_counter = 0x7;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage3;BMS_CMU_Voltages1;BMS_CMU_counter = 0x7;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage4;BMS_CMU_Voltages1;BMS_CMU_counter = 0x7;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage5;BMS_CMU_Voltages1;BMS_CMU_counter = 0x8;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage6;BMS_CMU_Voltages1;BMS_CMU_counter = 0x8;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage7;BMS_CMU_Voltages1;BMS_CMU_counter = 0x8;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage8;BMS_CMU_Voltages1;BMS_CMU_counter = 0x8;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU3_voltage9;BMS_CMU_Voltages1;BMS_CMU_counter = 0x9;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x507;0;Cyclic;0\n"
"BMS_CMU4_temp1;BMS_CMU_Temp1;BMS_CMU_counter = 0x2;40;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU4_temp2;BMS_CMU_Temp1;BMS_CMU_counter = 0x2;48;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU4_temp3;BMS_CMU_Temp1;BMS_CMU_counter = 0x2;56;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU4_temp4;BMS_CMU_Temp1;BMS_CMU_counter = 0x3;8;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU4_temp5;BMS_CMU_Temp1;BMS_CMU_counter = 0x3;16;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU4_temp6;BMS_CMU_Temp1;BMS_CMU_counter = 0x3;24;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU4_voltage1;BMS_CMU_Voltages2;BMS_CMU_counter = 0x0;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage10;BMS_CMU_Voltages2;BMS_CMU_counter = 0x2;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage11;BMS_CMU_Voltages2;BMS_CMU_counter = 0x3;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage12;BMS_CMU_Voltages2;BMS_CMU_counter = 0x3;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage13;BMS_CMU_Voltages2;BMS_CMU_counter = 0x3;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage14;BMS_CMU_Voltages2;BMS_CMU_counter = 0x3;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage2;BMS_CMU_Voltages2;BMS_CMU_counter = 0x0;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage3;BMS_CMU_Voltages2;BMS_CMU_counter = 0x1;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage4;BMS_CMU_Voltages2;BMS_CMU_counter = 0x1;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage5;BMS_CMU_Voltages2;BMS_CMU_counter = 0x1;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage6;BMS_CMU_Voltages2;BMS_CMU_counter = 0x1;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage7;BMS_CMU_Voltages2;BMS_CMU_counter = 0x2;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage8;BMS_CMU_Voltages2;BMS_CMU_counter = 0x2;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU4_voltage9;BMS_CMU_Voltages2;BMS_CMU_counter = 0x2;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_temp1;BMS_CMU_Temp1;BMS_CMU_counter = 0x3;32;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU5_temp2;BMS_CMU_Temp1;BMS_CMU_counter = 0x3;40;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU5_temp3;BMS_CMU_Temp1;BMS_CMU_counter = 0x3;48;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU5_temp4;BMS_CMU_Temp1;BMS_CMU_counter = 0x3;56;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU5_temp5;BMS_CMU_Temp1;BMS_CMU_counter = 0x4;8;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU5_temp6;BMS_CMU_Temp1;BMS_CMU_counter = 0x4;16;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU5_voltage1;BMS_CMU_Voltages2;BMS_CMU_counter = 0x4;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage10;BMS_CMU_Voltages2;BMS_CMU_counter = 0x6;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage11;BMS_CMU_Voltages2;BMS_CMU_counter = 0x6;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage12;BMS_CMU_Voltages2;BMS_CMU_counter = 0x6;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage13;BMS_CMU_Voltages2;BMS_CMU_counter = 0x7;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage14;BMS_CMU_Voltages2;BMS_CMU_counter = 0x7;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage2;BMS_CMU_Voltages2;BMS_CMU_counter = 0x4;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage3;BMS_CMU_Voltages2;BMS_CMU_counter = 0x4;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage4;BMS_CMU_Voltages2;BMS_CMU_counter = 0x4;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage5;BMS_CMU_Voltages2;BMS_CMU_counter = 0x5;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage6;BMS_CMU_Voltages2;BMS_CMU_counter = 0x5;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage7;BMS_CMU_Voltages2;BMS_CMU_counter = 0x5;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage8;BMS_CMU_Voltages2;BMS_CMU_counter = 0x5;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU5_voltage9;BMS_CMU_Voltages2;BMS_CMU_counter = 0x6;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_temp1;BMS_CMU_Temp1;BMS_CMU_counter = 0x4;24;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU6_temp2;BMS_CMU_Temp1;BMS_CMU_counter = 0x4;32;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU6_temp3;BMS_CMU_Temp1;BMS_CMU_counter = 0x4;40;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU6_temp4;BMS_CMU_Temp1;BMS_CMU_counter = 0x4;48;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU6_temp5;BMS_CMU_Temp1;BMS_CMU_counter = 0x4;56;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU6_temp6;BMS_CMU_Temp1;BMS_CMU_counter = 0x5;8;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU6_voltage1;BMS_CMU_Voltages2;BMS_CMU_counter = 0x7;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage10;BMS_CMU_Voltages2;BMS_CMU_counter = 0x9;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage11;BMS_CMU_Voltages3;BMS_CMU_counter = 0x0;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU6_voltage12;BMS_CMU_Voltages3;BMS_CMU_counter = 0x0;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU6_voltage13;BMS_CMU_Voltages3;BMS_CMU_counter = 0x0;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU6_voltage14;BMS_CMU_Voltages3;BMS_CMU_counter = 0x0;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU6_voltage2;BMS_CMU_Voltages2;BMS_CMU_counter = 0x7;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage3;BMS_CMU_Voltages2;BMS_CMU_counter = 0x8;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage4;BMS_CMU_Voltages2;BMS_CMU_counter = 0x8;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage5;BMS_CMU_Voltages2;BMS_CMU_counter = 0x8;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage6;BMS_CMU_Voltages2;BMS_CMU_counter = 0x8;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage7;BMS_CMU_Voltages2;BMS_CMU_counter = 0x9;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage8;BMS_CMU_Voltages2;BMS_CMU_counter = 0x9;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU6_voltage9;BMS_CMU_Voltages2;BMS_CMU_counter = 0x9;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x508;0;Cyclic;0\n"
"BMS_CMU7_temp1;BMS_CMU_Temp1;BMS_CMU_counter = 0x5;16;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU7_temp2;BMS_CMU_Temp1;BMS_CMU_counter = 0x5;24;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU7_temp3;BMS_CMU_Temp1;BMS_CMU_counter = 0x5;32;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU7_temp4;BMS_CMU_Temp1;BMS_CMU_counter = 0x5;40;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU7_temp5;BMS_CMU_Temp1;BMS_CMU_counter = 0x5;48;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU7_temp6;BMS_CMU_Temp1;BMS_CMU_counter = 0x5;56;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU7_voltage01;BMS_CMU_Voltages3;BMS_CMU_counter = 0x1;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage02;BMS_CMU_Voltages3;BMS_CMU_counter = 0x1;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage03;BMS_CMU_Voltages3;BMS_CMU_counter = 0x1;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage04;BMS_CMU_Voltages3;BMS_CMU_counter = 0x1;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage05;BMS_CMU_Voltages3;BMS_CMU_counter = 0x2;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage06;BMS_CMU_Voltages3;BMS_CMU_counter = 0x2;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage07;BMS_CMU_Voltages3;BMS_CMU_counter = 0x2;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage08;BMS_CMU_Voltages3;BMS_CMU_counter = 0x2;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage09;BMS_CMU_Voltages3;BMS_CMU_counter = 0x3;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage10;BMS_CMU_Voltages3;BMS_CMU_counter = 0x3;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage11;BMS_CMU_Voltages3;BMS_CMU_counter = 0x3;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage12;BMS_CMU_Voltages3;BMS_CMU_counter = 0x3;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage13;BMS_CMU_Voltages3;BMS_CMU_counter = 0x4;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU7_voltage14;BMS_CMU_Voltages3;BMS_CMU_counter = 0x4;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_temp1;BMS_CMU_Temp1;BMS_CMU_counter = 0x6;8;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU8_temp2;BMS_CMU_Temp1;BMS_CMU_counter = 0x6;16;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU8_temp3;BMS_CMU_Temp1;BMS_CMU_counter = 0x6;24;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU8_temp4;BMS_CMU_Temp1;BMS_CMU_counter = 0x6;32;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU8_temp5;BMS_CMU_Temp1;BMS_CMU_counter = 0x6;40;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU8_temp6;BMS_CMU_Temp1;BMS_CMU_counter = 0x6;48;8;Intel;Unsigned;-40;1;-40;-40;215;DegC;-;CMU Cell Temperature;0x500;0;Cyclic;0\n"
"BMS_CMU8_voltage1;BMS_CMU_Voltages3;BMS_CMU_counter = 0x4;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage10;BMS_CMU_Voltages3;BMS_CMU_counter = 0x6;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage11;BMS_CMU_Voltages3;BMS_CMU_counter = 0x7;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage12;BMS_CMU_Voltages3;BMS_CMU_counter = 0x7;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage13;BMS_CMU_Voltages3;BMS_CMU_counter = 0x7;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage14;BMS_CMU_Voltages3;BMS_CMU_counter = 0x7;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage2;BMS_CMU_Voltages3;BMS_CMU_counter = 0x4;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage3;BMS_CMU_Voltages3;BMS_CMU_counter = 0x5;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage4;BMS_CMU_Voltages3;BMS_CMU_counter = 0x5;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage5;BMS_CMU_Voltages3;BMS_CMU_counter = 0x5;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage6;BMS_CMU_Voltages3;BMS_CMU_counter = 0x5;45;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage7;BMS_CMU_Voltages3;BMS_CMU_counter = 0x6;6;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage8;BMS_CMU_Voltages3;BMS_CMU_counter = 0x6;19;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU8_voltage9;BMS_CMU_Voltages3;BMS_CMU_counter = 0x6;32;13;Intel;Unsigned;0;0.001;0;0;8.191;volts;-;CMU Cell Voltage;0x509;0;Cyclic;0\n"
"BMS_CMU_counter;BMS_CMU_Voltages3;Multiplexor;0;6;Intel;Unsigned;0;1;0;0;63;count;-;-;0x509;0;Cyclic;0\n"
"BMS_CMU_counter;BMS_CMU_Voltages2;Multiplexor;0;6;Intel;Unsigned;0;1;0;0;63;count;-;-;0x508;0;Cyclic;0\n"
"BMS_CMU_counter;BMS_CMU_Voltages1;Multiplexor;0;6;Intel;Unsigned;0;1;0;0;63;count;-;-;0x507;0;Cyclic;0\n"
"BMS_CMU_counter;BMS_CMU_Temp1;Multiplexor;0;6;Intel;Unsigned;0;1;0;0;63;count;-;-;0x500;0;Cyclic;0\n"
"BMS_Cool_Emgncy_Req_bool;BMS_Status2;-;2;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Emergency cooling request;0x291;0;Cyclic;0\n"
"BMS_Cool_None_Req_bool;BMS_Status2;-;0;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS no cooling request;0x291;0;Cyclic;0\n"
"BMS_Cool_Normal_Req_bool;BMS_Status2;-;1;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Normal cooling request;0x291;0;Cyclic;0\n"
"BMS_Counter_num;BMS_Status1;-;8;4;Intel;Unsigned;0;1;0;0;15;count;-;4 bit continuously incrementing counter. Wraps around to 0 after 15.;0x290;0;Cyclic;0\n"
"BMS_Counter_num;BMS_Status2;-;8;4;Intel;Unsigned;0;1;0;0;15;count;-;4 bit continuously incrementing counter. Wraps around to 0 after 15.;0x291;0;Cyclic;0\n"
"BMS_Dischrg_CapacityRemain_Ah;BMS_Status2;-;24;8;Intel;Unsigned;0;0.2;0;0;51;-;-;Battery Pack Discharge Capacity Remaining in Ah;0x291;0;Cyclic;0\n"
"BMS_DischrgPwrLim10s_enum;BMS_FltInfo_Derate1;-;0;16;Intel;Unsigned;0;1;0;0;65535;enum;VtSig_BMS_DischrgPwrLim10s_enum;Discharge Current Limit Enumeration for 10 second events / instantaneous;0x73F;0;Cyclic;0\n"
"BMS_DischrgPwrLim10s_W;BMS_Limits1;-;0;16;Intel;Unsigned;0;20;0;0;1310700;W;-;Discharge Current Limit for 10 second events / instantaneous;0x295;0;Cyclic;0\n"
"BMS_DischrgPwrLim30s_enum;BMS_FltInfo_Derate1;-;32;16;Intel;Unsigned;0;1;0;0;65535;enum;VtSig_BMS_DischrgPwrLim30s_enum;Discharge Current Limit Enumeration for 30 second events / continuous;0x73F;0;Cyclic;0\n"
"BMS_DischrgPwrLim30s_W;BMS_Limits2;-;0;16;Intel;Unsigned;0;20;0;0;1310700;W;-;Discharge Current Limit for 30 second events / continuous;0x296;0;Cyclic;0\n"
"BMS_EmgncyCttrOpening_bool;BMS_Status1;-;15;1;Intel;Unsigned;0;1;0;0;1;bool;-;Emergency contactor opening warning (0 = contactors not able to open, 1 = contactors about to open due to emergency);0x290;0;Cyclic;0\n"
"BMS_FltDisbl_Act_bool;BMS_Status2;-;3;1;Intel;Unsigned;0;1;0;0;1;bool;-;Any Disable Fault is active;0x291;0;Cyclic;0\n"
"BMS_FltDrate_Act_bool;BMS_Status2;-;5;1;Intel;Unsigned;0;1;0;0;1;bool;-;Any Derate Fault is active;0x291;0;Cyclic;0\n"
"BMS_FltLmpHm_Act_bool;BMS_Status2;-;4;1;Intel;Unsigned;0;1;0;0;1;bool;-;Any Limp Home Fault is active;0x291;0;Cyclic;0\n"
"BMS_FltWarn_Act_bool;BMS_Status2;-;6;1;Intel;Unsigned;0;1;0;0;1;bool;-;Any Warn Fault is active;0x291;0;Cyclic;0\n"
"BMS_HMI_WarnLevel_0_bool;BMS_FltInfo_Sfty1;-;9;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS HMI safety layer warning level 0...;0x72A;0;Cyclic;0\n"
"BMS_HMI_WarnLevel_1_bool;BMS_FltInfo_Sfty1;-;10;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS HMI safety layer warning level 1...;0x72A;0;Cyclic;0\n"
"BMS_HMI_WarnLevel_2_bool;BMS_FltInfo_Sfty1;-;11;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS HMI safety layer warning level 2...;0x72A;0;Cyclic;0\n"
"BMS_HMI_WarnLevel_3_bool;BMS_FltInfo_Sfty1;-;12;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS HMI safety layer warning level 3...;0x72A;0;Cyclic;0\n"
"BMS_HVBattTotalCapacity_kWh;BMS_PackInfo1;-;16;12;Intel;Unsigned;0;0.1;0;0;102.35;kWh;-;Total battery capacity in kWh (energy content)....;0x71B;0;Cyclic;0\n"
"BMS_HvBus1_Tract_OnFb_bool;BMS_Status1;-;0;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 1 (Traction) feedback (negative & relevant positive contactor are open or closed) (0 = open, 1 = closed);0x290;0;Cyclic;0\n"
"BMS_HvBus2_Chrg_OnFb_bool;BMS_Status1;-;1;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 2 (Fuel Cell) feedback (negative & relevant positive contactor are open or closed) (0 = open, 1 = closed);0x290;0;Cyclic;0\n"
"BMS_HvBus3_Anc_OnFb_bool;BMS_Status1;-;2;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 3 (Ancillary) feedback (negative & relevant positive contactor are open or closed) (0 = open, 1 = closed);0x290;0;Cyclic;0\n"
"BMS_HvBus4_Null_OnFb_bool;BMS_Status1;-;3;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 4 (Not Used) feedback (negative & relevant positive contactor are open or closed) (0 = open, 1 = closed);0x290;0;Cyclic;0\n"
"BMS_HvBus5_Null_OnFb_bool;BMS_Status1;-;4;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 5 (Not Used) feedback (negative & relevant positive contactor are open or closed) (0 = open, 1 = closed);0x290;0;Cyclic;0\n"
"BMS_IsolDisbl_ReqFb_bool;BMS_Status1;-;5;1;Intel;Unsigned;0;1;0;0;1;bool;-;Isolation monitor disable request feedback (0 = requested enabled, 1 = requested disabled);0x290;0;Cyclic;0\n"
"BMS_IsolVal_kohm;BMS_PackInfo2;-;32;16;Intel;Unsigned;0;1;0;0;65535;kohm;-;Isolation Value in kohm;0x71C;0;Cyclic;0\n"
"BMS_PackCurr_A;BMS_Status1;-;40;16;Intel;Signed;0;0.1;0;-3276.8;3276.7;A;-;Battery Pack Current (Convention: Positive = Discharge , Negative = Charge);0x290;0;Cyclic;0\n"
"BMS_PackPwr_W;BMS_Status2;-;40;16;Intel;Signed;0;40;0;-1310720;1310680;W;-;Calculated Pack Power in Watts (Convention: Positive = Discharge , Negative = Charge);0x291;0;Cyclic;0\n"
"BMS_PackVolt_Meas_V;BMS_PackInfo1;-;48;16;Intel;Unsigned;0;0.1;0;0;6553.5;V;-;Battery Pack Voltage - measured by HVM;0x71B;0;Cyclic;0\n"
"BMS_PackVolt_Sum_V;BMS_PackInfo2;-;16;16;Intel;Unsigned;0;0.1;0;0;6553.5;V;-;Battery Pack Voltage - summation of cell voltages;0x71C;0;Cyclic;0\n"
"BMS_PackVolt_V;BMS_Status1;-;24;16;Intel;Unsigned;0;0.1;0;0;6553.5;V;-;Battery Pack Voltage;0x290;0;Cyclic;0\n"
"BMS_Press_CoolInlet_bar;BMS_PackInfo4;-;16;16;Intel;Unsigned;0;0.001;0;0;65.535;bar;-;Coolant inlet pressure;0x71E;0;Cyclic;0\n"
"BMS_Press_CoolOutlet_bar;BMS_PackInfo4;-;32;16;Intel;Unsigned;0;0.001;0;0;65.535;bar;-;Coolant outlet pressure;0x71E;0;Cyclic;0\n"
"BMS_ResponseLevel_1_bool;BMS_FltInfo_Sfty1;-;0;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 1 (CAT3);0x72A;0;Cyclic;0\n"
"BMS_ResponseLevel_2_bool;BMS_FltInfo_Sfty1;-;1;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 2 (CAT3);0x72A;0;Cyclic;0\n"
"BMS_ResponseLevel_3_bool;BMS_FltInfo_Sfty1;-;2;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 3 (CAT3);0x72A;0;Cyclic;0\n"
"BMS_ResponseLevel_4_bool;BMS_FltInfo_Sfty1;-;3;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 4 (CAT4);0x72A;0;Cyclic;0\n"
"BMS_ResponseLevel_5_bool;BMS_FltInfo_Sfty1;-;4;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 5 (CAT5);0x72A;0;Cyclic;0\n"
"BMS_ResponseLevel_6_bool;BMS_FltInfo_Sfty1;-;5;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 6 (CAT6);0x72A;0;Cyclic;0\n"
"BMS_ResponseLevel_7_bool;BMS_FltInfo_Sfty1;-;6;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 7 (CAT7);0x72A;0;Cyclic;0\n"
"BMS_ResponseLevel_8_bool;BMS_FltInfo_Sfty1;-;7;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 8 (CAT7);0x72A;0;Cyclic;0\n"
"BMS_ResponseLevel_9_bool;BMS_FltInfo_Sfty1;-;8;1;Intel;Unsigned;0;1;0;0;1;bool;-;BMS Safety Layer Response Level 9 (CAT7);0x72A;0;Cyclic;0\n"
"BMS_SftyLyr_FaultCode_num;BMS_FltInfo_Sfty1;-;16;32;Intel;Unsigned;0;1;0;-1;0;-;-;BMS Safety Layer Fault Codes;0x72A;0;Cyclic;0\n"
"BMS_SftyLyr_FaultCodeActNum_num;BMS_FltInfo_Sfty1;-;48;8;Intel;Unsigned;0;1;0;0;255;-;-;BMS Number of Active Safety Layer Fault Codes;0x72A;0;Cyclic;0\n"
"BMS_ShutdownOk_bool;BMS_Status1;-;7;1;Intel;Unsigned;0;1;0;0;1;bool;-;Shutdown request has been received and the battery is ready to be shutdown (0 = not ready to shutdown, 1 = ready to shutdown);0x290;0;Cyclic;0\n"
"BMS_SOC_pack_CellVoltMax_pc;BMS_PackInfo5;-;32;16;Intel;Unsigned;0;0.01;0;0;100;%;-;Cell Voltage Maximum State Of Charge;0x71F;0;Cyclic;0\n"
"BMS_SOC_pack_CellVoltMin_pc;BMS_PackInfo5;-;48;16;Intel;Unsigned;0;0.01;0;0;100;%;-;Cell Voltage Minimum State Of Charge;0x71F;0;Cyclic;0\n"
"BMS_SOC_pack_pc;BMS_PackInfo2;-;0;16;Intel;Unsigned;0;0.01;0;0;100;%;-;Pack State Of Charge (Actual State of Charge);0x71C;0;Cyclic;0\n"
"BMS_SOC_pc;BMS_Status1;-;16;8;Intel;Unsigned;0;0.5;0;0;100;%;-;Usable State of Charge;0x290;0;Cyclic;0\n"
"BMS_SoftwareVersion_num;BMS_PackInfo2;-;48;16;Intel;Unsigned;0;1;0;0;65534;num;-;-;0x71C;0;Cyclic;0\n"
"BMS_SOH_pc;BMS_PackInfo1;-;32;16;Intel;Unsigned;0;0.01;0;0;100;%;-;State Of Health;0x71B;0;Cyclic;0\n"
"BMS_Startup_Rdy_bool;BMS_Status1;-;14;1;Intel;Unsigned;0;1;0;0;1;bool;-;Startup ready status to indicate readiness for receiving requests (0 = startup not complete, 1 = startup complete);0x290;0;Cyclic;0\n"
"BMS_Status1_CRC_num;BMS_Status1;-;56;8;Intel;Unsigned;0;1;0;0;255;num;-;CRC value calculated on the message (8 bit), for safety reasons this must be calculated correctly.;0x290;0;Cyclic;0\n"
"BMS_Status2_CRC_num;BMS_Status2;-;56;8;Intel;Unsigned;0;1;0;0;255;num;-;CRC value calculated on the message (8 bit), for safety reasons this must be calculated correctly.;0x291;0;Cyclic;0\n"
"BMS_Status_enum;BMS_Status2;-;16;8;Intel;Unsigned;0;1;0;0;255;enum;VtSig_BMS_Status_enum;BMS status enumeration;0x291;0;Cyclic;0\n"
"BMS_Temp_CoolInlet_degC;BMS_PackInfo4;-;0;8;Intel;Unsigned;-20;0.5;-20;-20;107.5;degC;-;Coolant inlet temperature;0x71E;0;Cyclic;0\n"
"BMS_Temp_CoolOutlet_degC;BMS_PackInfo4;-;8;8;Intel;Unsigned;-20;0.5;-20;-20;107.5;degC;-;Coolant outlet temperature;0x71E;0;Cyclic;0\n"
"BMS_TractVolt_V;BMS_PackInfo3;-;0;16;Intel;Unsigned;0;0.1;0;0;1000;V;-;Traction Voltage - measured by HVM;0x71D;0;Cyclic;0\n"
"VSC_ChrgModeReq_bool;VSC_BatCmd;-;6;1;Intel;Unsigned;0;1;0;0;1;bool;-;Stationary Charge mode request (0 = charge mode not requested, 1 = charge mode requested);0x270;0;Cyclic;0\n"
"VSC_Cmd_CRC_num;VSC_BatCmd;-;16;8;Intel;Unsigned;0;1;0;0;255;num;-;CRC value calculated on the message (8 bit), for safety reasons this must be calculated correctly.;0x270;0;Cyclic;0\n"
"VSC_Counter_num;VSC_BatCmd;-;8;4;Intel;Unsigned;0;1;0;0;15;count;-;4 bit continuously incrementing counter. Wraps around to 0 after 15.;0x270;0;Cyclic;0\n"
"VSC_CrashStatus_bool;VSC_BatCmd;-;13;1;Intel;Unsigned;0;1;0;0;1;bool;-;This signal defines the crash status of the vehicle safety system....;0x270;0;Cyclic;0\n"
"VSC_HvBus1_Tract_OnReq_bool;VSC_BatCmd;-;0;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 1 (Traction) request (negative & relevant positive contactor to be closed or opened) (0 = open, 1 = close);0x270;0;Cyclic;0\n"
"VSC_HvBus2_Chrg_OnReq_bool;VSC_BatCmd;-;1;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 2 (Fuel Cell) request (negative & relevant positive contactor to be closed or opened) (0 = open, 1 = close);0x270;0;Cyclic;0\n"
"VSC_HvBus3_Anc_OnReq_bool;VSC_BatCmd;-;2;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 3 (Ancillary) request (negative & relevant positive contactor to be closed or opened) (0 = open, 1 = close);0x270;0;Cyclic;0\n"
"VSC_HvBus4_Null_OnReq_bool;VSC_BatCmd;-;3;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 4 (Not Used) request (negative & relevant positive contactor to be closed or opened) (0 = open, 1 = close);0x270;0;Cyclic;0\n"
"VSC_HvBus5_Null_OnReq_bool;VSC_BatCmd;-;4;1;Intel;Unsigned;0;1;0;0;1;bool;-;High voltage bus 5 (Not Used) request (negative & relevant positive contactor to be closed or opened) (0 = open, 1 = close);0x270;0;Cyclic;0\n"
"VSC_IsolDisbl_Req_bool;VSC_BatCmd;-;5;1;Intel;Unsigned;0;1;0;0;1;bool;-;Battery Pack Isolation monitor disable request (0 = enable, 1 = disable);0x270;0;Cyclic;0\n"
"VSC_ShutdownReq_bool;VSC_BatCmd;-;7;1;Intel;Unsigned;0;1;0;0;1;bool;-;Shutdown request to prepare system for shutting down (0 = no shutdown requested, 1 = shutdown requested);0x270;0;Cyclic;0\n"
"VSC_StorageModeReq_bool;VSC_BatCmd;-;12;1;Intel;Unsigned;0;1;0;0;1;bool;-;Storage Mode request prepare system for storage mode (0 = no storage mode requested, 1 = storage mode requested);0x270;0;Cyclic;0\n";
int dbc_index = 0;
char feedRowParser() {
return dbc[dbc_index++];
bool rowParserFinished() {
return dbc[dbc_index] == 0;
delay(5000);
CSV_Parser cp(dbc,"s--udud--dfd--s--ux---", true, ';');
Serial.println("Accessing values by column name:");
char **names = (char**)cp[0];
uint16_t *startbits = (uint16_t*)cp[3];
uint16_t *lengths = (uint16_t*)cp[4];
int16_t *initial_values = (int16_t*)cp[7];
float *factors = (float*)cp[8];
int16_t *offsets = (int16_t*)cp[9];
char **units = (char**)cp[12];
int32_t *message_ids = (int32_t*)cp[15];
int row_index = 0;
while (cp.parseRow()) {
char *name = names[0];
uint16_t startbit = startbits[0];
uint16_t length = lengths[0];
int16_t initial_value = initial_values[0];
float factor = factors[0];
int16_t offset = offsets[0];
char *unit = units[0];
int32_t message_id = message_ids[0];
Serial.print(String(row_index));
Serial.print(". Name: ");
Serial.print(name);
Serial.print(" | Startbit: ");
Serial.print(startbit, DEC);
Serial.print(" | Length: ");
Serial.print(length, DEC);
Serial.print(" | Initial Value: ");
Serial.print(initial_value, DEC);
Serial.print(" | Factor: ");
Serial.print(factor);
Serial.print(" | Offset: ");
Serial.print(offset, DEC);
Serial.print(" | Message ID: 0x");
Serial.print(message_id, HEX);
if (name == "BMS_AncVolt_V") {
Serial.println("Caught");
row_index++;
for (int i = 0; i < row_index + 1; i++) {
if (names[row_index] == "VSC_StorageModeReq_bool") {
Serial.println(names[row_index]);
cp.print();
