second set of eyes please, error code, functions not declared.
if someone could take a look and see why I'm getting the error code. I've looked for all the correct "{}" and tried moving my functions around and putting the function names in the globals. I really don't know what else to look for.
My coding skills still need practice.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
long randomNumber;
int randomA;
int randomB;
int randomC;
int randomD;
int randomCode;
int codeVal;
int realNumber;
int realA;
int realB;
int realC;
int realD;
int value;
int count;
int state;
int lastState;
int counter;
int relayPin = 5;
int SW = 2;
int CLK = 9;  // Pin 9 to clk on encoder
int DT = 8;  // Pin 8 to DT on encoder
  lcd.begin(16, 2);
  randomSeed(analogRead(0));
  pinMode (SW, INPUT);
  pinMode (CLK, INPUT);
  pinMode (DT, INPUT);
  pinMode  (relayPin, OUTPUT);
  counter = 5;
  count = 0;
  lastState = digitalRead(CLK);
  lcd.setCursor(0, 0);
  lcd.print("  Code  #");
  lcd.setCursor(0, 1);
  lcd.print(" Access #");
  lcd.setCursor(11, 0);
  lcd.print(randomCode);
  if (count == 0){
    randomGen();
  if (digitalRead(SW) == HIGH) {
    count++;
  switch (count) {  //RotPosition = counter
    case 1:
      select();
      realA = (counter * 1000);
      lcd.setCursor(11, 1);
      lcd.print(counter);
    case 2:
      lcd.print("*");
      select();
      realB = (counter * 100);
      lcd.setCursor(12, 1);
      lcd.print(counter);
    case 3:
      lcd.print("*");
      select();
      realC = (counter * 10);
      lcd.setCursor(13, 1);
      lcd.print(counter);
    case 4:
      lcd.print("*");
      select();
      realD = (counter * 10);
      lcd.setCursor(14, 1);
      lcd.print(counter);
    case 5:
      lcd.print("*");
      check();
int select() {
  state = digitalRead(CLK);
  if (state != lastState) {
    if (digitalRead(DT) != state) {
      counter++;
    else {
      counter--;
    count++;
int check() {
  realNumber = (realA + realB + realC + realD);
  codeVal = map (randomCode, 9999, 1111, 1111, 9999);
  if (codeVal == realNumber) {
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("    * ACCESS    ");
    lcd.setCursor(0,1);
    lcd.print("     GRANTED    ");
    digitalWrite(relayPin, HIGH);
    delay(3000);
    digitalWrite(relayPin, LOW);
    count = 0;
    counter = 5;
    lcd.clear();
    if (codeVal != realNumber) {
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("     ACCESS     ");
    lcd.setCursor(0,1);
    lcd.print("     DENIED     ");
    delay(3000);
    count = 0;
    counter = 5;
    lcd.clear();
int randomGen() {
  randomNumber = random(1, 10);
  randomA = (randomNumber * 1000);
  randomB = (randomNumber * 100);
  randomC = (randomNumber * 10);
  randomD = randomNumber;
  randomCode = (randomA + randomB + randomC + randomD);
  delay(100);
    count++;
  return randomCode;
LandonW:
It would be very helpful if you specified what "the error code" is. In fact, copy and post the complete error message(s) verbatim.
LandonW:
Auto format your code (ctrl-t) and look again. Remember, you're not allowed to define functions within functions.
[/quote]
Arduino: 1.8.5 (Windows 10), TD: 1.41, Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
C:\Users\Landon\Documents\Arduino\Random_Code_Safe\Random_Code_Safe.ino: In function 'void loop()':
Random_Code_Safe:53: error: 'randomGen' was not declared in this scope
randomGen();
C:\Users\Landon\Documents\Arduino\Random_Code_Safe\Random_Code_Safe.ino: In function 'int check()':
Random_Code_Safe:146: error: a function-definition is not allowed here before '{' token
int randomGen() {
Random_Code_Safe:159: error: expected '}' at end of input
exit status 1
option enabled in File -> Preferences.
See Reply #2.
Something that I found helpful when learing to code in C++ is to put every { and every } on their own lines. It is easier to see if the brackets are matched, especially in combination with autoformat.
if(something == somethingElse)
      // do this
      // do that
I auto format every 5 to 10 lines...
but I guess a } was missing on line 145.
Thanks, sometimes I feel like it a Where's Waldo in a 3D image book lol
