second void loop?
Hey guys,
I'm gonna use an arduino for my new project..
the big purpose of it will be to remotely control my device.
here are a few things to make my question clear (at least I hope so)
for starters. my device will be powered by 230v, this input has got a true on/off switch.
if this switch is on the device will be in stand-by mode.
in stand-by mode half of the 230v will be stopped by a relay.
the other half will be decreased to 12v dc, this will power a LED to show the stand-by mode
(so far nothing arduino related)
the 12v will continuly power the arduino, here comes the catch
I've got a push button which empowers the relay signal channel.
if the relay signal channel == 0 (RSC for short)
the arduino should only be able to read the push button AND the on/off button on a remote (due to IR)
both the physical button and the remote button are able to change the RSC to 1
let's say I've got two push buttons, one for the relay and one for a LED.
if RSC ==0 only the relay button works if RSC == 1 the LED button works and the relay button is reversed (to turn everything off)
so short story
if RSC == 0 nothing works except for the relay switch (physical and remotely)
if RSC == 1 all the scripts programmed work
so... there is my question.
is it possible to create a void loop with an if statement
void loop 1; if RSC == 0 "I'm working"
void loop 2; if RSC == 1 "I'm working"
or should I use only one loop and make a HUUGGE if statement
if RSC == 0 "nothing works except powering me up"
if RSC == 1 "everything works"
hope its clear for you guys what I mean to do
kind regards!
One loop function.
No huge “if”,
holdingpattern:
I got stuck at this bit:
Me too.
loop() is a function and a program cannot have two functions with the same name. Provided you use separate names you may have as many functions as you like. Have a look at Planning and Implementing a Program
...R
Hey guys,
Thanks for the replies..
Found some ways to do it
Cheers!
Can I suggest you approach one project at a time.
To quote;
I'm quite new in the world of arduino but I challenged myself in using an arduino for my new little project.
To many "little" projects...
Tom.... :slight_smile:
