secondary LED on Arduino Uno board will not light up properly.
were here with our Arduino Uno and every time we put in a secondary LED (port 8; but we've tried others) it glows much dimmer than it could. the main LED (Port 13; also have tried others) is fine and if we switch the two around (Main becomes secondary) the secondary still does not light up as much as it could. the code is correct and the LEDs are fine (we've tested with a battery), we just cannot get the secondary to completely light up.
Thanks
Dylan
7th grade
Saint Louis
Post your code, let's see.
You are using a current limit resistor with 2nd LED?
All we had to do was type pinMode("led name", OUTPUT);
That should set up the ground port for the LED.
Uriel A.
8th Grade
St. Louis
Grand Center Arts Academy (GCAA)
"All we had to do was type pinMode("led name", OUTPUT);
That should set up the ground port for the LED."
before setup declare the new LED and pin connection :-
int ledname = 8;
And then in Setup
pinMode("ledname", OUTPUT);
and in loop
digitalWrite ( ledname , HIGH);
and the LED connected to pin 8 ( via a resistor ! ) should light...
