secret knock code debuguing question
Hello everyone,
I'm very new to all electronic and programming stuff. Bought my Arduino few weeks ago and just been playing around.
I want to make secret clapping switch. For that I used this code that I have found online. But there is a problem. When I connect this microphone to input pin it start to give me non stop signal. Eaven when i take the mic out it continues to pick up some signal. I suppose the problem is in a code but just cannot find it.
Tried messing with the threshold. I made more simple clapper with this mic and it worked so I guess it's ok.
Thank you for your help.
   By Steve Hoefer http://grathio.com
   Version 0.1.10.20.10
   Licensed under Creative Commons Attribution-Noncommercial-Share Alike 3.0
   http://creativecommons.org/licenses/by-nc-sa/3.0/us/
   (In short: Do what you want, just be sure to include this line and the four above it, and don't sell it or use it in anything you sell without contacting me.)
const int knockSensor = 2;         // Piezo sensor on pin 0.
const int programSwitch = 2;       // If this is high we program a new code.
const int lockMotor = 3;           // Gear motor used to turn the lock.
const int redLED = 4;              // Status LED
const int greenLED = 5;            // Status LED
const int threshold = 15;
const int rejectValue = 25;
const int averageRejectValue = 15;
const int knockFadeTime = 150;     // milliseconds we allow a knock to fade before we listen for another one. (Debounce timer.)
const int lockTurnTime = 2000;      /
const int maximumKnocks = 20;       // Maximum number of knocks to listen for.
const int knockComplete = 1200;     /
int secretCode[maximumKnocks] = {50, 25, 25, 50, 100, 50, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};  // Initial setup: "Shave and a Hair Cut, two bits."
int knockReadings[maximumKnocks];   // When someone knocks this array fills with delays between knocks.
int knockSensorValue = 0;           // Last reading of the knock sensor.
int programButtonPressed = false;   // Flag so we remember the programming button setting at the end of the cycle.
  pinMode(lockMotor, OUTPUT);
  pinMode(redLED, OUTPUT);
  pinMode(greenLED, OUTPUT);
  pinMode(programSwitch, INPUT);
  Serial.begin(9600);                           // Uncomment the Serial.bla lines for debugging.
  Serial.println("Program start.");
  digitalWrite(greenLED, HIGH);
  // Listen for any knock at all.
  knockSensorValue = analogRead(knockSensor);
  if (digitalRead(programSwitch)==HIGH){  // is the program button pressed?
    programButtonPressed = true;          // Yes, so lets save that state
    digitalWrite(redLED, HIGH);           // and turn on the red light too so we know we're programming.
    digitalWrite(redLED, LOW);
  if (knockSensorValue >=threshold){
    listenToSecretKnock();
// Records the timing of knocks.
void listenToSecretKnock(){
  Serial.println("knock starting");
  int i = 0;
  // First lets reset the listening array.
  for (i=0;i<maximumKnocks;i++){
    knockReadings[i]=0;
  int currentKnockNumber=0;                     // Incrementer for the array.
  int startTime=millis();
  int now=millis();
  digitalWrite(greenLED, LOW);
  if (programButtonPressed==true){
  delay(knockFadeTime);
  do {
    //listen for the next knock or wait for it to timeout.
    if (knockSensorValue >=threshold){                   //got another knock...
      //record the delay time.
      Serial.println("knock.");
      now=millis();
      knockReadings[currentKnockNumber] = now-startTime;
      currentKnockNumber ++;                             //increment the counter
      startTime=now;
      // and reset our timer for the next knock
        digitalWrite(redLED, LOW);                       // and the red one too if we're programming a new knock.
      delay(knockFadeTime);                              // again, a little delay to let the knock decay.
    now=millis();
    //did we timeout or run out of knocks?
  } while ((now-startTime < knockComplete) && (currentKnockNumber < maximumKnocks));
  //we've got our knock recorded, lets see if it's valid
  if (programButtonPressed==false){             // only if we're not in progrmaing mode.
    if (validateKnock() == true){
      triggerDoorUnlock();
      Serial.println("Secret knock failed.");
      digitalWrite(greenLED, LOW);          // We didn't unlock, so blink the red LED as visual feedback.
      for (i=0;i<4;i++){
        delay(100);
        delay(100);
  } else { // if we're in programming mode we still validate the lock, we just don't do anything with the lock
    validateKnock();
    // and we blink the green and red alternately to show that program is complete.
    Serial.println("New lock stored.");
    for (i=0;i<3;i++){
      delay(100);
      delay(100);
// Runs the motor (or whatever) to unlock the door.
void triggerDoorUnlock(){
  Serial.println("Door unlocked!");
  int i=0;
  // turn the motor on for a bit.
  digitalWrite(lockMotor, HIGH);
  digitalWrite(greenLED, HIGH);            // And the green LED too.
  delay (lockTurnTime);                    // Wait a bit.
  digitalWrite(lockMotor, LOW);            // Turn the motor off.
  // Blink the green LED a few times for more visual feedback.
  for (i=0; i < 5; i++){
      delay(100);
      delay(100);
// Sees if our knock matches the secret.
// returns true if it's a good knock, false if it's not.
// todo: break it into smaller functions for readability.
boolean validateKnock(){
  int i=0;
  int currentKnockCount = 0;
  int secretKnockCount = 0;
  int maxKnockInterval = 0;                     // We use this later to normalize the times.
    if (knockReadings[i] > 0){
      currentKnockCount++;
    if (secretCode[i] > 0){                     //todo: precalculate this.
      secretKnockCount++;
    if (knockReadings[i] > maxKnockInterval){   // collect normalization data while we're looping.
      maxKnockInterval = knockReadings[i];
  // If we're recording a new knock, save the info and get out of here.
      for (i=0;i<maximumKnocks;i++){ // normalize the times
        secretCode[i]= map(knockReadings[i],0, maxKnockInterval, 0, 100);
      delay(50);
      for (i = 0; i < maximumKnocks ; i++){
        // only turn it on if there's a delay
          delay( map(secretCode[i],0, 100, 0, maxKnockInterval));
        delay(50);
      return false;
  if (currentKnockCount != secretKnockCount){
    return false;
  int totaltimeDifferences=0;
  int timeDiff=0;
    knockReadings[i]= map(knockReadings[i],0, maxKnockInterval, 0, 100);
    timeDiff = abs(knockReadings[i]-secretCode[i]);
    if (timeDiff > rejectValue){
      return false;
    totaltimeDifferences += timeDiff;
  if (totaltimeDifferences/secretKnockCount>averageRejectValue){
    return false;
  return true;
Do you mean "even when I leave the input floating, I pick up a signal"?
Nothing surprising there.
Is there a 1/2Vcc offset on the analog output of the mic module? Have you taken that into account?
Hi, thx for replying. The problem is that when I attach microphone on analog pins it keeps giving me signal.
I used regular pushbutton switch to try the code out and it worked. The signal was normal.
But when I attach it to the mic it goes wild. Maybe I'm not connecting it wright way
Hey all, tnx for the help.... It turns out that I just had to adjust threshold signal in the code and on the microphone potentiometar.
On the manufacturer site there is a code for reading the analog and digital signal and with spining the potentiometar U can adjust it as U want.
paparazzit:
Yeah, I saw that code. I think it's borrowed from somewhere else. Consider the line:
int sensorPin = A0; // select the input pin for the potentiometer
Should be the microphone, no? So I have no faith in that code, to tell me how the board should be interfaced. There's nowhere where it says whether the analogue output is audio, or a peak detector level. No schematics, to find out for myself.
The threshold pot is for the digital circuit.
