Secret knock lock
Hello all
i am trying to make a secret knock lock - you knock a certain pattern
Piezo speaker - sensor detects the pattern in case the pattern is correct activates a the relay ​(npn 222 transistor in my case) and opens the lock if incorrect then nothing
project link
https://www.instructables.com/Secret-Knock-Detecting-Door-Lock/
youtube video https://youtu.be/5bO_ICXuB70
so wired and uploaded code but something doesn't work as should
i tested every stage b4 going fwd with wiring aand it seems like everything is ok
but lock opens with any knock and it i addition keeps opening &lock every 3 seconds
(const int knockComplete = 3000; ) ???
when looking at the serial monitor it displays like everything is ok when pressing the button to register a new knock pattern it says registering a new pattern and than says new pattern stored and every time the locks open it says door open
but as it opens every 3 seconds and it response to any pattern instead of correct one
( maybe related to const int knockComplete = 3000;
equipment:
Arduino uno
  • Piezo speaker
  • pushbutton. (normally "off")
  • 1 Red LED
  • 1 Green LED
  • 1 NPN Transistor P2N2222A l
  • 1 Rectifier Diodedo.
  • 1 2.2k ohm resistor (1/4 watt)
  • 1 10k ohm resistor (1/4 watt)
  • 1 1M ohm resistor (1/4 watt)
  • 2 560 ohm resistor
    code
/* Detects patterns of knocks and triggers a motor to unlock */
// Pin definitions
const int knockSensor = 0;         // Piezo sensor on pin 0.
const int programSwitch = 2;       // If this is high we program a new code.
const int lockMotor = 3;           // Gear motor used to turn the lock.
const int redLED = 4;              // Status LED
const int greenLED = 5;            // Status LED
// Tuning constants.  Could be made vars and hoooked to potentiometers for soft configuration, etc.
const int threshold = 3;           // Minimum signal from the piezo to register as a knock
const int rejectValue = 25;        // If an individual knock is off by this percentage of a knock we don't unlock..
const int averageRejectValue = 15; // If the average timing of the knocks is off by this percent we don't unlock.
const int knockFadeTime = 150;     // milliseconds we allow a knock to fade before we listen for another one. (Debounce timer.)
const int lockTurnTime = 650;      // milliseconds that we run the motor to get it to go a half turn.
const int maximumKnocks = 20;       // Maximum number of knocks to listen for.
const int knockComplete = 1200;     // Longest time to wait for a knock before we assume that it's finished.
// Variables.
int secretCode[maximumKnocks] = {50, 25, 25, 50, 100, 50, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};  // Initial setup: "Shave and a Hair Cut, two bits."
int knockReadings[maximumKnocks];   // When someone knocks this array fills with delays between knocks.
int knockSensorValue = 0;           // Last reading of the knock sensor.
int programButtonPressed = false;   // Flag so we remember the programming button setting at the end of the cycle.
  pinMode(lockMotor, OUTPUT);
  pinMode(redLED, OUTPUT);
  pinMode(greenLED, OUTPUT);
  pinMode(programSwitch, INPUT);
  Serial.println("Program start.");
  digitalWrite(greenLED, HIGH);     .
  // Listen for any knock at all.
  knockSensorValue = analogRead(knockSensor);
  if (digitalRead(programSwitch)==HIGH){  // is the program button pressed?
    programButtonPressed = true;          // Yes, so lets save that state
    digitalWrite(redLED, HIGH);           // and turn on the red light too so we know we're programming.
    digitalWrite(redLED, LOW);
  if (knockSensorValue >=threshold){
    listenToSecretKnock();
// Records the timing of knocks.
void listenToSecretKnock(){
  Serial.println("knock starting");
  int i = 0;
  // First lets reset the listening array.
  for (i=0;i<maximumKnocks;i++){
    knockReadings[i]=0;
  int currentKnockNumber=0;         			// Incrementer for the array.
  int startTime=millis();           			// Reference for when this knock started.
  int now=millis();
  digitalWrite(greenLED, LOW);      			// we blink the LED for a bit as a visual indicator of the knock.
  if (programButtonPressed==true){
     digitalWrite(redLED, LOW);                         // and the red one too if we're programming a new knock.
  delay(knockFadeTime);                       	        // wait for this peak to fade before we listen to the next one.
  do {
    //listen for the next knock or wait for it to timeout.
    if (knockSensorValue >=threshold){                   //got another knock...
      //record the delay time.
      Serial.println("knock.");
      now=millis();
      knockReadings[currentKnockNumber] = now-startTime;
      currentKnockNumber ++;                             //increment the counter
      startTime=now;
      // and reset our timer for the next knock
      delay(knockFadeTime);                              // again, a little delay to let the knock decay.
    now=millis();
    //did we timeout or run out of knocks?
  } while ((now-startTime < knockComplete) && (currentKnockNumber < maximumKnocks));
  //we've got our knock recorded, lets see if it's valid
  if (programButtonPressed==false){             // only if we're not in progrmaing mode.
    if (validateKnock() == true){
      triggerDoorUnlock();
      Serial.println("Secret knock failed.");
      digitalWrite(greenLED, LOW);  		// We didn't unlock, so blink the red LED as visual feedback.
      for (i=0;i<4;i++){
        delay(100);
        delay(100);
  } else { // if we're in programming mode we still validate the lock, we just don't do anything with the lock
    validateKnock();
    // and we blink the green and red alternately to show that program is complete.
    Serial.println("New lock stored.");
    for (i=0;i<3;i++){
      delay(100);
      delay(100);
// Runs the motor (or whatever) to unlock the door.
void triggerDoorUnlock(){
  Serial.println("Door unlocked!");
  int i=0;
  // turn the motor on for a bit.
  digitalWrite(lockMotor, HIGH);
  digitalWrite(greenLED, HIGH);            // And the green LED too.
  delay (lockTurnTime);                    // Wait a bit.
  digitalWrite(lockMotor, LOW);            // Turn the motor off.
  // Blink the green LED a few times for more visual feedback.
  for (i=0; i < 5; i++){
      delay(100);
      delay(100);
// Sees if our knock matches the secret.
// returns true if it's a good knock, false if it's not.
// todo: break it into smaller functions for readability.
boolean validateKnock(){
  int i=0;
  // simplest check first: Did we get the right number of knocks?
  int currentKnockCount = 0;
  int secretKnockCount = 0;
  int maxKnockInterval = 0;          			// We use this later to normalize the times.
    if (knockReadings[i] > 0){
      currentKnockCount++;
    if (secretCode[i] > 0){  					//todo: precalculate this.
      secretKnockCount++;
    if (knockReadings[i] > maxKnockInterval){ 	// collect normalization data while we're looping.
      maxKnockInterval = knockReadings[i];
  // If we're recording a new knock, save the info and get out of here.
      for (i=0;i<maximumKnocks;i++){ // normalize the times
        secretCode[i]= map(knockReadings[i],0, maxKnockInterval, 0, 100);
      // And flash the lights in the recorded pattern to let us know it's been programmed.
      delay(50);
      for (i = 0; i < maximumKnocks ; i++){
        // only turn it on if there's a delay
          delay( map(secretCode[i],0, 100, 0, maxKnockInterval)); // Expand the time back out to what it was.  Roughly.
        delay(50);
	  return false; 	// We don't unlock the door when we are recording a new knock.
  if (currentKnockCount != secretKnockCount){
    return false;
  /*  Now we compare the relative intervals of our knocks, not the absolute time between them.
      (ie: if you do the same pattern slow or fast it should still open the door.)
      This makes it less picky, which while making it less secure can also make it
      less of a pain to use if you're tempo is a little slow or fast.
  int totaltimeDifferences=0;
  int timeDiff=0;
  for (i=0;i<maximumKnocks;i++){ // Normalize the times
    knockReadings[i]= map(knockReadings[i],0, maxKnockInterval, 0, 100);
    timeDiff = abs(knockReadings[i]-secretCode[i]);
    if (timeDiff > rejectValue){ // Individual value too far out of whack
      return false;
    totaltimeDifferences += timeDiff;
  // It can also fail if the whole thing is too inaccurate.
  if (totaltimeDifferences/secretKnockCount>averageRejectValue){
    return false;
  ![secret knock lock circuit|690x353](upload://4cElRqC6fqbCAacCZLHHC6O1Eaf.jpeg)
  return true;
```wiring diagram attached
 Thank you!![secret knock|544x484](upload://wpxoGlumO92EVgb2nTwsCb0td3U.png)
millis() returns an unsigned long which can hold larger values than an int. You are overflowing your variable
