see uploaded program?
I lost track of which program I uploaded. Is it possible to see the code that has been uploaded to an Arduino UNO by looking at the Arduino itself? thanks. (not hopeful, cuz I guess only the machine code is uploaded and not the text.) I tried searching for a key word that I know is in the program, but windows explorer doesnt seem to find text inside the ino files.
jgolden:
You guess correctly.
Unfortunately I'm not familiar enough with search in windows, but a quick google search appears to indicate you can add files with an .ino extension to the file content search, that may be your best option.
I use grepWin to search (from Windows Explorer) in any type of text file under Windows; under Linux, I use grep.
Windows nowadays seems to have a similar functionality but I have no idea of the name. You can google windows find in files and see what shows up.
My favourite Windows search tool is Agent Ransack Agent Ransack – Mythicsoft
It searches both for files and inside files
I know it does not solve your current problem but as a suggestion for the future, I always include this code in setup()
Serial.begin(38400);
 Serial.println("<Starting MyFile.ino >");
 Serial.print("<Filename ");
 Serial.print(__FILE__); // double underscores
 Serial.print(' ');
 Serial.print("  Compiled on ");
 Serial.print(__DATE__);
 Serial.print(" at ");
 Serial.print(__TIME__);
 Serial.println('>');
…R
EDIT to add the missing semi colon after Filename ")
Robin2:
Serial.print(' ');
...R
although there is a " ; " missing ( :slight_smile: ) that is something I needed. Thanks
Robin2:
Serial.print(' ');
...R
. Needs more F()
demkat1:
Thanks for spotting that. I have corrected it.
For some reason that is a mistake I make regularly with Serial.print statements (old age, I guess).
...R
AWOL:
. Needs more F()
Feel free to demonstrate your expertise.
I can't recall writing a program that used so much memory that the F() was obligatory. YMMV
...R
Robin2:
I can’t recall writing a program that used so much memory that the F() was obligatory. YMMV
…R
It’s not obligatory it’s a Good Habittm.
It helps avoid wheeltapper bugs
Windows finds files that have text I am searching for, and file extensions. It finds files only that have that extension and the searched text. But searching the ino files, neither search works for some reason. Wierd. I dont care for loading 2nd/3rd party software. There's gotta be a way to find this file.
jgolden:
depending to "adjustments" windows may NOT reveal files located in "locked" or "hidden" directories (for example , i had a "not found" problem with a .h file in Application Data)
