SEED Studio CAN Buss Wire.h problem
I'm trying to use a Seeed CAN buss I2C module.
Trying to compile the "get RPM example" I get the following compiler errors:
In file included from \\some path...\Coding\libraries\Seeed I2C_CAN_Arduino-main\Longan_I2C_CAN_Arduino.h:5:0,
                 from \\some path...\libraries\Seeed I2C_CAN_Arduino-main\Longan_I2C_CAN_Arduino.cpp:1:
\\some path...\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h: In member function 'bool I2C_CAN::IIC_CAN_GetReg(unsigned char, int, unsigned char*)':
\\some path...\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:68:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
     uint8_t requestFrom(int, int);
\\some path...\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src/Wire.h:65:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
     uint8_t requestFrom(uint8_t, uint8_t);
Reading other post about similar issues, I'm pretty sure it's a problem with the data type in the library function not being correct. I've tried a couple modifications, but i'm obviously out of my depth.
The example sketch:
    OBD-II_PIDs TEST CODE
    Loovee, Longan Labs 2022
    Query
    send id: 0x7df
      dta: 0x02, 0x01, PID_CODE, 0, 0, 0, 0, 0
    Response
    From id: 0x7E9 or 0x7EA or 0x7EB
      dta: len, 0x41, PID_CODE, byte0, byte1(option), byte2(option), byte3(option), byte4(option)
    https://en.wikipedia.org/wiki/OBD-II_PIDs
#include <Wire.h>
#include "Longan_I2C_CAN_Arduino.h"
I2C_CAN CAN(0x25);                                    // Set I2C Address
#define PID_ENGIN_PRM       0x0C
#define PID_VEHICLE_SPEED   0x0D
#define PID_COOLANT_TEMP    0x05
#define CAN_ID_PID          0x7DF
void set_mask_filt()
    // set mask, set both the mask to 0x3ff
    CAN.init_Mask(0, 0, 0x7FC);
    CAN.init_Mask(1, 0, 0x7FC);
    // set filter, we can receive id from 0x04 ~ 0x09
    CAN.init_Filt(0, 0, 0x7E8);
    CAN.init_Filt(1, 0, 0x7E8);
    CAN.init_Filt(2, 0, 0x7E8);
    CAN.init_Filt(3, 0, 0x7E8);
    CAN.init_Filt(4, 0, 0x7E8);
    CAN.init_Filt(5, 0, 0x7E8);
void sendPid(unsigned char __pid) {
    unsigned char tmp[8] = {0x02, 0x01, __pid, 0, 0, 0, 0, 0};
    CAN.sendMsgBuf(CAN_ID_PID, 0, 8, tmp);
bool getRPM(int *r)
    sendPid(PID_ENGIN_PRM);
    unsigned long __timeout = millis();
    while(millis()-__timeout < 1000)      // 1s time out
        unsigned char len = 0;
        unsigned char buf[8];
        if (CAN_MSGAVAIL == CAN.checkReceive()) {                // check if get data
            CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
            if(buf[1] == 0x41)
                *r = (256*buf[3]+buf[4])/4;
                return 1;
    return 0;
    while(!Serial);
    while (CAN_OK != CAN.begin(CAN_500KBPS)) {             // init can bus : baudrate = 500k
        Serial.println("CAN init fail, retry...");
        delay(100);
    Serial.println("CAN init ok!");
    set_mask_filt();
    int __rpm = 0;
    int ret = getRPM(&__rpm);
    if(ret)
        Serial.print("Engin Speed: ");
        Serial.print(__rpm);
        Serial.println(" rpm");
    }else Serial.println("get Engin Speed Fail...");
// END FILE
What I believe is the offending library file:
I2C_CAN::I2C_CAN(unsigned char __addr)
    IIC_ADDR = __addr;
void I2C_CAN::begin()
    Wire.begin();
void I2C_CAN::IIC_CAN_SetReg(unsigned char __reg, unsigned char __len, unsigned char *__dta)
    Wire.beginTransmission(IIC_ADDR);
    Wire.write(__reg);
    for(int i=0; i<__len; i++)
        Wire.write(__dta[i]);
    Wire.endTransmission();
void I2C_CAN::IIC_CAN_SetReg(unsigned char __reg, unsigned char __dta)
    Wire.write(__reg);
    Wire.write(__dta);
bool I2C_CAN::IIC_CAN_GetReg(unsigned char __reg, unsigned char *__dta)
    uint8_t my_size = 1; // MDR added
    Wire.write(__reg);
    //Wire.requestFrom(IIC_ADDR, 1);        //Original
    Wire.requestFrom(IIC_ADDR, my_size);    //MDR modify
    while(Wire.available())
        *__dta = Wire.read();
        return 1;
    return 0;
bool I2C_CAN::IIC_CAN_GetReg(unsigned char __reg, int len, unsigned char *__dta)  //ORIGINAL
//bool I2C_CAN::IIC_CAN_GetReg(uint8_t __reg, uint8_t len, uint8_t *__dta)  //MDR MODIFIED
    Wire.write(__reg);
    Wire.requestFrom(IIC_ADDR, len);
    //Wire.requestFrom( (int) IIC_ADDR, (int) len);    //MDR MODIFIED
    int __len = 0;
        __dta[__len++] = Wire.read();
    return (len == __len);
byte I2C_CAN::begin(byte speedset)                                      // init can
    Wire.begin();
    IIC_CAN_SetReg(REG_BAUD, speedset);
    delay(10);
    unsigned char __speed = 0;
    if(IIC_CAN_GetReg(REG_BAUD, &__speed))
        if(speedset == __speed)return 1;
    delay(100);
    return 0;
byte I2C_CAN::init_Mask(byte num, byte ext, unsigned long ulData)       // init Masks
    unsigned char dta[5];
    dta[0] = ext;
    dta[1] = 0xff & (ulData >> 24);
    dta[2] = 0xff & (ulData >> 16);
    dta[3] = 0xff & (ulData >> 8);
    dta[4] = 0xff & (ulData >> 0);
    unsigned char mask = (num == 0) ? REG_MASK0 : REG_MASK1;
    IIC_CAN_SetReg(mask, 5, dta);
    delay(50);
byte I2C_CAN::init_Filt(byte num, byte ext, unsigned long ulData)       // init filters
    dta[0] = ext;
    unsigned char filt = (7+num)*0x10;
    IIC_CAN_SetReg(filt, 5, dta);
    delay(50);
byte I2C_CAN::sendMsgBuf(unsigned long id, byte ext, byte rtr, byte len, byte *buf)     // send buf
    unsigned char dta[16];
    dta[0] = 0xff & (id >> 24);
    dta[1] = 0xff & (id >> 16);
    dta[2] = 0xff & (id >> 8);
    dta[3] = 0xff & (id >> 0);
    dta[4] = ext;
    dta[5] = rtr;
    dta[6] = len;
    for(int i=0; i<len; i++)
        dta[7+i] = buf[i];
    dta[15] = makeCheckSum(dta, 15);
    IIC_CAN_SetReg(REG_SEND, 16, dta);
byte I2C_CAN::sendMsgBuf(unsigned long id, byte ext, byte len, byte *buf)               // send buf
    sendMsgBuf(id, ext, 0, len, buf);
byte I2C_CAN::readMsgBuf(byte *len, byte *buf)                          // read buf
    readMsgBufID(&m_ID, len, buf);
byte I2C_CAN::readMsgBufID(unsigned long *ID, byte *len, byte *buf)     // read buf with object ID
    //IIC_CAN_GetReg(unsigned char __reg, int len, unsigned char *__dta)
    unsigned long id = 0;
    IIC_CAN_GetReg(REG_RECV, 16, dta);
    unsigned char __checksum = makeCheckSum(dta, 15);
    if(__checksum == dta[15])           // checksum ok
        id = dta[0];
        id <<= 8;
        id += dta[1];
        id <<= 8;
        id += dta[2];
        id <<= 8;
        id += dta[3];
        *ID = id;
        m_ID  = id;
        m_EXT = dta[4];
        m_RTR = dta[5];
        *len = dta[6];
        //Serial.print("readMsgBufID, len = ");
        //Serial.println(*len);
        if(*len > 8)return 0;
        for(int i=0; i<*len; i++)
            buf[i] = dta[7+i];
        return 1;
        //Serial.println("CHECKSUM ERROR");
        return 0;
byte I2C_CAN::checkReceive(void)                                        // if something received
    unsigned char num = 0;
    if(IIC_CAN_GetReg(REG_DNUM, &num))
        if(num > 0)
            return CAN_MSGAVAIL;
    return 0;
byte I2C_CAN::checkError(void)                                          // if something error
    return 0;
unsigned long I2C_CAN::getCanId(void)                                   // get can id when receive
    return m_ID;
byte I2C_CAN::isRemoteRequest(void)                                     // get RR flag when receive
    return m_RTR;
byte I2C_CAN::isExtendedFrame(void)                                     // did we recieve 29bit frame?
    return m_EXT;
unsigned char I2C_CAN::makeCheckSum(unsigned char *dta, int len)
    unsigned long sum = 0;
    for(int i=0; i<len; i++)sum += dta[i];
    if(sum > 0xff)
        sum = ~sum;
        sum += 1;
    sum  = sum & 0xff;
    return sum;
// END FILE
You will see some of the changes I tried (comment "MDR"). But I don't have a full grasp of the problem.
Any ideas?
Thank you.
