Seedstudio BT interface only green led flashing
After some time i trying to get the SeedStudio BT interface working again.
Uploaded the following sketch:
/* Upload this sketch into Seeeduino and press reset*/
#include <SoftwareSerial.h>   //Software Serial Port
#define RxD 6
#define TxD 7
#define DEBUG_ENABLED  1
#define PIN_TEMP    A1
SoftwareSerial blueToothSerial(RxD,TxD);
int getTemp()
    int a = analogRead(PIN_TEMP);
    int B=3975;
    float resistance = (float)(1023-a)*10000/a;
    float temperature = temperature=1/(log(resistance/10000)/B+1/298.15)-273.15;
    return (int)temperature;
    Serial.begin(19200);
    pinMode(RxD, INPUT);
    pinMode(TxD, OUTPUT);
    setupBlueToothConnection();
    char recvChar;
    while(1)
        if(blueToothSerial.available())
        {//check if there's any data sent from the remote bluetooth shield
            recvChar = blueToothSerial.read();
            Serial.print(recvChar);
            if(recvChar == 't' || recvChar == 'T')
                blueToothSerial.print("temperature: ");
                blueToothSerial.println(getTemp());
        if(Serial.available())
        {//check if there's any data sent from the local serial terminal, you can add the other applications here
            recvChar  = Serial.read();
            blueToothSerial.print(recvChar);
void setupBlueToothConnection()
    blueToothSerial.begin(38400);                           // Set BluetoothBee BaudRate to default baud rate 38400
    blueToothSerial.print("\r\n+STWMOD=0\r\n");             // set the bluetooth work in slave mode
    blueToothSerial.print("\r\n+STNA=ArduKMoto\r\n");    // set the bluetooth name as "SeeedBTSlave"
    blueToothSerial.print("\r\n+STOAUT=1\r\n");             // Permit Paired device to connect me
    blueToothSerial.print("\r\n+STAUTO=0\r\n");             // Auto-connection should be forbidden here
    delay(2000);                                            // This delay is required.
    blueToothSerial.print("\r\n+INQ=1\r\n");                // make the slave bluetooth inquirable
    Serial.println("The slave bluetooth is inquirable!");
    blueToothSerial.flush();
I do get the message that the device is inquirable but i cant see it on my phone or laptop.
Can see the laptop on the phone and the phone on the laptop.
The green led is flashing at a one second inter-fall. Any idee how to solve this problem?
Harry
