Seeed 2.8" TFT shield help and whatnot
So I know that i need to set up Tft.init(); but the only problem is it halts the gps shield after one loop even though i set it in void function. …And i know Tft.drawString is going to literally write what i put in quotes but i dont know how to put in lcdString as the String I want…Sorry I know nothing
Schultz :roll_eyes:
But i can tell you that it is a seeed v.1 Tft shield. I am using Tft library, I have tried UTFT but its too bulkey and i dont want to spend to time guessing what i can get rid of. I have a iTead v1.1 gps shield with SD and i can log to the SD fine. I had to change the baud rate of the itead shield to get the gps radio to work properly. So basically i want to print the lcdString I created to the screen and have it scroll or erase
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <stdint.h>
#include <TFT.h>
   This sample code demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 3(rx) and 2(tx).
static const int RXPin = 3, TXPin = 2;
static const uint32_t GPSBaud = 4800;
static char dtostrfbuffer[20];
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
//define String
String lcd_date ="invalid";
String lcd_lat = "invalid";
String lcd_lon = "invalid";
String lcdString = "";
  ss.begin(38400);
  ss.print("$PUBX,41,1,0007,0003,4800,0*13\r\n"); // Change iTead baudrate
  ss.flush();
  delay(50);
  ss.begin(4800); // reset SoftwareSerial baudrate
  ss.flush();
  delay(50);
  Serial.println(F("FullExample.ino"));
  Serial.println(F("An extensive example of many interesting TinyGPS++ features"));
  Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart,personalized by Jefe"));
  Serial.println(F("Sats HDOP Latitude   Longitude   Fix  Date       Time     Date Alt    Course Speed Card  Distance Course Card  Chars Sentences Checksum"));
  Serial.println(F("          (deg)      (deg)       Age                      Age  (m)    --- from GPS ----  ---- to London  ----  RX    RX        Fail"));
  Serial.println(F("---------------------------------------------------------------------------------------------------------------------------------------"));
  lcdString = lcd_date + "," + lcd_lat + "," + lcd_lon;
  Tft.drawString("lcdString",0,0,1,GREEN);
  static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  printInt(gps.satellites.value(), gps.satellites.isValid(), 5);
  printInt(gps.hdop.value(), gps.hdop.isValid(), 5);
  printFloat(gps.location.lat(), gps.location.isValid(), 11, 6,1);
  printFloat(gps.location.lng(), gps.location.isValid(), 12, 6,2);
  printInt(gps.location.age(), gps.location.isValid(), 5);
  printDateTime(gps.date, gps.time);
  printFloat(gps.altitude.meters(), gps.altitude.isValid(), 7, 2,0);
  printFloat(gps.course.deg(), gps.course.isValid(), 7, 2,0);
  printFloat(gps.speed.kmph(), gps.speed.isValid(), 6, 2,0);
  printStr(gps.course.isValid() ? TinyGPSPlus::cardinal(gps.course.value()) : "*** ", 6);
  unsigned long distanceKmToLondon =
    (unsigned long)TinyGPSPlus::distanceBetween(
      gps.location.lat(),
      gps.location.lng(),
      LONDON_LAT,
      LONDON_LON) / 1000;
  printInt(distanceKmToLondon, gps.location.isValid(), 9);
  double courseToLondon =
    TinyGPSPlus::courseTo(
      gps.location.lat(),
      gps.location.lng(),
      LONDON_LAT,
      LONDON_LON);
  printFloat(courseToLondon, gps.location.isValid(), 7, 2,0);
  const char *cardinalToLondon = TinyGPSPlus::cardinal(courseToLondon);
  printStr(gps.location.isValid() ? cardinalToLondon : "*** ", 6);
  printInt(gps.charsProcessed(), true, 6);
  printInt(gps.sentencesWithFix(), true, 10);
  printInt(gps.failedChecksum(), true, 9);
  smartDelay(1000);
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS data received: check wiring"));
// This custom version of delay() ensures that the gps object
// is being "fed".
static void smartDelay(unsigned long ms)
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
static void printFloat(float val, bool valid, int len, int prec, int lcdval)
  if (!valid)
    while (len-- > 1)
      Serial.print('*');
    Serial.print(' ');
    Serial.print(val, prec);
    if (lcdval == 1) lcd_lat = dtostrf(val,10,5,dtostrfbuffer);
    else if (lcdval == 2) lcd_lon = dtostrf(val,10,5,dtostrfbuffer);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1); // . and -
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(' ');
  smartDelay(0);
static void printInt(unsigned long val, bool valid, int len)
  char sz[32] = "*****************";
  if (valid)
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  smartDelay(0);
static void printDateTime(TinyGPSDate &d, TinyGPSTime &t)
  if (!d.isValid())
    Serial.print(F("********** "));
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d ", d.month(), d.day(), d.year());
    Serial.print(sz);
    lcd_date = sz;
  if (!t.isValid())
    Serial.print(F("******** "));
    char sz[32];
    sprintf(sz, "%02d:%02d:%02d ", t.hour(), t.minute(), t.second());
    Serial.print(sz);
  printInt(d.age(), d.isValid(), 5);
  smartDelay(0);
static void printStr(const char *str, int len)
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  smartDelay(0);
So I found out my problem with the Tft.init statement so i have gps data and a working lcd. Now the only problem is how to print the lcdString statement to the lcd. Any suggestions?? Tft.print and Tft.println dont seem to work so is there some other comand I can use with drawString?
