Seeed Arduino NFC Library
I am having difficulty getting this shield and code to work as detailed on this page:
I use the code for the IRQ2 communication method, and SPI interface.
I Get the following error:
C:\Program Files (x86)\Arduino\libraries\PN532_SPI/PN532_SPI.h:6:10: fatal error: PN532/PN532/PN532Interface.h: No such file or directory
#include "PN532/PN532/PN532Interface.h"
It seems somewhere in the include files the developer used a subfolder called:
"PN532_SPI/PN532_SPI.h"
I think it is because Linux uses forward slashes and Windows backslashes.
And thus the paths are not compatible.
Where do I find where this path has been used and fix it.
Really frustrating...
    #include <SPI.h>
    #include <PN532_SPI.h>
    PN532_SPI pn532spi(SPI, 10);
    NfcAdapter nfc = NfcAdapter(pn532spi);
    // FLAG_NONE used to signal nothing needs to be done
    #define FLAG_NONE 0
    // FLAG_IRQ_TRIGGERED used to signal an interrupt trigger
    #define FLAG_IRQ_TRIGGERED 1
    // FLAG_RESET_IRQ used to signal that the interrupt needs to be reset
    #define FLAG_RESET_IRQ 2
    // flags variable used to store the present flag
    volatile int flags = FLAG_NONE;
    String const myUID = "1B B3 C6 EF"; // replace this UID with your NFC tag's UID
    // LED pins
    int const greenLedPin = 3; // green led used for correct key notification
    int const redLedPin = 4; // red led used for incorrect key notification
    // the interrupt we'll be using (interrupt 0) is located at digital pin 2
    int const irqPin = 2; // interrupt pin
    String scannedUID = ""; // this is where we'll store the scanned tag's UID
    void setup(void) {
        // make LED pins outputs
        pinMode(greenLedPin,OUTPUT);
        pinMode(redLedPin,OUTPUT);
        Serial.begin(115200); // start serial comm
        Serial.println("NDEF Reader");
        nfc.begin(); // begin NFC comm
        // turn off the LEDs
        digitalWrite(greenLedPin,LOW);
        digitalWrite(redLedPin,LOW);
       // attach the function "irq" to interrupt 0 on the falling edges
       attachInterrupt(0,irq,FALLING);// digital pin 2 is interrupt 0, we'll call the irq function (below) on the falling edge of this pin
    void loop(void) {
        int flag = getFlag(); // get the present flag
        switch(flag) // check which flag/signal we are on
           case FLAG_NONE:
             // nothing needs to be done
           case FLAG_IRQ_TRIGGERED: // the interrupt pin has been triggered
               Serial.println("Interrupt Triggered");
               if (nfc.tagPresent())
                 // an NFC tag is present
                  NfcTag tag = nfc.read(); // read the NFC tag
                  scannedUID = tag.getUidString(); // get the NFC tag's UID
                  if(myUID.compareTo(scannedUID) == 0) // compare the NFC tag's UID with the correct tag's UID (a match exists when compareTo returns 0)
                    // the scanned NFC tag matches the saved myUID value
                    Serial.println("Correct tag/key");
                    blinkLed(greenLedPin,200,4); // blink the green led
                    // put your here to trigger the unlocking mechanism (e.g. motor, transducer)
                  }else{
                    // the scanned NFC tag's UDI does not match the myUID value
                    Serial.println("Incorrect tag/key");
                    blinkLed(redLedPin,200,4); // blink the red led
                    // DO NOT UNLOCK! an incorrect NFC tag was used.
                    // put your code here to trigger an alarm (e.g. buzzard, speaker) or do something else
                  // return to the original state
                  setFlag(FLAG_NONE);
                  reset_PN532_IRQ_pin();
               }else{
                 // a tag was not present (the IRQ was triggered by some other action)
                 setFlag(FLAG_NONE);
           default:
             // do any other stuff for flags not handled above
    * Name: setFlat
    * Description: used to set actions/flags to be executed in the loop(void) function
    * Parameters:
    *        int flag - the action/flag to store
    * Returns: void
    void setFlag(int flag)
      flags = flag;
    * Name: getFlag
    * Description: used to get the present flag/action
    * Parameters: void
    * Returns: int - the flags variable. The action/flag set by setFlag
    int getFlag()
      return flags;
    * Name: irq
    * Description: Interrupt service routine (ISR). This function will be executed whenever there is a falling edge on digital pin 2 (the interrupt 0 pin)
    * Parameters: void
    * Returns: void
    void irq()
      if(getFlag()==FLAG_NONE){
        setFlag(FLAG_IRQ_TRIGGERED);
    * Name: reset_PN532_IRQ_pin
    * Description: used to reset the PN532 interrupt request (IRQ) pin
    * Parameters: void
    * Returns: void
    void reset_PN532_IRQ_pin()
      nfc.tagPresent();
    * Name: blinkLed
    * Description: used to toggle a pin to blink an LED attached to the pin
    * Parameters:
    *      ledPin - the pin where the led is connected to
    *      delayTime - the time in milliseconds between HIGH and LOW
    *      times - the number of times to toggle the pin
    * Returns: void
    void blinkLed(int ledPin,int delayTime,int times)
      for(int i=0;i<times;i++){
        digitalWrite(ledPin,HIGH);
        delay(delayTime);
        digitalWrite(ledPin,LOW);
        delay(delayTime);
What do you mean, "somewhere in the include files..."? The compiler told you what file it's in.
