So I have an UNO(3) and I decided to go on the cheap and try out a camera. All of my research over the last few days is not giving me a whole lot on this specific shield. I have no problem getting the Serial to show me that it has ‘taken a picture’.
I either cannot see the picture on the SD car(Windows 8.1) after they are taken or I am getting the first few top bars. Is saving to the SD Card(Kens Cl4 - 8gb) the issue?
I have tried:
SdFat lib
JPEG extension for saving to card
Have NOT tested the camera by itself yet
Here is the card
http://www.seeedstudio.com/depot/Camera-Shield-p-2106.html
Wiki
http://www.seeedstudio.com/wiki/Camera_Shield
#include "SoftwareSerial.h"
#include <VC0706_UART.h>
#include <SD.h>
#include <SPI.h>
#define SS_SD 10
//use software serial
SoftwareSerial cameraconnection(2,3);//Rx, Tx
VC0706 cam = VC0706(&cameraconnection);
//use hardware serial
//VC0706 cam = VC0706(&Serial1);
Serial.println("VC0706 Camera Snapshot Test ...");
if (!SD.begin(SS_SD)) {
Serial.println("SD Card init failed...");
return;
if(true == cameraInit()){
snapShot();
}else{
Serial.println("camera init error...");
//nothing to do
bool cameraInit()
cam.begin(BaudRate_19200);
char *reply = cam.getVersion();
if (reply == 0) {
Serial.println("Failed to get version");
return false;
Serial.println("version:");
Serial.println("-----------------");
Serial.println(reply);
return true;
void snapShot()
Serial.println("Snap in 3 secs...");
delay(3000);
if (! cam.takePicture()){
Serial.println("Failed to snap!");
}else {
Serial.println("Picture taken!");
// Create an image with the name IMAGExx.JPG
char filename[13];
strcpy(filename, "IMAGE00.JPG");
for (int i = 0; i < 100; i++) {
filename[5] = '0' + i/10;
filename[6] = '0' + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! SD.exists(filename)) {
// Open the file for writing
File imgFile = SD.open(filename, FILE_WRITE);
Serial.print("create ");
Serial.println(filename);
uint16_t jpglen = cam.getFrameLength();
Serial.print("wait to fetch ");
Serial.print(jpglen, DEC);
Serial.println(" byte image ...");
int32_t time = millis();
cam.getPicture(jpglen);
uint8_t *buffer;
while(jpglen != 0){
uint8_t bytesToRead = min(32, jpglen);
buffer = cam.readPicture(bytesToRead);
imgFile.write(buffer, bytesToRead);
//Serial.print("Read "); Serial.print(bytesToRead, DEC); Serial.println(" bytes");
jpglen -= bytesToRead;
imgFile.close();
time = millis() - time;
Serial.println("Done!");
Serial.print("Took "); Serial.print(time); Serial.println(" ms");
cam.resumeVideo();
