WiFly Ver 2.23, 04-26-2011 on RN-171
MAC Addr=00:06:66:72:29:cf
S¦ý¥ÿþmÿSoftMDjoin mtDSoft
Auto-Assoc mtDSoft chan=7 mode=WPA2 SCAN OK
Joining mtDSoft now..
<2.23> Disconn from mtDSoft,AUTH-ERR
mtDSoft is my ssid and I’m sure about password, but I still get AUTH-ERR. I tried wpa2 and wpa, same result…
I am using Adruino Uno 3 + Seeed Studio Wifi Shield v 1.1.
As per instructions ..Wifi Shield V1.1 - Seeed Wiki
I was able to get response from Wifly module on serial monitor.
But suddenly now the module is not responding.It shows " Wifi shiedl not present".
What could be the problem..
Other examples run well on Adruino like serail communication,blinking Led etc.
I hv tried with many wifi shield libs..and versions.
pls share the ideal/suitable libs for Seeed studio wifi shield.
Find the attached Wifishield Library that I found on github.com
I followed this particular steps as mentioned in the forum from which i got the solution…
previously I had downloaded many libs and then copied them in library folder etc…but it didnt work…
So…I dont know due to library name conflict or so…it insisted to make a wifi lib folder as WiFly ONLY.
Unzip it. Create a new folder named WiFly in Adruino\arduino-1.0.3-windows\arduino-1.0.3\libraries\WiFly
Now Copy the contents of unzipped folder into ur Adruino\arduino-1.0.3-windows\arduino-1.0.3\libraries\WiFly .
Restart ur Adruino IDE and open the TCP example from WiFly->example->TCP.
compile n opload it.
open the serial monitor … and c the Wifly module get initialised.
I have downloaded various libraries for my seeed studio wifi shield and able to compile the test example. But I cannot connect to the wifi.
The wifi is working fine because I can connect to other devices.
Please help!!
