SEEED XIAO RP2040 uploads, but does not run
I have several SEEED rp2040 boards, and have tried to run and compile simple code, such as Blink.ino
I know that this sounds like a newbie question, but I am very familiar with Arduino with other boards. I am stuck on the RP2040.
The board and port are recognized properly. When I press the upload button in verbose mode, I receive the following output, which does not indicate any errors:
Sketch uses 58848 bytes (2%) of program storage space. Maximum is 2093056 bytes.
Global variables use 9640 bytes (3%) of dynamic memory, leaving 252504 bytes for local variables. Maximum is 262144 bytes.
"/Users/mscohen/Library/Arduino15/packages/rp2040/tools/pqt-python3/1.0.1-base-3a57aed-1/python3" -I "/Users/mscohen/Library/Arduino15/packages/rp2040/hardware/rp2040/4.7.1/tools/uf2conv.py" --serial "/dev/cu.usbmodem1101" --family RP2040 --deploy "/Users/mscohen/Library/Caches/arduino/sketches/096FF690349861577FA559168E3166DD/Blink.ino.uf2"
Resetting /dev/cu.usbmodem1101
Converting to uf2, output size: 151040, start address: 0x2000
Scanning for RP2040 devices
Flashing /Volumes/RPI-RP2 (RPI-RP2)
Wrote 151040 bytes to /Volumes/RPI-RP2/NEW.UF2
However the program does not run at all. I have tried this on 3 XIAO boards. I have the same problem with other skeleton programs. For example:
delay(2000);
Serial.println("Hello");
I am running Arduino IDE 2.3.5 on a Mac. I have installed version 4.7.1 of the “Raspberry Pi Pico/RP2040/RP2350” board manager, and the “https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json” into the settings. As I noted the board appears on my ports.
For what it’s worth, the same code runs properly on the SAMD21 QTPY boards.
I will be very grateful for any help
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
You followed all the steps from seed wiki?
Yes. As best I could, but they were not complicated.
How did you interpret this (from link in post #3) ?
Does it require an external USB/UART adaptor ?
Anyway, try first to start with the example to blink a led. If that works then proceed with the sketch to write to the serial monitor.
I interpret it as one of the many errors you will find in the Seeed Studio documentation.
I just tried it on my XIAO RP2040 and the sketch outputs to the USB CDC serial port of the board as expected.
