SeeedStudio 2km 433 MHz RF Module - why is there lost data?
I’m using the SeeedStudio 2km 433 MHz RF module
http://www.seeedstudio.com/depot/2KM-Long-Range-RF-link-kits-w-encoder-and-decoder-p-321.html
and I’ve been able to transmit data over my required distance (over 300 ft) including through 2 exterior walls plus some interior walls. Using the sketches below, I’m able to transmit 4 bit “packets”. The sketches transfer 1 packet/second, but I’m able to achieve a rate of about 6/second without errors by changing the delays. For the purpose of my question, let’s stay with 1/second as originally written.
The two sketches I’m using are:
Receiver:
RX:  2Km RF Receiver Code from this article: http://www.seeedstudio.com/forum/viewtopic.php?f=4&t=309&p=767&hilit=pt2262#p767
RF-->arduino/seeeduino
VT-->pin3;
D0-->pin4;
D1-->pin5;
D2-->pin6;
D3-->pin7;
GND-->GND;
VDD-->5v.
int data=0;
  pinMode(3,INPUT);
  pinMode(4,INPUT);
  pinMode(5,INPUT);
  pinMode(6,INPUT);
  pinMode(7,INPUT);
  attachInterrupt(1,RF_VT,RISING);
void RF_VT() // interrupt service function
  data=(digitalRead(4)<<3)+(digitalRead(5)<<2)+(digitalRead(6)<<1)+(digitalRead(7)<<0);
  Serial.print("data=");
  Serial.println(data,DEC);
Transmitter:
TX:  2Km RF Transmitter Code from this article: http://www.seeedstudio.com/forum/viewtopic.php?f=4&t=309&p=767&hilit=pt2262#p767
D0-->pin4;
D1-->pin5;
D2-->pin6;
D3-->pin7;
GND-->GND;
VDD-->5v.
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  unsigned char i=0;
  for(i=0;i<16;i++)
    send_data(i);
    Serial.print("i=");
    Serial.println(i,DEC);
    delay(500); // delay as short as 140 will work
    send_data(0);
    delay(500);  // delay as short as 10 will work
void send_data(unsigned char data)
  digitalWrite(4,(data&0x01));
  digitalWrite(5,(data&0x02));
  digitalWrite(6,(data&0x04));
  digitalWrite(7,(data&0x08));
The purpose of these sample sketches is to continuously transfer 4-bit packets starting at zero, going up to 15, then repeat.
When used this way, I reliably transfer packets for 2, 3, 4, …, 15, 2, 3, 4, …, 15 etc.
I believe I understand why ZERO doesn’t get transmitted. The code actually sends 0, 1, 0, 2, 0, 3, 0,4,… 0, 15, 0, 0, 0, 1 etc. and apparently the receiver module is looking for a transition from zero to something non-zero before firing an interrupt. So, OK.
But I do not receive ANY 1-packets. Seems like the transition from a packet of 4 zero bits (0000) to a packet of (0001) should be a transition and should work. But I never get this. Other packets with only 1 bit on (0010) (0100) and (1000) all come through fine.
Can anyone explain why the packet for “1” is always being lost? Thank you.
You can NOT do Serial.print() in an interrupt service routine.
Thank you. This was the sample I found, but I will re-code it to get the serial call out of the interrupt routine and try again.
