Seeeduino XIAO and RFM69HCW
Hi, does anyone know if the Seeeduino XIAO supports the RFM69HCW modules ? I have used the Sparkfun RFM69HCW Hookup Guide + RFM69_LowPowerLab examples for gateway / node but just cannot seem to get connectivity between my 2 devices.
Also, I am a bit of a Adruino noob..
Are you using a set of example sketches and wiring you had nothing to do with creating?
If they are both 3.3 volt devices, processor and radio, it should just work.
Post the sketches and wiring diagram, even a hand drawn schematic, or link to the schematic you following.
TIA
OIC you state you are in fact, I'll take a look, sry. If you have a link you'll save google a few dozen inquiries.
a7
OK, are you certainly provided adequate power?
The RFM69HCW will run on voltages from 1.8V to 3.6V , and can draw up to 130mA of current when it's transmitting.
And have you set the preferences in the IDE to provide all compiler warnings, and also then compiled or verified and found no warnings? Red ink in the copious output the build process creates?
The XIAO uses a different chip, perhaps the library is somehow quietly failing you.
a7
Thanks a7,
Pinout below.
and code..
// RFM69HCW Example Sketch
// Send serial input characters from one RFM69 node to another
// Based on RFM69 library sample code by Felix Rusu
// http://LowPowerLab.com/contact
// Modified for RFM69HCW by Mike Grusin, 4/16
// This sketch will show you the basics of using an
// RFM69HCW radio module. SparkFun's part numbers are:
// 915MHz: https://www.sparkfun.com/products/12775
// 434MHz: https://www.sparkfun.com/products/12823
// See the hook-up guide for wiring instructions:
// https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide
// Uses the RFM69 library by Felix Rusu, LowPowerLab.com
// Original library: https://www.github.com/lowpowerlab/rfm69
// SparkFun repository: https://github.com/sparkfun/RFM69HCW_Breakout
// Include the RFM69 and SPI libraries:
#include <RFM69.h>
#include <SPI.h>
#include <RFM69_ATC.h>     //get it here: https://www.github.com/lowpowerlab/rfm69
// Addresses for this node. CHANGE THESE FOR EACH NODE!
#define NETWORKID     0   // Must be the same for all nodes
#define MYNODEID      2   // My node ID
#define TONODEID      1   // Destination node ID
// RFM69 frequency, uncomment the frequency of your module:
#define FREQUENCY   RF69_433MHZ
//#define FREQUENCY     RF69_915MHZ
// AES encryption (or not):
#define ENCRYPT       false // Set to "true" to use encryption
#define ENCRYPTKEY    "1234567890" // Use the same 16-byte key on all nodes
#define IS_RFM69HW_HCW  //uncomment only for RFM69HW/HCW! Leave out if you have RFM69W/CW!
#define ENABLE_ATC    //comment out this line to disable AUTO TRANSMISSION CONTROL
#define ATC_RSSI      -80
// Use ACKnowledge when sending messages (or not):
#define USEACK        true // Request ACKs or not
// Create a library object for our RFM69HCW module:
#ifdef ENABLE_ATC
  RFM69_ATC radio;
#else
  RFM69 radio;
#endif
  // Open a serial port so we can send keystrokes to the module:
  Serial.print("Node ");
  Serial.print(MYNODEID,DEC);
  Serial.println(" ready");
  // Set up the indicator LED (optional):
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN,LOW);
  // Initialize the RFM69HCW:
  radio.setCS(3);  //uncomment this if using Pro Micro
  radio.setIrq(1);
  radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
  radio.setHighPower(); // Always use this for RFM69HCW
    radio.setPowerLevel(1); // power output ranges from 0 (5dBm) to 31 (20dBm)
  // Turn on encryption if desired:
  if (ENCRYPT)
    radio.encrypt(ENCRYPTKEY);
 #ifdef ENABLE_ATC
  radio.enableAutoPower(ATC_RSSI);
#endif
  // Set up a "buffer" for characters that we'll send:
  static char sendbuffer[62];
  static int sendlength = 0;
  // SENDING
  // In this section, we'll gather serial characters and
  // send them to the other node if we (1) get a carriage return,
  // or (2) the buffer is full (61 characters).
  // If there is any serial input, add it to the buffer:
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input != '\r') // not a carriage return
      sendbuffer[sendlength] = input;
      sendlength++;
    // If the input is a carriage return, or the buffer is full:
    if ((input == '\r') || (sendlength == 61)) // CR or buffer full
      // Send the packet!
      Serial.print("sending to node ");
      Serial.print(TONODEID, DEC);
      Serial.print(", message [");
      for (byte i = 0; i < sendlength; i++)
        Serial.print(sendbuffer[i]);
      Serial.println("]");
      // There are two ways to send packets. If you want
      // acknowledgements, use sendWithRetry():
      if (USEACK)
        if (radio.sendWithRetry(TONODEID, sendbuffer, sendlength))
          Serial.println("ACK received!");
          Serial.println("no ACK received");
      // If you don't need acknowledgements, just use send():
      else // don't use ACK
        radio.send(TONODEID, sendbuffer, sendlength);
      sendlength = 0; // reset the packet
      Blink(LED_BUILTIN,10);
  // RECEIVING
  // In this section, we'll check with the RFM69HCW to see
  // if it has received any packets:
  if (radio.receiveDone()) // Got one!
    // Print out the information:
    Serial.print("received from node ");
    Serial.print(radio.SENDERID, DEC);
    // The actual message is contained in the DATA array,
    // and is DATALEN bytes in size:
    for (byte i = 0; i < radio.DATALEN; i++)
      Serial.print((char)radio.DATA[i]);
    // RSSI is the "Receive Signal Strength Indicator",
    // smaller numbers mean higher power.
    Serial.print("], RSSI ");
    Serial.println(radio.RSSI);
    // Send an ACK if requested.
    // (You don't need this code if you're not using ACKs.)
    if (radio.ACKRequested())
      radio.sendACK();
      Serial.println("ACK sent");
void Blink(byte PIN, int DELAY_MS)
// Blink an LED for a given number of ms
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
Ok, received another Pro Mini 328 in the mail today.
soldered up in the last 30 minutes, used the same RFM module and worked instantly with same code, just changed the IRQ, CS pin asignments..
Still keen to see if I can get a Seed XIAO working as it is a really small form factor
