Seeeduino Xiao - CPU Clock - Slow Operations
Hey all. I recently switch over from the Pro Micro to the Seeediuno Xiao. Is a good board, love it so far.
After much time, I found out how to get the clock speed to the 48MHz speed and able to output it to a Pin and verify on my oscilloscope.
I am running FFT for a spectrum analyzer and have my test code just throwing random numbers in the array. What is puzzling is, when I count the millis() before and after I enable the clock settings, the time it takes to compute the FFT still stays the same... 109 millis for 512 samples. Am I possibly enabling the clocks wrong or not enabling the right thing or my logic is just silly?
Am using the develop version of arduinofft... meaning I can use floats instead of doubles for faster math operations.
I figured up the clock, to perform more operations per second, but im still at 100 milliseconds either way.
Any advice would be appreciated. Even if you just have a SAMD21 mc.
// I/O Ports definitions
#define PORTA     (0ul)
#define PORTB     (1ul)
//peripheral to link to output pin (DFLL48)
#define PERIPHERAL_H  0x07
// Constants for Clock Generators
#define GENERIC_CLOCK_GENERATOR_0   (0u)
#define GENERIC_CLOCK_GENERATOR_1   (1u)
#define GENERIC_CLOCK_GENERATOR_2   (2u)
#define GENERIC_CLOCK_GENERATOR_3   (3u)
#define GENERIC_CLOCK_GENERATOR_4   (4u)
//Constants for clock identifiers
#define CLOCK_XOSC32K  0x05
#define CLOCK_DFLL48  0x07
#define CLOCK_8MHZ    0x06
//////////// Normally a header file, copied for internets
#include <arduinoFFT.h>
#define SAMPLES    512
#define SAMPLING_FREQ 30000
unsigned int sampling_period_us;
unsigned long newTime;
float vReal[SAMPLES];
float vImag[SAMPLES];
int fftBin[8];
int fftCalc[8];
float weighingFactors[SAMPLES];
//arduinoFFT FFT = arduinoFFT(vReal, vImag, SAMPLES, SAMPLING_FREQ);
ArduinoFFT<float> FFT = ArduinoFFT<float>(vReal, vImag, SAMPLES, SAMPLING_FREQ, weighingFactors);
  gclkSetup();
  //sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQ));
  SerialUSB.begin(9600);
  while (!SerialUSB) { }
  long t0, t;
  t0 = millis();
  for(int i=0; i<SAMPLES; i++) {
    vReal[i] = i*SAMPLES;
    vImag[i] = 0;
    //while ((micros() - newTime) < sampling_period_us) { /* chill */ }
    //-- Compute FFT
  //FFT.DCRemoval();
  //FFT.windowing(FFTWindow::Hann,FFTDirection::Forward);
  //FFT.Windowing(FFTWindow::Hamming, FFTDirection::Forward);
  FFT.windowing(FFTWindow::Flat_top, FFTDirection::Forward);         // Flat Top Window - better amplitude accuracy
  FFT.compute(FFTDirection::Forward);
  FFT.complexToMagnitude();
  addFFT();
  t = millis()-t0;  // calculate elapsed time
  SerialUSB.print("Time: ");
  SerialUSB.println((int)t);
void addFFT() {
    // Reset fftBin & fftCalc
  for (int i = 0; i<8; i++){
    fftBin[i] = 0;
    fftCalc[i] = 0;
  // Analyse FFT results based on old FHT library.
  for (int i = 0; i < (SAMPLES/2); i++){
    //8 bins
    if (i<=0 )           fftCalc[0]  += vReal[i];
    if (i>0   && i<=1  ) fftCalc[1]  += vReal[i];
    if (i>1   && i<=2  ) fftCalc[2]  += vReal[i];
    if (i>2   && i<=6  ) fftCalc[3]  += vReal[i];
    if (i>6   && i<=13 ) fftCalc[4]  += vReal[i];
    if (i>13  && i<=31 ) fftCalc[5]  += vReal[i];
    if (i>31  && i<=73 ) fftCalc[6]  += vReal[i];
    if (i>73           ) fftCalc[7]  += vReal[i];
void gclkSetup() {
  //NVM CTRLB registers and RWS[3:0] bit for setting wait states fro a read operation  //Defaults to 0 and can go as high as 15 (4 bits)
  NVMCTRL->CTRLB.bit.RWS        = 1;    // 1 wait state required @ 3.3V & 48MHz
  //the system controller subsystem controls the clocks. The XOSC32K register sets up the External 32.768kHz oscillator
  SYSCTRL->XOSC32K.bit.WRTLOCK  = 0;    // XOSC32K configuration is not locked
  SYSCTRL->XOSC32K.bit.STARTUP  = 0x2;  // 3 cycle start-up time
  SYSCTRL->XOSC32K.bit.ONDEMAND = 0;    // Osc. is always running when enabled
  SYSCTRL->XOSC32K.bit.RUNSTDBY = 0;    // Osc. is disabled in standby sleep mode
  SYSCTRL->XOSC32K.bit.AAMPEN   = 0;    // Disable automatic amplitude control
  SYSCTRL->XOSC32K.bit.EN32K    = 1;    // 32kHz output is enable
  SYSCTRL->XOSC32K.bit.XTALEN   = 1;    // Crystal connected to XIN32/XOUT32
  // Enable the Oscillator - Separate step per data sheet recommendation (sec 17.6.3)
  SYSCTRL->XOSC32K.bit.ENABLE   = 1;
  // Wait for XOSC32K to stabilize
  while (!SYSCTRL->PCLKSR.bit.XOSC32KRDY);
  //Generic clock subsystem setting GENDIV register to set the divide factor for Generic clock 1
  GCLK->GENDIV.reg |= GCLK_GENDIV_DIV(1) | GCLK_GENDIV_ID(GENERIC_CLOCK_GENERATOR_1); //set divide factor for gen clock 1
  // Configure Generic Clock Generator 1 with XOSC32K as source
  GCLK->GENCTRL.bit.RUNSTDBY = 0;                         // Generic Clock Generator is stopped in stdby
  GCLK->GENCTRL.bit.DIVSEL   = 0;                         // enable clock divide
  GCLK->GENCTRL.bit.OE       = 0;                         // Disable generator output to GCLK_IO[1]
  GCLK->GENCTRL.bit.OOV      = 0;                         // We will not use this signal as an output
  GCLK->GENCTRL.bit.IDC      = 1;                         // Generator duty cycle is 50/50
  GCLK->GENCTRL.bit.GENEN    = 1;                         // Enable the generator
  GCLK->GENCTRL.bit.SRC      = CLOCK_XOSC32K;             // Generator source: XOSC32K output
  GCLK->GENCTRL.bit.ID       = GENERIC_CLOCK_GENERATOR_1; // This was created in Definitions.h, refers to generic clock 1
  // GENCTRL is Write-Synchronized...so wait for write to complete
  while (GCLK->STATUS.bit.SYNCBUSY);
  //Enable the Generic Clock  // Generic Clock Generator 1 is the source  //Generic Clock Multiplexer 0 (DFLL48M Reference)
  GCLK->CLKCTRL.reg |= GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN(GENERIC_CLOCK_GENERATOR_1) | GCLK_CLKCTRL_ID_DFLL48;
  // DFLL Configuration in Closed Loop mode, cf product data sheet chapter
  // 17.6.7.1 - Closed-Loop Operation
  // Enable the DFLL48M in open loop mode. Without this step, attempts to go into closed loop mode at 48 MHz will
  // result in Processor Reset (you'll be at the in the Reset_Handler in startup_samd21.c).
  // PCLKSR.DFLLRDY must be one before writing to the DFLL Control register
  // Note that the DFLLRDY bit represents status of register synchronization - NOT clock stability
  // (see Data Sheet 17.6.14 Synchronization for detail)
  while (!SYSCTRL->PCLKSR.bit.DFLLRDY);
  SYSCTRL->DFLLCTRL.reg = (uint16_t)(SYSCTRL_DFLLCTRL_ENABLE);
  // Set up the Multiplier, Coarse and Fine steps. These values help the clock lock at the set frequency
  //There is not much information in the datasheet on what they do exactly and how to tune them for your specific needs
  //lower values lead to more "overshoot" but faster frequency lock. Higher values lead to less "overshoot" but slower lock time
  //Datasheet says put them at half to get best of both worlds
  SYSCTRL->DFLLMUL.bit.CSTEP = 31; //max value is 2^6 - 1 or 63
  SYSCTRL->DFLLMUL.bit.FSTEP = 511; //max value is 2^10 - 1 or 1023
  SYSCTRL->DFLLMUL.bit.MUL = 1465; //multiplier of ref external clock to get to 48M --> 32768 x 1465 = 48,005,120
  // Wait for synchronization
  // To reduce lock time, load factory calibrated values into DFLLVAL (cf. Data Sheet 17.6.7.1)
  // Location of value is defined in Data Sheet Table 10-5. NVM Software Calibration Area Mapping
  uint32_t tempDFLL48CalibrationCoarse; // used to retrieve DFLL48 coarse calibration value from NVM
  // Get factory calibrated value for "DFLL48M COARSE CAL" from NVM Software Calibration Area
  tempDFLL48CalibrationCoarse = *(uint32_t*)FUSES_DFLL48M_COARSE_CAL_ADDR;
  tempDFLL48CalibrationCoarse &= FUSES_DFLL48M_COARSE_CAL_Msk;
  tempDFLL48CalibrationCoarse = tempDFLL48CalibrationCoarse >> FUSES_DFLL48M_COARSE_CAL_Pos;
  // Write the coarse calibration value
  SYSCTRL->DFLLVAL.bit.COARSE = tempDFLL48CalibrationCoarse;
  uint32_t tempDFLL48CalibrationFine; // used to retrieve DFLL48 coarse calibration value from NVM
  tempDFLL48CalibrationFine = *(uint32_t*)FUSES_DFLL48M_FINE_CAL_ADDR;
  tempDFLL48CalibrationFine &= FUSES_DFLL48M_FINE_CAL_Msk;
  tempDFLL48CalibrationFine = tempDFLL48CalibrationFine >> FUSES_DFLL48M_FINE_CAL_Pos;
  SYSCTRL->DFLLVAL.bit.FINE = tempDFLL48CalibrationFine;
  // Switch DFLL48M to Closed Loop mode and enable WAITLOCK
  SYSCTRL->DFLLCTRL.reg |= (uint16_t) (SYSCTRL_DFLLCTRL_MODE | SYSCTRL_DFLLCTRL_WAITLOCK);
  // Now that DFLL48M is running, switch CLKGEN0 source to it to run the core at 48 MHz.
  // Enable output of Generic Clock Generator 0 (GCLK_MAIN) to the GCLK_IO[0] GPIO Pin
  GCLK->GENCTRL.bit.DIVSEL   = 0;   // Use GENDIV.DIV value to divide the generator
  GCLK->GENCTRL.bit.OE       = 0;   // Enable generator output to GCLK_IO[0] (so we can output it to pin, setup below)
  GCLK->GENCTRL.bit.OOV      = 0;   // GCLK_IO[0] output value when generator is off
  //The next two lines are where we set the system clock
  GCLK->GENCTRL.bit.SRC = CLOCK_DFLL48;   // Generator source: DFLL48M output
  GCLK->GENCTRL.bit.ID = GENERIC_CLOCK_GENERATOR_0; // Generic clock gen 0 is used for system clock
  /*   //Generic clock 2 for ADC - Custom
    GCLK->GENDIV.reg |= GCLK_GENDIV_DIV(4) | GCLK_GENDIV_ID(GENERIC_CLOCK_GENERATOR_2); //set divide factor for gen clock 1
    // Configure Generic Clock Generator 2 with CLOCK_DFLL48 as source
    GCLK->GENCTRL.bit.SRC      = CLOCK_DFLL48;              // Generator source: DFLL48 output
    GCLK->GENCTRL.bit.ID       = GENERIC_CLOCK_GENERATOR_2; // This was created in Definitions.h, refers to generic clock 1
    while(GCLK->STATUS.bit.SYNCBUSY); */
  Clock_Bus_Setup();
void Clock_Bus_Setup() {
  //in power management system do not divide system clock down
  PM->CPUSEL.reg  = PM_CPUSEL_CPUDIV_DIV1;
  PM->APBASEL.reg = PM_APBASEL_APBADIV_DIV1_Val;
  PM->APBBSEL.reg = PM_APBBSEL_APBBDIV_DIV1_Val;
  PM->APBCSEL.reg = PM_APBCSEL_APBCDIV_DIV1_Val;
  /* Enable the APB clock for the ADC. */
  //PM->APBCMASK.reg |= PM_APBCMASK_ADC;
void aDCSetup() {
  /* Enable GCLK2 for the ADC */
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN_GCLK0 | GCLK_CLKCTRL_ID_ADC;
  /* Wait for bus synchronization. */
  while (GCLK->STATUS.bit.SYNCBUSY) {};
  // Select reference
  REG_ADC_REFCTRL = ADC_REFCTRL_REFSEL_INTVCC1; //set vref for ADC to VCC
  // Average control 1 sample, no right-shift
  REG_ADC_AVGCTRL |= ADC_AVGCTRL_SAMPLENUM_1;
  // Sampling time, no extra sampling half clock-cycles
  REG_ADC_SAMPCTRL = ADC_SAMPCTRL_SAMPLEN(0);
  // Input control and input scan
  REG_ADC_INPUTCTRL |= ADC_INPUTCTRL_GAIN_DIV2 | ADC_INPUTCTRL_MUXNEG_GND | ADC_INPUTCTRL_MUXPOS_PIN0;
  while (REG_ADC_STATUS & ADC_STATUS_SYNCBUSY);
  ADC->CTRLB.reg |= ADC_CTRLB_RESSEL_10BIT | ADC_CTRLB_PRESCALER_DIV128 | ADC_CTRLB_FREERUN; //This is where you set the divide factor, note that the divide call has no effect until you change Arduino wire.c
  //Wait for synchronization
  ADC->WINCTRL.reg = ADC_WINCTRL_WINMODE_DISABLE; // Disable window monitor mode
  while (ADC->STATUS.bit.SYNCBUSY);
  ADC->EVCTRL.reg |= ADC_EVCTRL_STARTEI; //start ADC when event occurs
  ADC->CTRLA.reg |= ADC_CTRLA_ENABLE; //set ADC to run in standby
  ADC->SWTRIG.reg = ADC_SWTRIG_START; // Start ADC conversion
  while (ADC->STATUS.bit.SYNCBUSY); // Wait for sync
If I understand your issue, you are doing a timing check before configuring clocks and after, with results being the same.
I am not totally sure if this is the answer to your issue but the “startup.c” file that runs when the Xiao resets does the following :
  • Enables the XOSC32K clock.
  • Sets XOSC32K as source for Generic Clock Generator 1
  • Sets Generic Clock Generator 1 as source for Generic Clock Multiplexer 0 (DFLL48M reference)
  • Enable DFLL48M clock
  • Switch Generic Clock Generator 0 to DFLL48M. CPU will run at 48MHz
  • Modify prescaler value of OSC8M to have 8MHz
  • Set OSC8M as source for Generic Clock Generator 3
So after restart,
Generic Clock Generator 0 uses DFLL48M. CPU runs at 48MHz.
Generic Clock Generator 1 uses XOSC32K at 32.768KHz
Generic Clock Generator 3 uses OSC8M at 8MHz
This would appear to be exactly the same as your coding I think hence there will be no difference before and after your clock initialisation. It effectively has already been done for you.
Hope that provides some insight if I am correct!
I am playing with the clocks a lot at the moment. For some reason it appears that the XOSC32K runs at 32.773 KHz, not at 32.768. Not particularly useful for accurate long term clocking applications!
