Seeing initial pin output in AutoIT
I've "inherited" a job at work where we are using an Arduino Nano with a relay to bring on a beacon, using a really simple AutoIT script.
All the script does is literally turn a beacon on and off, depending if there is some text in a window or not.
The problem I'm having is that at the start of the script, I'd like it to know what state the beacon is in - off or on. I thought that would be simple, and it may well be for someone who hadn't just seen an Arduino for the first time four days ago :slight_smile:
Anyway, here's my (very very basic script):
int led = 12;
  pinMode(led, OUTPUT);
    int data = Serial.read();
    if (data == '0') //Off
      digitalWrite(led, LOW);
      Serial.print("Beacon off");
    if (data == '1') //On
      digitalWrite(led, HIGH);
      Serial.print("Beacon on");
When I run AutoIT, I'd like it to tell me the beacon's initial state straight away, just once. If I turn the beacon on I can see "Beacon on" in the console, and if I turn it off I can see "Beacon off", so that bit works perfectly. But I'd like the console to detect the state of pin 12 and report that before I turn it off or on.
I've tried putting digitalRead(led) in various parts of the script, but I only ever see a blank line in AutoIT's console.
Where am I going wrong?!
Thanks,
Graybags
