I'm looking for a sketch that inputs sensor data in the form of a square wave and outputs the processed data to a LED display. (This is my first project.)
Here's where to do that.
Gigs and Collaborations
Just pay someone some money and they will do it for you.
OR you could use google to find examples of each individual component in use. Try the tutorials yourself. Come here with questions if you are stumped. Then after you have both the sensor and the display working independently, try to combine them.
You will find many people here are more than willing to help you if you help yourself.
If your goal is to do it yourself, tell us more about the sensor and the display.
Links to the product and the data sheets help a lot.
To vinceherman
Thanks for the tips. I do want to do it myself, but I need help getting started.
Using your search tip I found some code that I can modify for the sensor side. I will now search for code for the display side.
When I complete my straw man sketch I will run it past the forum for comment.
