Hi everyone,
First of all, a disclaimer: I’m a beginner in microelectronics. So far, I’ve only worked on a couple of small projects using ESP8266, primarily for reading and logging air conditioner temperatures and displaying the data on a web interface.
Now, I’m aiming higher. I want to build a water top-off system for my 500L aquarium in my country house. The air there is very dry, so water evaporates quickly, and I’m often away for weeks at a time.
Here’s the system I envision:
- A 100L water container near the aquarium.
- A water level sensor (JSN-SR04T) in the aquarium to monitor water levels.
- Another JSN-SR04T sensor in the water container to track remaining water.
- An ATMAN PH4000 pump installed in the water container.
- The pump will be connected to a power outlet, which will be controlled by an SSR-25DA relay (chosen for reliability over the SRD-05VDC-SL).
- Two DS18B20 temperature sensors for monitoring the water temperature in the aquarium and the container.
- A YF-S201 water flow sensor to track the amount of water added.
- Finally, I plan to use an ESP32 Wroom-32 (30 pin) to control everything via Wi-Fi and have a web interface.
Here’s my main problem:
The ESP32 operates on 3.3V, but from what I understand, some of my components (like the relay and certain sensors) require 5V for proper operation. I’m stuck on how to connect everything correctly.
Should I consider using a different controller, or is there a solution to make this setup work with ESP32?
I’d greatly appreciate any advice or guidance from this community!
Thanks!
