Hello Arduino Geniuses,
Thank you Everyone for taking the time to read my very first post on this Awesome Forum.
I want to SHOUT OUT to MR DELTA_G and MR STERRETJE for helping me solving my last puzzle. Thank you for your great support and guidance.
I am trying to build a conveyor belt using IR Sensor and two DC motor.
However im getting confused on how to join these two seperate sketch together.
here are my sketch.
FIRST SKETCH (1A)
/*with this sketch
- IR sensor will keep the LED on and when object is detected
- the light will be off and start again.
- THIS IS TEST CODE
int led = 11; // declaring LED to pin 11 of Arduino.
int ledOff; // declaring LED Off open integer .
int count = 0;
pinMode(A0,INPUT);
pinMode(A1,OUTPUT);
pinMode(A2,OUTPUT);
pinMode(led,OUTPUT);
pinMode (13, OUTPUT);
digitalWrite(A2,HIGH);
digitalWrite(A1,LOW);
void loop () {
//Serial.println(analogRead(A0)); // this will print the IR sensor value.
//delay(100); // printing delay.
if(analogRead(A0) < 250) // less then 250 means there is an obstacle
{digitalWrite(11,LOW); // LED will be OFF
count++;
Serial.println (count);
delay (5000); // LED off for 5 seconds
digitalWrite (11,HIGH); // LED ON again
delay (3000);} // for 3 seconds
else // if IR doesnt sense an obstacle
digitalWrite(11,HIGH); // LED will be ON continiously
HERE IS THE SECOND SKETCH (2A)
// connect motor controller pins to Arduino digital pins
// motor one
int enA = 10;
int in1 = 9;
int in2 = 8;
// motor two
int enB = 5;
int in3 = 7;
int in4 = 6;
// set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
void loop ()
// this function will run the motors in both directions at a fixed speed
// turn on motor A
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// set speed to 255 out of possible range 0~255
analogWrite(enA, 255);
// turn on motor B
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
analogWrite(enB, 255);
delay(2000);
// REQUIREMENT
// i need to join this sketch with the IR SENSOR Sketch
// so that when the LED is OFF the motors will move in one direction
// and after 4 obstruction on the IR sensor (count ==4)
// the motors will Rotate in the opposing direction
// and when (count == 0) the motors will change direction again..
// now change motor directions
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
delay(2000);
// now turn off motors
demoOne();
delay(5000);
// REQUIREMENT
// and keep it on the loop.
I am seeking your valuable guidance .
kind regards
LordStark.
