Hello.
Maybe youse guys with more Arduino experience and brain power can point me to solutions for an issue, I'll try to be brief in my descriptions... ...famous last words.
I'm running an Arduino routine on a Mega to drive stepper motors for an industrial machine. 2 of the motors have quadrature optical encoders that provide positional feedback, and the code for this feedback, processed by 4 interrupts, modifies the next motor rotation step counts. This is all fine.
But now I need to use the encoder pulses, I think, the 4 ISR flags to count motor rotations, forward and backward, provide this info to the serial monitor, and also when the steppers are not in use (though the encoders are powered, the motors are not enabled). The machine transports can be advanced by hand during mechanical set-up.
Can anyone suggest a method to use the ISR flags or some other approach to count all motor rotations from init, in a way that can print-out for the operator in real-time without slowing the machine down?
I made a quick attempt at the bottom of the code in the 'encoder correction and debug' section at the bottom. It sort of works but it slows down the routine and doesn't really work properly.
I have extracted the relevant ISR code and definitions, to keep the long stepper drive code from bogging you down here. I can include more if it can't be understood without it.
Thanks in advance for your time!
-girgs
/* ************* 2 Stepper motors with optical quaderature encoder feedback via ISR,
***************** used to maintain lock to 'home' positions and further to use
***************** ISR flags to count motor rotations, forward and backwards, and real-time println
* This needs not to slow down the machine movement and needs to be active when
* the steppers are not enabled, as the motors can be turned by hand, non-energized.
* This code extracts the relevant ISR and encoder sections only, leaving out
* a lot of code that drives the steppers, just to keep it simpler for viewing.
* This is used with a Mega. The two steppers are called "Camera" and "Projector"
#define CAMERAA 18
#define CAMERAB 19
#define PROJECTORA 20
#define PROJECTORB 21
#define CAMFIRST 1285 // stepper home position points, in 2K steps
#define PROJFIRST 976
#define FADERFIRST 1285
#define CAMBACK 516
#define PROJBACK 831
#define FADERBACK 516
int trx18, trx20; // captures rotation position of camera A projector A. Forward
int trx19, trx21; // captures rotation position of camera B and projector B, Reverse
volatile boolean flag18, flag19, flag20, flag21;
int camcount, projcount;
int correctcam = 0, correctproj = 0;
int CameraOptoA = 0;
int ProjectorOptoA = 0;
int lastCamFrameCount = -1;
int lastProjFrameCount = 0;
int CamHomePin = 18; // Pin for input Aø camera encoder
int CamHomePinB = 19; // Pin for input Bø camera encoder
int ProjHomePin = 20; // Pin for input Aø Projector encoder
int ProjHomePinB = 21; // Pin for input Bø Projector encoder
int i; // general index
volatile boolean flag18=false, flag19=false, flag20=false, flag21=false;
pinMode(CamHomePin, INPUT); // Pin set at point in Cam motor rotation
pinMode(CamHomePinB, INPUT); // B home pin
pinMode(ProjHomePin, INPUT); // Pin set at point in Proj motor rotation
pinMode(ProjHomePinB, INPUT); // Pin home B
attachInterrupt(5, set18, RISING); // Camera first transition, Interrupt#, ISRname, mode
attachInterrupt(4, set19, RISING); // Camera B transition
attachInterrupt(3, set20, RISING); // Projector first transition
attachInterrupt(2, set21, RISING); // Projector B transition
Serial.begin(38400); // set speed for reading from serial line
} // end of one time module setup
// ********* ISRs ***********
void set18() { // Interrupt module 5
trx18 = camcount; // count seen at location (loc)
flag18 = true; // create cameraA encoder event Tick
void set19() { // Interrupt module 4
trx19 = camcount; // capture location at interrupt
flag19 = true; // create ProjectorA encoder event Tick
void set20() { // Interrupt module 3 for histogram
trx20 = projcount; // count seen at location (loc)
flag20 = true; // create CameraB encoder event Tick
void set21() { // Interrupt module 2
trx21 = projcount; // Capture location when signal changes
flag21 = true; // create ProjectorB encoder event Tick
void loop() { //to get the full TOTALSTEPS = 2000, takes about .25 seconds.
// a bunch of code for stepper drive
boolean waiting=true; // To accumulate number and command
boolean camsel=false, projsel=false, fadersel=false; // true for transport enables
boolean adjust=true; // Correction but protected to take place only after transition sample has been seen
boolean DoLoop=true; // cycle through action command
boolean prnt = false; // HIDE print transitions, debug homing precision
boolean forward = true;
boolean projforward=true, camforward=true, faderforward=true;
steps = 0;
while(waiting) { // - 2 waiting for command entry
// a bunch of code for CASE stepper drive commands, serial monitor print
// *********** MAIN EVENTS ************
} // if serial available - 2
} // while waiting - 1
correctcam = 0;
correctproj = 0;
DoLoop = true;
while(DoLoop) { // - 2
// a ton of code for stepper drive
// ********* Encoder Correction and Debug **********
if(prnt) {
gona=2000+correctcam;
Serial.print("Camera steps to Home / steps taken ");
Serial.print(gona, DEC);
Serial.print(" / ");
Serial.println(camcount, DEC);
gona=2000-correctproj;
Serial.print("Projector steps to Home / steps taken ");
Serial.println(projcount, DEC);
if(adjust) { // - 4
if(forward) { // - 5
if(trx18 != 0) correctcam = trx18-CAMFIRST-correctcam;
if(trx20 != 0) correctproj = trx20-PROJFIRST-correctproj;
} // - 4
else { // - 5
if(trx18 != 0) correctcam = trx18-CAMBACK-correctcam;
if(trx20 != 0) correctproj = trx20-PROJBACK-correctproj;
} // - 4
} // - 3 end adjust
if (flag18) { // -4
CameraOptoA++;
delay(250);
} // - 4
else { // - 5
if(flag19)
CameraOptoA--;
delay(250);
// if (lastFrameCount != CamApulses) { // - 4 only do output if the count has changed
Serial.print ("CF = "); // out to serial
Serial.println(CameraOptoA, DEC);
} // - 3
lastCamFrameCount = CameraOptoA; // end track count
if (flag20) { // -4
ProjectorOptoA++;
delay(250);
} // - 4
else { // - 5
if(flag21)
ProjectorOptoA--;
delay(250);
Serial.print ("PF = "); // out to serial
Serial.println(ProjectorOptoA, DEC);
} // - 3
lastProjFrameCount = ProjectorOptoA; // end track count
USE FLAGS to Tick FRAME COUNTS here?
Serial.print(" Encoder Pulses ");
Serial.print(flag18, BIN);
Serial.print(flag19, BIN);
Serial.print(flag20, BIN);
Serial.println(flag21, BIN);
if(prnt) { // - 4 show transitions
Serial.print(" Pin 18/Pin 19/Pin 20/Pin 21/ ");
Serial.print(trx18, DEC);
Serial.print(trx19, DEC);
Serial.print(trx20, DEC);
Serial.print(trx21, DEC);
Serial.print(" Correction for Camera and Projector /");
Serial.print(correctcam, DEC);
Serial.println(correctproj, DEC);
} // - 3
trx18 = 0;
trx20 = 0;
} // - 2 cycles end
DoLoop = false;
} // - 1 while loop
digitalWrite(CamEnablePin, HIGH); // Stepper idles
digitalWrite(ProjEnablePin, HIGH); //
digitalWrite(FaderEnablePin, HIGH); //
} // routine void - 0
