Seems to me that it skips code
Simple Led rings doing colorWipe with no delay.
Runs like I expect it to with only a siingle line for each ring. When I enter a second colorWipe for each it seems to skip the first lines of code and only loop he second of each. I expect the first wipe to be slower than the second wipe for each ring.
#define PIN 12
#define PIN2 13
// adjust this to use the correct pin
Adafruit_NeoPixel strip = Adafruit_NeoPixel(14, PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip2 = Adafruit_NeoPixel(14, PIN2, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip2.begin();
  strip.setBrightness(10);
  strip2.setBrightness(10);
  strip.show();
  strip2.show();
  colorWipe(strip.Color(0, 255, 0), 100);
  colorWipe2(strip2.Color(0, 0, 255), 100);
  colorWipe(strip.Color(0, 255, 0), 25);
  colorWipe2(strip2.Color(0, 0, 255), 25);
void wipe() {  // clear all LEDs
  for (int i = 0; i < strip.numPixels(); i++) {
    strip.setPixelColor(i, strip.Color(0, 0, 0));
void wipe2() {  // clear all LEDs
  for (int i = 0; i < strip2.numPixels(); i++) {
    strip2.setPixelColor(i, strip2.Color(0, 0, 0));
  colorWipe
  In:
    desired color
    wait time between updates
  Returns:
    true if colorWipe in progress, else false
bool colorWipe(uint32_t color, unsigned int wait) {
  // keep track of which pixel needs to be updated
  static byte pixelNum;
  // remember if we are in progress
  static bool inProgress = false;
  // last time that a pixel was updated
  static uint32_t lastUpdateTime;
  // if first time for a cycle
  if (inProgress == false) {
    lastUpdateTime = millis();
    // indicate that one cycle is complete
    inProgress = true;
  if (pixelNum == 0 || millis() - lastUpdateTime >= wait) {
    // update the pixel
    strip.setPixelColor(pixelNum, color);
    strip.show();
    // next time, next pixel
    pixelNum++;
    // if we have reached the number of pixels
    if (pixelNum >= strip.numPixels())
      // reset pixelNum
      pixelNum = 0;
      inProgress = false;
      wipe();
  // indicate to caller the status of the colorWipe cycle
  return inProgress;
bool colorWipe2(uint32_t color, unsigned int wait) {
    inProgress = true;
    // update the pixel
    strip2.setPixelColor(pixelNum, color);
    strip2.show();
    pixelNum++;
    if (pixelNum >= strip2.numPixels()) {
      // reset pixelNum
      pixelNum = 0;
      inProgress = false;
      wipe2();
  return inProgress;
You forgot show()' after your wipes.
Wait, no.. There's more code down there.
Something to look at..
Async Leds..
good luck.. ~q
I think your program can be much simpler.
This simulation of a similar idea to yours uses a different library, but you can see how two simultaneous color wipes do not need to take many lines of code.
