Segment effects
Hello,
I ended up, very laboriously, writing the attached project.
I would like to be able to trigger the animation of each segment, either by an external impulse, or on an input that would move forward one step, or by an input specific to each segment.
Or by a timing that could be more than an hour between each one.
I'm brewing tutos in all directions but I can't manage to implement them.
If someone could give me clues, I'd take them.
I am also looking for a sweeping effect that lights the LEDs one by one and leaves them on.
I use a UNO card and WS2812B strips.
Thank you for your attention.
As the English language is not mine, I only speak French, thank you for your indulgence for the machine translation
#include <WS2812FX.h>
#define LED_PIN    3  // n° de PIN Uno
#define LED_COUNT 75  // nombre de LEDs
WS2812FX ws2812fx = WS2812FX(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
  ws2812fx.init();
  ws2812fx.setBrightness(128);
  // parameters: index, start, stop, mode, color, speed, reverse
//TESTS
 ws2812fx.setSegment(0, 0, 14, FX_MODE_COMET, 0x00ff00, 1000, true);
 ws2812fx.setSegment(1, 15, 29, FX_MODE_COMET, 0x0000ff, 1000, false);
 ws2812fx.setSegment(2, 30, 44, FX_MODE_COMET, 0xff0000, 1000, true);
 ws2812fx.setSegment(3, 45, 59, FX_MODE_COMET, 0xC71585, 1000, false);
 ws2812fx.setSegment(4, 60, 74, FX_MODE_COMET, 0x8B0000, 1000, true);
    ws2812fx.start();
  ws2812fx.service();
My code using segmentation, note ULP code is missing, not used for segmenting led strips.
#include "sdkconfig.h"
#include "esp32/ulp.h"
#include "driver/rtc_io.h"
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include "AudioAnalyzer.h"
/* define event group and event bits */
EventGroupHandle_t eg;
#define evtDo_AudioReadFreq       ( 1 << 0 ) // 1
TickType_t xTicksToWait0 = 0;
QueueHandle_t xQ_LED_Info;
const int NeoPixelPin = 26;
const int LED_COUNT = 24; //total number of leds in the strip
const int NOISE = 0; // noise that you want to chop off
const int SEG = 6; // how many parts you want to separate the led strip into
const int Priority4 = 4;
const int TaskStack40K = 40000;
const int TaskCore1  = 1;
const int TaskCore0 = 0;
const int AudioSampleSize = 6;
const int Brightness = 180;
const int A_D_ConversionBits = 4096; // arduino use 1024, ESP32 use 4096
const float LED0_Multiplier = 2.0;
Analyzer Audio = Analyzer( 5, 15, 36 );//Strobe pin ->15  RST pin ->2 Analog Pin ->36
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
Adafruit_NeoPixel leds = Adafruit_NeoPixel( LED_COUNT, NeoPixelPin, NEO_GRB + NEO_KHZ800 );
int FreqVal[7];//create an array to store the value of different freq
void ULP_BLINK_RUN(uint32_t us);
  ULP_BLINK_RUN(100000);
  eg = xEventGroupCreate();
  Audio.Init(); // start the audio analyzer
  leds.begin(); // Call this to start up the LED strip.
  clearLEDs();  // This function, defined below, de-energizes all LEDs...
  leds.show();  // ...but the LEDs don't actually update until you call this.
  xQ_LED_Info = xQueueCreate ( 1, sizeof(FreqVal) );
  xTaskCreatePinnedToCore( fDo_AudioReadFreq, "fDo_ AudioReadFreq", TaskStack40K, NULL, Priority4, NULL, TaskCore1 ); //assigned to core
  xTaskCreatePinnedToCore( fDo_LEDs, "fDo_ LEDs", TaskStack40K, NULL, Priority4, NULL, TaskCore0 ); //assigned to core
  xEventGroupSetBits( eg, evtDo_AudioReadFreq );
} // setup()
void loop() {} // void loop
void fDo_LEDs( void *pvParameters )
  int iFreqVal[7];
  int j;
  leds.setBrightness( Brightness ); //  1 = min brightness (off), 255 = max brightness.
  for (;;)
    if (xQueueReceive( xQ_LED_Info, &iFreqVal,  portMAX_DELAY) == pdTRUE)
      j = 0;
      //assign different values for different parts of the led strip
      for (j = 0; j < LED_COUNT; j++)
        if ( (0 <= j) && (j < (LED_COUNT / SEG)) )
          set(j, iFreqVal[0]); // set the color of led
        else if ( ((LED_COUNT / SEG) <= j) && (j < (LED_COUNT / SEG * 2)) )
          set(j, iFreqVal[1]); //orginal code
        else if ( ((LED_COUNT / SEG * 2) <= j) && (j < (LED_COUNT / SEG * 3)) )
          set(j, iFreqVal[2]);
        else if ( ((LED_COUNT / SEG * 3) <= j) && (j < (LED_COUNT / SEG * 4)) )
          set(j, iFreqVal[3]);
        else if ( ((LED_COUNT / SEG * 4) <= j) && (j < (LED_COUNT / SEG * 5)) )
          set(j, iFreqVal[4]);
          set(j, iFreqVal[5]);
      leds.show();
  vTaskDelete( NULL );
} // void fDo_ LEDs( void *pvParameters )
void fDo_AudioReadFreq( void *pvParameters )
  int64_t EndTime = esp_timer_get_time();
  int64_t StartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros
  for (;;)
    xEventGroupWaitBits (eg, evtDo_AudioReadFreq, pdTRUE, pdTRUE, portMAX_DELAY);
    EndTime = esp_timer_get_time() - StartTime;
    // log_i( "TimeSpentOnTasks: %d", EndTime );
    Audio.ReadFreq(FreqVal);
    for (int i = 0; i < 7; i++)
      FreqVal[i] = constrain( FreqVal[i], NOISE, A_D_ConversionBits );
      FreqVal[i] = map( FreqVal[i], NOISE, A_D_ConversionBits, 0, 255 );
      // log_i( "Freq %d Value: %d", i, FreqVal[i]);//used for debugging and Freq choosing
    xQueueSend( xQ_LED_Info, ( void * ) &FreqVal, xTicksToWait0 );
} // fDo_ AudioReadFreq( void *pvParameters )
//the following function set the led color based on its position and freq value
void set(byte position, int value)
  // segment 0, red
  if ( (0 <= position) && (position < LED_COUNT / SEG) ) // segment 0 (bottom to top), red
    if ( value == 0 )
      leds.setPixelColor( position, 0, 0, 0 );
      // increase light output of a low number
      // value += 10;
      // value = constrain( value, 0, 255 ); // keep raised value within limits
      if ( value <= 25 )
        leds.setPixelColor( position, leds.Color( value , 0, 0) );
        if ( (value * LED0_Multiplier) >= 255 )
          leds.setPixelColor( position, leds.Color( 255 , 0, 0) );
          leds.setPixelColor( position, leds.Color( (value * LED0_Multiplier) , 0, 0) );
  else if ( (LED_COUNT / SEG <= position) && (position < LED_COUNT / SEG * 2) ) // segment 1 yellow
    if ( value == 0 )
      leds.setPixelColor(position, leds.Color(0, 0, 0));
      leds.setPixelColor(position, leds.Color( value, value, 0)); // works better to make yellow
  else if ( (LED_COUNT / SEG * 2 <= position) && (position < LED_COUNT / SEG * 3) ) // segment 2 pink
    if ( value == 0 )
      leds.setPixelColor(position, leds.Color( value, 0, value * .91) ); // pink
  else if ( (LED_COUNT / SEG * 3 <= position) && (position < LED_COUNT / SEG * 4) ) // seg 3, green
    if ( value == 0 )
      leds.setPixelColor(position, leds.Color( 0, 0, 0));
    else //
      leds.setPixelColor( position, leds.Color( 0, value, 0) ); //
  else if ( (LED_COUNT / SEG * 4 <= position) && (position < LED_COUNT / SEG * 5) ) // segment 4, leds.color( R, G, B ), blue
    if ( value == 0 )
    else //
      leds.setPixelColor(position, leds.Color( 0, 0, value) ); // blue
  else // segment 5
    if ( value == 0 )
      leds.setPixelColor(position, leds.Color( 0, 0, 0)); // only helps a little bit in turning the leds off
      leds.setPixelColor( position, leds.Color( value, value * .3, 0) ); // orange
} // void set(byte position, int value)
void clearLEDs()
  for (int i = 0; i < LED_COUNT; i++)
    leds.setPixelColor(i, 0);
} // void clearLEDs()
Hello,
Thank you for your answer, but my poor knowledge of programming and English does not allow me to understand everything about your code and how it works.
I still managed to spot that it seems to be written for an ESP32, and I cannot transcribe it to the Arduino UNO that I use ...
So I find myself at square "start" .... :o
Here I set the number of LED's:
This sets the number of segments
Say I have 100 LED's, if each segment was 10 LED's I could then have 10 segments.
Here if ( (0 <= j) && (j < (LED_COUNT / SEG)) ) and else if ( ((LED_COUNT / SEG) <= j) && (j < (LED_COUNT / SEG * 2)) ) in the void fDo_LEDs( void *pvParameters ) divides the LEDS up and applies the proper numbers to the segments. The rest of the code is just stuff.
If you have the code in a sketch, comment out the esp32 junk and the meat of the code will be exposed. You can also comment out the irrelevant fDo_AudioReadFreq function.
