sekUndMinString was not declared in this scope
Hi guys,
I need your help. I programing with the arduino for 2 weeks now and im such a noob in the programing as in other programing languages as well.
I have a projekt which i have to pass in in the next 2 days so pls help.
with in this code. theres everytime the error: sekUndMinString was not declared in this scope.
and i just dont get it :confused:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
const byte startPin = 2, endPin = 3, fehlerPin = 4, buzzerPin = 5, strafZeitPin = 10;
const byte minStrafZeit= 1, maxStarfZeit= 15;
const String strafZeitString= "Fehler", endZeitString= "Endzeit", zeitString= "Zeit", gesamtZeit= "Gesamtzeit";
long millisStart, millisEnde;
int fehler, strafZeit, spielZeit;
void secUndMinString(int input) { // Konvertiert Sekunden in eine Minuten und Sekunden Anzeige
   String minutes = String((int)(input / 60));
   String seconds = String(input % 60);
   if (seconds.length() == 1)
     seconds = "0" + seconds;
   //if (minutes.length() == 1)
   //  minutes = "0" + minutes;
 pinMode(startPin, INPUT);
 pinMode(endPin, INPUT);
 pinMode(fehlerPin, INPUT);
 pinMode(buzzerPin, OUTPUT);
 digitalWrite(buzzerPin, LOW);
 digitalWrite(startPin, HIGH);
 digitalWrite(endPin, HIGH);
 digitalWrite(fehlerPin, HIGH);
 lcd.begin(16, 2);
 lcd.print("Heisser Draht");
 delay(2000);
 lcd.clear();
 lcd.print("Start in");
 for (int zeit=5; zeit>0; zeit-- ){
   lcd.setCursor(9,0);
   lcd.print(zeit);
 //Start des Spiels
 millisStart= millis();
 fehler = 0;
 while (digitalRead(endPin) == HIGH) {
   // Fehlerüberprüfung
   int spielZeit=((millis()- millisStart/1000));
   int strafZeitSum= fehler * strafZeit;
   lcd.print("Zeit:");
   lcd.setCursor(6,0);
   lcd.print(sekUndMinString(spielZeit));
   lcd.setCursor(1,1);
   lcd.print("Gesamt:");
   lcd.setCursor(8,1);
   lcd.print(sekUndMinString(spielZeit + strafZeitSum));
   if (digitalRead(fehlerPin) == LOW) {
     fehler++;
     digitalWrite(buzzerPin, HIGH);
     lcd.print("Zeit:");
     lcd.setCursor(6,0);
     lcd.setCursor(1,1);
     lcd.setCursor(8,1);
 //Ende des Spiels
 millisEnde= millis();
 lcd.clear();
 lcd.print("Ende!");
 lcd.print("Zeit:");
 lcd.setCursor(6,0);
 lcd.setCursor(1,1);
 lcd.setCursor(8,1);
 delay(16000);
void zeigeStatusAufLcd () {
 lcd.print("Zeit:");
 lcd.setCursor(6,0);
 lcd.setCursor(1,1);
 lcd.setCursor(8,1);
sekUndMinString is not declared. secUndMinString is. Spelling matters.
Also, please read the posts by Nick Gammon at the top of this Forum on the proper way to post code here using code tags. (You can edit your post to use them.) It makes it easier for the rest of us to see your code using less space.
thanks, but it donest work either :frowning:
same code, but i fixed the misspell.
error: invalid use of void expression
So, let's see:
The function is defined to not return anything. How can you expect to print that?
