Select pin on SD Card reader
When there are multiple devices on the SPI bus, with one of them being an SD card reader, can I select it, open and read from a file, switch to a different device to do something else, then come back to the SD card reader and continue reading where the pointer left off? Note I did not close the file prior to moving to a different device, so in a sense it's still open.
No in "a sense". In every sense.
Of course.
You'll have to excuse my primitive thinking here Paul. When I think of disconnecting a signal line, I instantly believe that everything else related to that device is lost and will have to be re-initialized. So that's why I'm asking whether it's possible to disconnect the CS signal and re-connect and expect the read pointer to be where I left it.
Sounds like it could work just fine.
I hope that you are simply misusing the term "disconnect". You should not be making connections or disconnecting anything while the Arduino is running. Setting CS HIGH or LOW is a completely different action, and is quite possible. That's how SPI is meant to work.
Setting CS HIGH or LOW does not move the read pointer. That is a property of a class instance, not of the hardware.
Uh yah, not a physical removal of a wire, sorry. Just flipping its state so I can select something else then come back and continue reading where I left of.
