Hi Friends,
I am new to adriuno as well as electronics, and building a project for my self learning, I am facing one issue using NPN transistor when using it as a switch.
For my testing I have 3v and 20mA current should be passing in the circuit via BJT with some current is given to base.
Now when I tried lighting an led without passing current to base my bjt it is still conducting and giving low light on led, the only change happen when I am passing current to base, led turns brighter. unfortunately I do hold datasheet for this bjt as I got this with starter kit.
Not sure what I am doing wrong and why it is conducting without base voltage.
In real use case I want to switch on a 12v motor with max 3Amps current when a high is given to base. please suggest me which NPN (or alternative) I should use since there are many and I do not want to amplify.
Another help I am looking to understand how much voltage and amps a bjt can control/handle before leaking or failing and not getting hot.
How much should be minimum and maximum base voltage and current.
Thanks,
Manish
