selecting correct feedback resistor value
hello guys, I want to know how can I find correct feedback resistor value in an transimpedance amplifier. I know for example a photodiode as input: Vout=Id x R which parameter in datasheet used for calculating feedback resistor value? Thanks
Probably trial-and-error (or use a potentiometer), especially since you probably don't know how much light is hitting the photodiode.
...You may not want to use a pot "permanently", but it could make the experimenting easier.
What amplifier are you using - A standard voltage opamp or a current type?
Allan
allanhurst: What amplifier are you using - A standard voltage opamp or a current type?
Allan
I'm using MCP601.
I'm using MCP601.
The MCP601 is not a transimpedance amplifier.
https://en.wikipedia.org/wiki/Transimpedance_amplifier
Grumpy_Mike: The MCP601 is not a transimpedance amplifier.
see page 15 of datasheet typical application - photo detection
navab1362: hello guys, I want to know how can I find correct feedback resistor value in an transimpedance amplifier. I know for example a photodiode as input: Vout=Id x R which parameter in datasheet used for calculating feedback resistor value? Thanks
R = Vout/Id
The output voltage desired divided by the diode current that should produce it. If you want 1V per microamp, use 1 megaohm.
