Hi all,
I am writing some code for a voltage quantizer and am stuck thinking there must be a better way to do what I am attempting to do.
My current code (which does work), looks like this.
void setStepDown()
byte a = seqNote[writeNum];
switch (quantizerScale)
case 0: //minor
if (seqNote[writeNum] > 0)
byte b = minTable[a - 1]; //this array is different in each case
for (int i = 1; a == b; i++)
b = minTable[a - i]; //and here
seqNote[writeNum] = b;
case 1: //major
byte b = majTable[a - 1]; //only thing different in each case
b = majTable[a - i];
This is actually just a short example, there are actually 8 different cases all which repeat the same code but with a different array "xxxTable[]" in each one.
This seems kind of pointless and messy.
It seems like better code would be to just write the function once and then send the different arrays to it as an argument
So something like this
void setStepDown(byte scale[])
byte b = scale[a - 1];
b = scale[a - i];
And this works, except that I am using a variable with the value of 0-7 to determine which xxxTable is being used, so when I call the function
setStepDown(xxxTable[]);
I can't figure out how to change the array that is sent to the function without doing something like creating another switch case and putting a different version of the function in each one.
I hope what I am asking is clear. I will do my best to answer any questions If this is confusing.
I'm pretty much self taught when it comes to programming so I suspect there is something that I am overlooking or haven't been introduced to.
Thanks in advance.
