Selecting hardware: wireless-controlled LED on battery
Greetings,
I would like to make the following setup: an LED (or a group of 3-5) toggled by a wireless signal, in a small package – comparable to a cigarette pack or smaller. The LED state will be updated once every 3 minutes. I expect the lights to be on for 30 minutes a day or less. This is where specifications end and possibilities begin, and I would like to ask your advice on the best way to proceed.
I would very much prefer to have the device run on a battery, but it should last for 3 months or more, and the battery should be easy to buy and replace. Is this kind of battery life possible with wireless connection? Note that it can be asleep most of the time. Another possible option, from what I've found, is power via computer's USB port – this would be less desirable though.
As to connectivity, I thought of two options: first, a Wi-Fi connection to an existing network. In this case, the device should ping a remote server once every 3 minutes and receive the LED state (on or off). Second, it could have a bluetooth connection to an Android smartphone, and receive the state from an app (which will connect to a server). I can code as far as the app goes, and I assume it should be fairly easy to toggle an LED.
I have researched a little on battery life, and found some articles that recommend making a custom controller, with all the non-essential components cut out. This is not an option for me, because I have no experience in electronics. If you could suggest a setup that requires minimal adjustments, this would be perfect. I do not have any hardware yet.
On batteries that last three months? Unless you don't mind a pair of large car batteries, that's a non-starter.
Bluetooth can be powered down while the Arduino sleeps, but takes time to come back up and reconnect.
Is the device going to pull data or is data going to be pushed to it? If data is going to be pushed at random times, the Arduino and radio can hardly be napping most of the time.
How about a Promini, nrf24L01+ module, P-channel MOSFET so the module could be fully powered down, and high brightness LEDs that would seem pretty bright still at low mA levels while on.
Turn off LEDs & RF, go into power down sleep mode. Wake on battery backed interrupt from an alarm equipped RTC module every 3 minutes, power up the RF, request data, go back to sleep.
