Selecting the right arduino board for project
I'm looking to make a touch sensitive chess board with 64 different sensor pads used to trigger sounds.
I have no real idea how to do this but I plan on figuring it out along the way. However I don't wont to get halfway through and realise i should have bought i different board to start out with.
Is there a preferred arduino for using with touch sensor peripherals?
Cheers
64 inputs can be don with any Arduino (although you might need external chips and/or cleaver reading).
Most important question, what is supposed to make the sounds?
I think i'll be looking to get it trigger ableton. I guess midi programming is probably the best way to do this.
Is there an arduino that is best for midi outputting?
cheers
Midi also isn't terrible hard. If you do a quick google you can see a lot of projects using Midi. Heck, you can even search for "Arduino ableton" and find quite some projects.
Finn67:
An Arduino Mega has the most I/O pins by a substantial margin.
Without knowing the touch sensors you plan to use it is impossible to know how they might connect to an Arduino.
If you are inexperienced with Arduinos then I suggest you start with a small part of your project - such as as one or two touch sensors and learn how to implement them.
As you learn more your concept of how to implement the project will probably change so I reckon you should expect to find yourself in the position where you need to buy some different parts.
...R
